Old 07-06-2009, 09:45 AM   #11 (permalink)
Sorry to bump up an older thread.
But ( cant remmember which team ) there was a motorcycle racing team that decided to install the exhaust under the seat - and it gave trememdous advantages.
Old 07-06-2009, 02:33 PM   #12 (permalink)
ooo ooo ooo ah ah ah
Blue - '93 Tempo
ShWing! - '82 gold wing Interstate
F150 - '94 F150 XLT
Sport Coupe - '92 Tempo GL
Moon Unit - '98 Sable LX Wagon
Sure, things are a bit different when you're going 180 mph and seeking tenth-of-a-second advantages.
Old 07-24-2009, 02:12 AM   #13 (permalink)
BamZipPow's Avatar
BZP T-100 (2010) - '98 T-100 ext cab - 3.4L/auto SR5
90 day: 20.99 mpg (US)
BZP T-100 (2011) - '98 T-100 ext cab - 3.4L/auto SR5
90 day: 20.93 mpg (US)
BZP T-100 (2009) - '98 T-100 ext cab - 3.4L/auto SR5
Last 3: 19.01 mpg (US)
BZP T-100 (current) (2012) - '98 T-100 ext cab - 3.4L/auto SR5
90 day: 19.56 mpg (US)
Send a message via ICQ to BamZipPow Send a message via AIM to BamZipPow Send a message via MSN to BamZipPow Send a message via Yahoo to BamZipPow
I bet that kinda heated up their rear end a little bit...kinda like putting the fire to their butt.
Old 07-25-2009, 01:56 PM   #14 (permalink)
slipstream
Originally Posted by ConnClark View Post
Right now my exhaust exits right below the bumper on the drivers side. I could get it to route just above the bumper with a slight bend just in front of the muffler and a 6 inch extension. The exit would be right in the slipstream then and hence in a slight vacuum.
I would have to cut the body work which makes me uneasy with this mod.
Edit: CO poisoning isn't a problem on diesels unless they are way out of tune. Fumes wouldn't getting into the passenger compartment wouldn't be a problem anyway
The base pressure behind the 300 will essentially be at the same pressure as where the air separates.If the side tailpipe is within 6-inches of the tail,there may be little Delta-P between the two locations.Also,the side flow is dilluting the exhaust stream through mixing,which wouldn't necessarily occur behind the car,making it nastier for following motorists.
Old 07-27-2009, 12:53 AM   #15 (permalink)
mwebb's Avatar
1996 geo metro - '96 metro base
just placing the exhaust tip willy nilly somewhere may put it in an area of pressure or ...
so
it would not be too hard
to measure , just get a MAP or FuelTankPressuresensor sensor from somewhere (junk yard) get the connector too ...
three pins on the MAP or FuelTankPressure sensor.
power 5v , ground , signal .
,tap into the 5volt reference in the car OR make up a 5v power supply , use a dvom or labscope on the MAP or FuelTankPressure sensor sensor signal pin
and position a vacuum line from the MAP or FuelTankPressure sensor in the car
to the area you suspect has lower "pressure " , drive the car .
not moving signal voltage will be about 4.5 volts on a MAP sensor from GM or 3 volts on a Honda MAP sensor , what ever the value
assign it to be "local Ambient Barometric pressure "
for this test ;
lower voltage is better because it will show (lower pressure),
you will be searching for the vacuum hose position that yields the lowest value
there are charts that will give up voltage vs "pressure" values.
depending on which MAP or FuelTankPressuresensor you can scavenge from ...
a FuelTankPressure sensor will have better resolution .(differences will be easier to measure and see)
or use a real pressure transducer .
or a water filled vertical "U" shaped tube with the vacuum line on one end of the "U" permanent marker graduation s ...
either way , differences will not be large
Old 07-27-2009, 08:32 PM   #16 (permalink)
I think sending more concentrated exhaust to following cars is reason enough not to do it. It could be a pretty significant difference considering that cars intake air for the HVAC at the cowl... So someone drafting you would get your exhaust in the cabin.
Old 07-27-2009, 11:09 PM   #17 (permalink)
Blue - '93 Tempo
F150 - '94 F150 XLT
I usually smell smokers in the cars ahead of me (with all my windows up) before I see them!
Proposed braking test: comparing tire pressure @ 50 psi vs 35 brucepick EcoModding Central 55 06-11-2011 08:29 PM
The Mechanism Behind Flow Separation LostCause Aerodynamics 46 07-15-2010 07:38 AM
Discussion on tire efficiency Ernie Rogers General Efficiency Discussion 68 02-21-2010 08:45 PM
Looking for a fuel efficient solution. I've got a few ideas. CuriousOne EcoModding Central 41 03-28-2009 02:46 PM
Valve stem caps that blink when your pressure is low SVOboy EcoModding Central 1 12-23-2007 03:57 PM
