Old 04-07-2008, 07:59 AM   #31 (permalink)
Moderator
tasdrouille's Avatar
The Guzzler - '08 Elantra GL
90 day: 33.12 mpg (US)
Got Soul? - '011 Soul 2U
I use OEM filters with a filter minder on the TDI, so I only change filters wen they need to be changed.
www.HyperKilometreur.com - Quand chaque goutte compte...
Old 04-07-2008, 11:27 PM   #32 (permalink)
Giant Moving Eco-Wall
DifferentPointofView's Avatar
The Jeep! - '95 Grand Cherokee ZJ Laredo
90 day: 23.75 mpg (US)
The Caliber - '07 Caliber R/T
90 day: 30.6 mpg (US)
The 'Scort - '98 Escort LX
It's not much (typically) We're talking a tiny bit of dirt stuck in the corners
Oh, I thought you meant 1/4" build up on the surface of the filter. which to me is taking a ruler to the dust and it goes into it 1/4"
Yea.. I drive a Jeep and I'm on a fuel economy site, but you just wouldn't understand... "It's a Jeep thing!" *Jeep Wave*
Did I Use Too Many Abbreviations? Here's The Abbreviations List
Old 04-09-2008, 12:13 AM   #33 (permalink)
Funny's Avatar
Rolling Lemon - '02 Corolla S
90 day: 40.94 mpg (US)
Originally Posted by Big Dave View Post
The subject of air filters has been studied to death by trucking companies, railroads and river towboat operators. Literally thousands of studies, done over decades.
The unanimous conclusion: A paper air filter puts the cleanest air into your engine. Oiled fiberglass lets much more dirt into your engine. Dirt equals wear and engine parts are much more expensive than fuel.
Further, a paper filter gets more efficient at removing dirt as it builds us a “cake” of air on its intake side. In fact, it is most effective as a filter just before it plugs up entirely. Some industrial operators will dust on some lime before they install an air filter to get a “starter cake.” A K&N gets less efficient as it builds up a cake, because as the sticky surfaces are fouled, they just let the dirt zoom on through.
I work for the one of the few filter media manufacturing companies that supplies Baldwin filters with the paper (which can contain both wood pulp and glass fibers in the same filter) that they make their filters with. The only thing that needs to be corrected about Big Dave's statement is the oiled fiberglass part. First, it is cotton gauze that most "high flow" filters are made of. Secondly, Fiberglass, mainly microfibers, are used to increase efficiency. By efficiency, I mean ability to contain particles of a smaller size. Generally a filter's efficiency is inversely proportional to it's capacity. So, one cannot have his cake and eat it too . Congrats to Big Dave to an otherwise flawless post .
American by right
Ecomodder by choice
Hypermiler by necessity
Old 04-09-2008, 01:06 AM   #34 (permalink)
Ryland's Avatar
honda cb125 - '74 CB 125 S1
90 day: 79.71 mpg (US)
green wedge - '81 Commuti-Car
Blue VX - '93 Civic VX
I thought that semi's still used oil bath filters, as they can hold pounds of dirt in a few cups of oil, and just need the oil changed, from what I have read about them they sounded like the best air filter you could get, other then people don't understand how to maintain them.
Old 04-09-2008, 06:48 AM   #35 (permalink)
Funny's Avatar
Oil bath filters are used on much older semi's, and the truckers are the ones that changed over to HUGE air filters. They were sick of wiping out all the nasty oil (especially when there are dead critters in it). So they went to filters that are upwards of 2 feet tall and a foot plus diameter.
American by right
Ecomodder by choice
Old 04-09-2008, 07:31 AM   #36 (permalink)
EcoMudder
Harpo's Avatar
Harpo's Honda - '05 Civic VP
90 day: 42.64 mpg (US)
Be carefull
Originally Posted by Chris D. View Post
I'm going to try just using my air compressor and blowing the dirt out of the paper one from the back side (clean side)....
Be carefull, and use low pressure at a generous distance or you'll blow some micro-holes in the filter element thereby rendering it less effective. Tapping it out, and using a shop vacuum works for me.
Old 04-09-2008, 05:04 PM   #37 (permalink)
EcoModding Minded
Chris D.'s Avatar
Lunar Mist - '02 Tacoma SR5
90 day: 25.31 mpg (US)
Silver Streak - '08 Corolla S
90 day: 38.25 mpg (US)
Send a message via AIM to Chris D.
thanks for the advise, I'll exercise extreme caution when doing so..
Cold air VS Warm Air Intakes - what's the difference? deadman1474 EcoModding Central 49 03-25-2012 10:47 PM
Honda IACV explained TomO Off-Topic Tech 10 11-25-2011 12:59 PM
Home made air conditioning article Fudog1138 General Efficiency Discussion 9 11-24-2008 08:13 PM
DIY: tire bands for Air Pressure Sensors larrydag DIY / How-to 10 05-08-2008 01:30 PM
OEM Air Injection, Yay or nay? Dane-ger EcoModding Central 11 01-14-2008 10:05 AM
