Old 02-20-2010, 11:43 AM   #11 (permalink)
Tank - '76 El Camino Classic
90 day: 25.89 mpg (US)
Sabrina - '91 190 E
90 day: 37.07 mpg (US)
Angel - '88 420SEL
Last 3: 23.01 mpg (US)
Why are you giving the O.P. advice if you have no idea if it will help or hinder achieving his fuel economy goal?
Because we did it on our car and i told him the results, i didn't monitor before after FE results but looking at the mileage on that car I'd say it helped out a little, especially since less throttle is needed to achieve the same speed that extra throttle response can sometime save a bit of gas
Tank:
(No actual EPA numbers for car just used F/E numbers when i first got it)
Old 02-20-2010, 02:21 PM   #12 (permalink)
Daox's Paseo - '97 Paseo
Last 3: 53.99 mpg (US)
Daox's Prius - '04 Prius
90 day: 54.91 mpg (US)
CM400E - '81 CM400E
Sorry Domman, you just don't get it. You keep saying less throttle is better for FE, but you apparently don't understand how engine efficiency works. More throttle means more efficiency. This is why pulse and glide works so amazingly well. Its also why you drop down engine size to increase mileage. Using your theory that less throttle is better, I should drop a 350 in my Paseo for as little throttle as possible while cruising. Seriously, you need to read up on brake specific fuel consumption and stop giving bad info to people.
Reviving a 2000 Honda Insight "beater" Red Hybrids 209 05-07-2012 09:47 AM
Longtime Lurker Looking for Miles ZX40 Electric Micro van mods & information rmay635703 Fossil Fuel Free 46 03-15-2012 07:21 PM
Mullet's Metro Project Johnny Mullet EcoModding Central 302 02-06-2011 07:04 PM
smaller exaust pipe for mpg moonmonkey EcoModding Central 77 02-19-2010 02:15 PM
Using exaust gas as an aero. aid Cd Aerodynamics 15 04-12-2008 09:33 PM
