Old 09-09-2008, 02:26 PM   #1 (permalink)
wagonman76's Avatar
Red Car - '89 Celebrity CL 4 door
Team Chevy
90 day: 36.47 mpg (US)
Winter Wagon - '89 6000 LE Wagon
90 day: 28.26 mpg (US)
Restricted fuel system affect mpguino readings?
Ive charted my last few mpguino tank readings compared to actual fuel usage. It started out very close, then read 4% high on fuel use twice, then last time was 8.5% high on fuel use.
Ive also had a couple times in the last few tanks where the fuel seems restricted, and it acts like it is almost out of gas for a bit. I know, I need to change the fuel filter since the pump seems to act just fine.
But anyway, I was wondering if this could actually cause the readings to be skewed? Like say the injectors are firing (and even firing even longer because of more throttle while attempting to go faster) but the actual fuel is not getting through. So fuel usage reads high. Until the computer compensates, if it even can accurately.
And if this is the case, this could even be a bonus of the mpguino, if the fuel usage starts to read high fuel usage (or low mpg), it could be a sign of reduced fuel pressure and an early warning to fuel system problems.
Winter daily driver, parked most days right now
Summer daily driver
Old 09-09-2008, 02:34 PM   #2 (permalink)
dcb
needs more cowbell
dcb's Avatar
pimp mobile - '81 gs 250 t
90 day: 96.29 mpg (US)
schnitzel - '01 Golf TDI
90 day: 53.56 mpg (US)
Absolutely. If the fuel system pressure is dropping due to an overly clogged filter or pump problems then the injectors have to stay open longer (and would look like more fuel going into the engine).
Same is true if the injectors are getting clogged, they have to spray longer to keep the o2 sensor happy.
Hydrogen Generator Experiment willy57 DIY / How-to 473 03-04-2011 03:29 PM
Fuel Economy related papers tasdrouille General Efficiency Discussion 31 01-18-2011 11:48 AM
ElmScan + Customized Scantool Software = data logging! cfg83 Instrumentation 19 08-08-2010 10:24 PM
mileage computer for a carbureted engine diesel_john Instrumentation 162 07-18-2010 06:31 PM
smart cdi (diesel) owner from BC, Canada smartzuuk Introductions 23 04-10-2010 01:22 PM
