Old 08-04-2010, 02:34 PM   #1 (permalink)
Revise Tacoma air flow test results
The Flow Illustrator website was briefly functional yesterday (it's been down with various errors as of late) and I used the opportunity to update my air flow tests for my 2003 Toyota Tacoma short bed truck to remove some noise from the slanted cap configuration and to add a new configuration: A cap that rises directly vertical 3 inches above the cab i.e. without a slant (or "wedge" in cap lingo). Best watched in 720p HD...
The Following 2 Users Say Thank You to Varu For This Useful Post:
ChazInMT (08-04-2010), davidgrey50 (08-04-2010)
Old 08-04-2010, 02:52 PM   #2 (permalink)
Cogito Ergo Ecomod
davidgrey50's Avatar
Dobbin - '04 Dakota 3.7 V6 A/T
Thank you, Varu! As someone with a drawerful of sketches for an aerocap, I really appreciate some objective info. As a simple peasant, though, I'm concluding that a complex curved cap or a simpler slanted cap work about equally well. Yes?
Old 08-04-2010, 03:04 PM   #3 (permalink)
I was just remarking to someone that if I build a cap I might as well go with a plain slant. But then it occurred to me that the air speed is pretty slow in all of my simulations. I had set Re to 100. So my next batch of tests will be with faster wind to see if I there's any significant difference in turbulence between curved and slanted.
Old 08-04-2010, 03:21 PM   #4 (permalink)
Cogito Ergo Ecomod
I look forward to seeing them. Thanks again!
Old 08-04-2010, 05:25 PM   #5 (permalink)
eco....something or other
wood hauler - '91 F-250
90 day: 22.06 mpg (US)
3800 Sunfire - '02 Sunfire
280 minute wait time!!!! WOAH
1991 F-250:
4.9L, Mazda 5 speed, 3.55 10.25" rear.
Old 08-07-2010, 09:47 AM   #6 (permalink)
The new results are the same as the old, leading me to believe I've reached the limits of what Flow Illustrator can do, alas.
One new bit of info however is that having no tailgate on at all seems to provide the least turbulence following the truck.
Honda IACV explained TomO Off-Topic Tech 10 11-25-2011 12:59 PM
Compression Test results questions. Verdann DIY / How-to 27 01-03-2011 10:35 PM
The Mechanism Behind Flow Separation LostCause Aerodynamics 46 07-15-2010 07:38 AM
Comparing Warm Air Intakes (WAI) & Cold Air Intakes (CAI) toomuch EcoModding Central 22 04-07-2009 09:30 PM
OEM Air Injection, Yay or nay? Dane-ger EcoModding Central 11 01-14-2008 10:05 AM
