You are going to want to bump it up to a 24 volt panel and a charge controler.
"12v panels" barely charge 12 batteries, using a 12 volt panel to charge a 14 volt cell stack or pushing power onto a 14.4v system just isn't going to happen, it will be a waste of money.
1984 chevy suburban, custom made 6.5L high compression diesel.
New engine is in and should be good for 29mpg highway.
1985 chevy camaro mostly stock.
