Retrailer (building a good trailer from scrap / other trailer parts)
If you are the company that builds trailers in bulk to sell at lowes, home depot or northern tool you are trying to get the cheapest and there for thinnest steel that should do the job and hold it all together with as few welds as possible, as if there is a shortage of welding sticks.
Since the steel its self and welding are among your top expenses that is where you cut corners. If you get your steel comes from the scrap yard you error on the side of heavier steel, part of the reason is the flimsy stuff like what the big box stores use in their trailers gets crushed or bent beyond the point to where its not useable ether because it failed in its past life or in the scrap yard environment its self. At 15 cents a pound you don't really worry about if you go 20 or 30 pounds heavy. I think my standard trailer frame design will measure 98''x64'' that way it can easily swallow 4'x8' sheets of anything that's important because most builders only think in 4' and/or 8' lenghts. The box and A-frame alone will weigh 140 pounds and cost me a grand total of about $20 in steel. The other expense is welding. Since I am the welder and I have pride and give a damn about my work I fully weld most joints for a few reasons. Also after years of MIG welding experimentation I have worked out the most economical way to lay down a weld that is both strong and good looking. I'm thinking each one will run about $3 or $4 worth of wire, another $3 or $4 worth of my special economical welding gas mix, to stick together $20 worth of steel, $20 for trailer lights, about $100 for new springs axle, tires and spindles. Not sure how much sandblast and painting will cost but I think it will be around $30. Axles, spindles and springs are going to a bit of a money eater. All costs are passed down to the end consumer, would like to pass along less cost. There is literally tons of slightly used fairly straight hot rolled 1/4 inch thick C-channel, in the form of 5'4'' long scaffolding at the scrap yard down the street from me. Plus there is all the other random stuff that shows up. I like the I-beams. I think I will make the non standard trailers out of a mix of 1/4'' scaffolding and what ever shows up. I think any one that owns or has access to a scrap pile, welding machine, drill and chop saw can build a trailer. I find a lot of people lack electrical skills or are afraid of wiring, if so pay some honky mechanic $50 to wire it up for you. |
5 Attachment(s)
Went to lowes.
They set the bar pretty low. $900 gets you a 2000lb 5'x8' trailer with a box frame made out of what I would call "bed frame angle iron". I guess they are depending on the wood decking to be part of the structure. Nothing wrong with that, till the wood gets old and rotted. Welds are clearly from a stick machine using a small rod with the amps cranked way up and leave something to be desired. Looked up the trailer laws for New mexico, they give me a lot of room to work with. New Mexico Trailer Laws & Regulations Look-Up - Trailers.com - Shop Cargo, Utility, Equipment, & Enclosed Trailers If I copy the basic lay out of my rebuilt northern tool trailer with 2 brake lights, 2 amber running lights, license plate light, rear reflector, safety chains, 2500lb cap. with nonbrake hubs the design will be accepted almost every where. Here are some pics: (the small trailer is missing a cross brace, need to drag out the plasma cutter and cut a length of that heavy angle iron to fit, and I'm going to cut 2 or 3 extras when I do) |
yours are deff some nice welds. i am still learning to weld mig solid wire and have had the machine 10 years now. what is this 'special economical welding gas mix' you speek of. i use 75/25 i believe.
C25 mix is over priced, takes up too much room for something that only does one thing.
I still need to weld stainless and aluminum. Stainless needs a 3% CO2/Argon mix, Aluminum needs pure argon. So I use a bottle of CO2 and Argon, blend them together for a 60% to 70% carbon dioxide blend. |
i just have a single gauge, can i get a pic of the mix valves you have. i need to get a spool gun also but can't justify it right now. sorry for all the questions.
I don't have mixing valves, just standard regulators with flow meters, just set the pressures on the 2 regulators with in a few PSI of each other and plumbed them together.
A spool gun is good for 2 things. Its good for aluminum because soft weak aluminum does not like to feed through a MIG welder handle at the high wire feed speeds that you run aluminum at. It tends to break. Its also good for switching between fillers, they can save a lot of time if you find your self spending a lot of time switching back and forth between different rolls of wire. |
Shipping containers weigh about 5K lb or the 20' and 9K lb for the 40' versions. Assume 2 or 3 I-beam front truck axles with an electric steering rack, and a 6x6" wooden telescopic boom 12-24' long.
Do you think the design is feasible? Would putting the axles 10% behind the center of gravity allow manageable tongue weight? |
My old century had a rusted solid feed cable and I retrofitted an ebay hot max spg spool gun. No regrets, cost competitive with the OEM, flexible cable, and can entertain aluminum. I used the original speed control, just turned the setting down by about 1/2 (12v motor in the gun). The gun is a little cheezy but nothing insurmountable for a budget item.
Trailers that heavy are designed to be just about balanced on their multiple axles, or with turning wheels up front and a tow boom that moves up & down. Like this : http://www.konag.nl/media/catalog/pr...naamloos-7.jpg |
cringing at the rolling resistance of that trailer
I'm thinking of something like the front dolly with a third axle and a longer boom, eliminating the weight of the other 2/3 of that trailer (it is shiny though). The container is inherently stiff enough it doesn't need all that support.
And electrically steered axles for parallel parking. |
1 Attachment(s)
Its been slow going but I have the first trailer almost finished.
Got it sand blasted and primed. I am putting the deck on. This one is a little 43''x49'' unit rated for 1000lb. After all the holes get drilled for the decking bolts its all coming off and I am going to paint it dark blue, because that is the color paint I have. http://ecomodder.com/forum/attachmen...1&d=1380140826 |
It's looking good. What are the 12 holes above the hitch and on the front corners for?
There's a metals recycler between me and the train yard, I should stop by and ask if they sell as well as buy. |
The holes where the hitch should be are to attack a bolt on ball coupler.
The holes on the corners are hard attaching points, then there are a few holes along the frame to run wires and install the turn signals and running lights. They should want to sell anything they have. The scrap yard here really likes to resell stuff locally or else they have to truck the scrap 7 hours south of here to a steel mill in mexico. |
1 Attachment(s)
Here is the finished version. With 1300 pounds of shingles.
Painted it orange instead of dark blue, didn't think I had enough blue paint to get full coverage. http://ecomodder.com/forum/attachmen...1&d=1380748703 |
3 Attachment(s)
Tear'em down and build them up.
From this one I think I am almost done with the tear down. I cut out about 200 pounds of bent metal and broken welds, all cross members, tongue and hitch. I am going to add at least 400lb of reclaimed steel, adding about 2 feet of length. I am reusing the axles, springs, wheel assemblies, most of the frame, fenders, about half of the original wood, some of the wiring, even reusing the old U-bolts I had to cut as tie downs. This is after the chain saw got it. http://ecomodder.com/forum/attachmen...1&d=1389926820 Miller 625 plasma cutter, impact wrench http://ecomodder.com/forum/attachmen...1&d=1389926820 A few more hours of plasma cutting and grinding. http://ecomodder.com/forum/attachmen...1&d=1389926820 |
Old camp trailers are a good place for lightweight trailer chassis. The pop up tent trailers usually have high load rated, small diameter tires too, though they have to be carefully maintained for long term high speed use.
I never did post the finished picture of that gigantic trailer I was building.
Well here it is. The deck is 18 feet long and 99 inches wide, just under the legal width limit. Hauling 3,200 pounds of crap. http://ecomodder.com/forum/attachmen...1&d=1450469995 And yes a good portion of that trailer was made from what you see all cut apart in my drive way. The sides, the axles, springs, tires and some of the old wood (not shown). I absolutely gutted it. The original trailer weighed 900 pounds, when I got done with it the empty weight is now right about 2,000 pounds. |
Another good source for a trailer frame could be a old golf cart frame. The one I just got rid of from my "off road hybrid buggy" project was a Club Car made of aluminum i-beams, very strong and light.
If I ever see one at the scrap yard I will check it out.
