RGB LCD for MPGuino
Hi all,
long-time lurker, finally pulled the trigger and got all the components to make an MPGuino. I'm using a freeduino board with an adafruit 16x2 RGB backlight negative LCD. While in the future I'd like to modify the code so I can change the colors using the buttons, right now I'm just trying to set it up to display orange. This only requires red and green light (in theory) so I hooked up the red cathode to Pin 10 on the board, and the green cathode to 11, as I was under the impression from the adafruit documentation that the cathodes needed to be wired to PWM pins. Is this necessary to have the LCD display in a solid color, or is it just for when making the LCD change colors intermittently? I added the following lines to my code: under //LCD Pins: #define RedPin 10 #define GreenPin 11 #define COMMON_ANODE under void setup(void): pinMode(RedPin,OUTPUT); pinMode(GreenPin,OUTPUT); setColor(83, 4); at the bottom: void setColor(int red, int green) { #ifdef COMMON_ANODE red = 255 - red; green = 255 - green; #endif analogWrite(RedPin, red); analogWrite(GreenPin, green); } How's my code look? I haven't hooked up to the VSS, inj, or +12V yet, currently I'm testing it through USB power. The problem I'm experiencing is the screen flashes brighter about 2 times per second. Can anybody help me troubleshoot this issue? Thanks :-) Edit: For clarification, my board is using an ATMega328 chip, and I believe I'm using an old version of the MPGuino software, as the main download link is down. I used an old archived MPGuino.pde file from Github that's dated June 2009, so I assume it's v0.82. If anybody has a link to where I could grab the v0.86 .pde file, I'd really appreciate it. |
My version of MPGuino supports the Adafruit RGB LCD module, right out of the box.
You can find it here -> http://ecomodder.com/forum/showthrea...ued-34733.html |
