Old 11-25-2012, 12:03 AM   #11 (permalink)
Burn lean and prosper\\//
VLX - '93 Honda Civic VLX
90 day: 51.1 mpg (US)
Yea grab the ecu number as well. It's behind the passenger kick panel by the floor. What model civic is it? I couldn't read anything on the hatch.
Old 11-25-2012, 12:20 AM   #12 (permalink)
Sven7's Avatar
Boo Radley - '65 Ford F100
90 day: 13.28 mpg (US)
I'll go grab numbers tomorrow. The PO had the ECU hidden in a corner of the garage so I surely know where it goes!
I've been looking though Japanese names, and I'm somewhat partial to Ren. The car is definitely a guy.
http://www.behindthename.com/name/ren
I'll also go look at the steering components to make sure it's the tie rod ends. I'm not going to drive the car until that's fixed and it's lowered and aligned.
Old 11-25-2012, 11:23 AM   #13 (permalink)
Master Ecomadman
arcosine's Avatar
sc1 - '98 saturn sc1
Team Saturn
90 day: 43.17 mpg (US)
rans - '97 rans tailwind
90 day: 28.25 mpg (US)
red bug - '00 VW beetle TDI
big tractor - '66 ford 3400
90 day: 58.42 mpg (US)
RV - '88 Winnebago LeSharo
90 day: 16.67 mpg (US)
Did my tie rod end and aligned it this morning. Not too bad out 25F and sunny.I got the more expensive one with the grease fitting. $18.99 and not the cheap one, $10.99.
Honda suspensions are a pain to work on, when I changed the struts in my 87 accord, I had to drill out the pincher bolts because they snapped off. Saturns just have two big bolts to undo, no pincher clamps.. I always put grease on all the threads, so if I need to take it apart in the future, it will be easier and not rusted up.
... rolling better than ever with zero toe. alignment procedure posted on sc1 aeromods
http://ecomodder.com/forum/showthrea...-15529-16.html
- Tony
Old 11-25-2012, 11:47 AM   #14 (permalink)
Vader - '15 Dodge Grand Caravan
90 day: 23.13 mpg (US)
Cmax - '13 Ford Cmax SEL
90 day: 40.92 mpg (US)
Originally Posted by Sven7 View Post
Ha, nice. I like the shark teeth!
If you have some extra 14" wheels you'd like to part with let me know. I'm going to need some to put winter tires on.
Thanks. Sorry no extras here but if you ever need a hand with making/installing the kammback feel free to hit me up, I'd be happy to help. This is my first Honda as well.
Old 11-25-2012, 12:09 PM   #15 (permalink)
Cd
Ultimate Fail
Cd's Avatar
Behind the Name: Meaning, Origin and History of the Name Ren
The first thing I thought of was Ren Hoek .
Old 11-25-2012, 01:05 PM   #16 (permalink)
Wiki Mod
Weather Spotter's Avatar
Max - '14 Ford C-Max SEL
build a boat tail for it!
Old 11-25-2012, 02:06 PM   #17 (permalink)
Master Ecomadman
arcosine's Avatar
Team Saturn
Put front skirts on it!
Its a "lily" red car..
http://www.japan-guide.com/forum/que...y.html?0+79524
- Tony
Old 11-25-2012, 08:02 PM   #18 (permalink)
Sven7's Avatar
arcosine-
Could it be difficult because of the double wishbone suspension?
drainoil-
I'll be experimenting with fiberglass at some point so you'd be welcome to build a kammback off my template afterward. I like to DIY stuff like that.
Cd-
Thought about Ren&Stimpy but also about Rén. I liked Kiku as well, but the car just isn't a girl.
WS,arc-
No boat tail. I'm debating putting rear skirts on. There will be no duct tape on this car. Whatever I make will have to be bolted or zip tied on. That could mean removable fiberglass rear skirts in the future. We'll see what MPG it gets as is.
It's a D16Y7 engine. I didn't see if it's still OBD.
Originally Posted by wikipedia
D16Y7
Found in:
1996–2000 Honda Civic DX/VP/LX/CX
1998–2000 Honda Civic Special Edition – SE/EX(Canada)
1996–1997 Honda Del Sol S
1996–1997 Honda Civic Coupé LSI
Bore and Stroke: see D16 Series Engines
Displacement: see D16 Series Engines
Compression: 9.4:1
Power: 106 hp (79.0 kW, 107 ps) at 6,200 rpm
Torque: 103 lb·ft (140 N.m) at 4,600 rpm
Redline: 6,800 rpm
Rev-limiter: 7,200 rpm
Valvetrain: SOHC (4 valves per cylinder)
Fuel Control: OBD2-a MPFI
Head Code: P2A-2
Piston Code: P2E
ECU Code: P2E
Cam Gear: 38 Tooth
Also did not get a chance to check the tie rod ends today, but I will pick up some stuff at NAPA tomorrow to get started.
Today was spent blocking the grilles, sanding and retouching some of the cracking bumper paint, moving the license plate to a less distracting place, and removing the front "H" emblem. Turns out the car was built in Ontario.
There is a serious problem with something in the drivers side window mechanism, so that it does not roll up correctly. I'm going to leave it as is until I can either buy another, working, door or fix it. The upper hatch needs a strut assembly.
The paint looks best in photos. It looks good from about 60 feet away.
Ren by Tyler Linner, Intergalactic Man of Mystery, on Flickr
Old 11-25-2012, 08:07 PM   #19 (permalink)
Sven7's Avatar
4x4 stance. Buying coilover springs tomorrow.
Edit oops. Forgot to get the ECU number.
VIN tells me the specific chassis code for this car is EH2 (3 door 1.5L). It rolled off the line in Alliston, ON with a stick shift trans.
Okay last thing for tonight. I've seen rumors of OEM exterior mirror delete panels for JDM models, but can't seem to find any hard facts or items for sale. Does anyone know about this? I'd rather throw a piece of plastic on there than rig up God-knows-what to fill the hole.
Old 11-25-2012, 09:56 PM   #20 (permalink)
Sven7's Avatar
Last last thing for tonight.
Just bought some cheapo coilover springs. The Ebay page showed a big-boobed Asian chick in front of a yellow R34 Skyline, as well as assurance that these coilovers offers [sic] race car performance. Well, if that's the case...
G'night, guys and gals!
