Old 12-31-2013, 02:26 PM   #1 (permalink)
Reverse-Trike EV
Giovanni LiCalsi's Avatar
Reverse-Trike EV
I'm building a reverse trike with two 15kw 20hp brushless motors with Hall's Effect sensors.
The motors will independently drive the front wheels and will provide limited slip.
It's motors will be mounted forward of the front axle and the battery packs with controllers will be mounted behind the front axle.
The motors will be powered by two 15kw 100volt Lipo battery packs.
Each individual motor will be connected to it's own electronic speed controller.
The controllers are PC programmable for low battery warning, high amp limiter, brake regeneration, soft start and high-speed governor.
I will be using a detachable iPad Mini for the dashboard that will also have remote ignition, GPS locator and Lo-Jack.
The wheels will be carbon fiber 17" Blackstone Black Mambas, as well as the rear single-sided swingarm.
The belly pan and lower body section will be made out of all metal Alulight aluminum foam panels.
It's upper body section will be made out of fiberglass.
The entire EV will weigh in at 800lbs. and have around a 75-100 mile range per charge.
It can take a 100% charge in 20 minutes.
Sevcon Gen4 Speed Controller
Astroflight 15kw 100volt Brushless Motor , 12lb. - 4-1/2" Diameter x 7" length
Blackstone Single-sided Swingarm 5lbs.
Black Mamba Wheel On Ducat 1098, 5.97lbs.
Kind Regards,
Giovanni
http://www.steamcar.net/stanley/fastest.pdf
The Following 3 Users Say Thank You to Giovanni LiCalsi For This Useful Post:
aerohead (01-03-2014), NeilBlanchard (01-01-2014), renault_megane_dci (01-01-2014)
Old 01-01-2014, 03:30 AM   #2 (permalink)
Wow! I'll be following this one.
Old 01-01-2014, 07:34 AM   #3 (permalink)
la_voiture_de_courses - '03 Renault Megane Estate
OldContinents
90 day: 44.34 mpg (US)
xiao lan - '01 Audi A2
90 day: 38.88 mpg (US)
Brit iron - '92 Mini Mini
90 day: 45.5 mpg (US)
Prius - '09 Toyota PRIUS Lounge
90 day: 47.37 mpg (US)
Beemer - '06 BMW F800 ST
90 day: 53.06 mpg (US)
Could you reply and add stuff on a single thread ?
It is much easier to follow.
And obviously I very much like what you show us.
The Following User Says Thank You to renault_megane_dci For This Useful Post:
Xist (01-01-2014)
Old 01-01-2014, 12:24 PM   #4 (permalink)
wheelbender6's Avatar
That sounds like a real beast with 40hp. I'll be living through you vicariously.
Bicycle, 125cc motor scooter, 4.0L pick up truck
Old 01-01-2014, 12:37 PM   #5 (permalink)
Reverse-Trike EV
Here is the spec sheet for the motors.
Kind Regards,
Giovanni
The Following User Says Thank You to Giovanni LiCalsi For This Useful Post:
Old 01-01-2014, 12:38 PM   #6 (permalink)
Reverse-Trike EV
Is it ok to stay on this thread?
Kind Regards,
Giovanni
Old 01-01-2014, 12:52 PM   #7 (permalink)
Reverse-Trike EV
I am using the 1906 Stanley Rocket body but reversing direction.
The front of the reverse-trike will have the curved shape and the tapered end will house the single wheel.
What is old is now new.
Kind Regards,
Giovanni
Old 01-01-2014, 09:03 PM   #8 (permalink)
If there were any content in the other threads the mods can combine (or separate) them.
The Stanley is almost symmetrical. For the best aerodynamics the widest point should be at 30% of the length, in plan and taper. I don't know if the simple curve below the beltline and compound curved above is optimal.
Here's my design. The front suspension, steering and brake lines are in a filleted pylon. It's 3x12ft, the same as a P-38 drop tank. It has four wheels to fit into an open-wheel Lakester racing class.
It would actually be constructed of sheets braked into triangular or hexagonal flats , instead of being compound curved.
Old 01-01-2014, 09:23 PM   #9 (permalink)
Reverse-Trike EV
Very impressive drawing!
Kind Regards,
Giovanni
Old 01-01-2014, 10:52 PM   #10 (permalink)
90 day: 29.44 mpg (US)
Freebeard, that is awesome!
A very unexpected four-wheel design, too!
If I ever finish my prototype Kamm-rack, I plan on cutting pieces of foam to fit together to make a foam-and-fiberglass version, so kind of like that, but I plan on sanding down the corners on the outside and filling in them on the inside.
