Old 10-28-2008, 11:54 AM   #11 (permalink)
MechE
The Wagen - '00 Jetta GLS
90 day: 32.72 mpg (US)
Originally Posted by TestDrive View Post
Take a look at the figure in Step 1 of this article.
The image in the first post of this forum thread may also be useful.
So the wear I'm measuring on two of my tires is that of under inflation - just like this image, just not to the degree.
I might just bring it in for a 4 wheel alignment.
Challenge me, or correct me, but don't ask me to die quietly.
Old 10-28-2008, 12:59 PM   #12 (permalink)
MechE
Okay, so I found the problem... And it was an easy fix....
It was me :X
I remeasured, and noticed a chamfer on inside the tread valley (I guess to reduce stress concentration).... My caliper was resting on the chamfer, not completely seated in the valley... Measured from the center of the valley (not on the chamfer) - everything is nominal...
Side to Center to Side - everything is within a couple thousandths I'm good to go for another 25K miles, at high pressure and even wear
Sorry for the bad call Thanks for the help
Old 10-28-2008, 03:13 PM   #13 (permalink)
Turbo gas guzzler
grocery getter - '03 Evolution
90 day: 17.55 mpg (US)
In the immortal words of Homer Simpson "DOH!!!"
Old 10-28-2008, 04:56 PM   #14 (permalink)
WonderWagon - '94 Escort LX
Last 3: 51.52 mpg (US)
DaRedOne - '99 Escort ZX2 Hot
DaBluOne - '99 Escort SE
90 day: 48.97 mpg (US)
I'm guessing that by chamfer you mean the 2/32" high wear indicators molded into most tires.
(I believe US DOT requires them in passenger car tires.)
Example 1
from Tires, Page 3 of 4
Example 2
from Checking Your Tires for Wear - For Dummies
FWIW - I prefer a standard tread depth gage ($2-$3 from any auto parts store).
The compact design makes it easy to use in the wheel wells of most passenger cars.
Old 10-28-2008, 07:01 PM   #15 (permalink)
chop suey
Blue - '93 Tempo
ShWing! - '82 gold wing Interstate
F150 - '94 F150 XLT
Sport Coupe - '92 Tempo GL
Moon Unit - '98 Sable LX Wagon
"Boo Hoo to you everyone that said I'd wear out my centers at these pressures "
Well it looks like those pressures will work out for you. I do know, however, that I've had tires wear just like the "overinflation" pic in post 11. Vehicle was almost always very lightly loaded, and at max sidewall psi. Are tires different now? Were the rims too narrow for that tire? I dunno. But overinflation wear down the middle is not a myth.
Old 10-28-2008, 07:56 PM   #16 (permalink)
Yep, no myth. I've had tires wear like that to. I'd guess that old style, bias ply tires were more prone to that type of wear?
Old 10-29-2008, 12:13 AM   #17 (permalink)
papa smurf - '81 pickup 4wd dlx long bed 1/2 ton
90 day: 18.11 mpg (US)
Heep - '011 Grand cherokee Larado x
90 day: 19.31 mpg (US)
Da bike - '06 Shadow Vlx deluxe
90 day: 53.94 mpg (US)
i get digional wear heal toe.??
can u expain what u found?
2011 Jeep grandcherokee larado x v6 4x4. (wifes/weekender)
98 taco base 4x4 i4 toyota bought back due to a rust spot. gone but not forgotten.
81 toyota 4wd long bed 1/2 ton
Old 10-29-2008, 01:22 AM   #18 (permalink)
chop suey
Blue - '93 Tempo
F150 - '94 F150 XLT
They are, but these were radials.
Old 10-29-2008, 09:34 AM   #19 (permalink)
Big Blue - '06 Dakota Quad SLT
90 day: 20.36 mpg (US)
Miazda - '96 Miata mx-5
90 day: 44.14 mpg (US)
Diagonal wear is most likely a bearing or race.
Old 10-29-2008, 10:38 AM   #20 (permalink)
is diagonal like feathered? cause it is both front and even, it has done this for years.
Top 5 most fuel efficient tires (Lowest Rolling resistance: LRR) blackjackel General Efficiency Discussion 140 11-21-2011 10:13 AM
LR Horrible Tire Wear Noel Off-Topic Tech 3 06-03-2011 07:47 PM
Tire Engineer here - concerned about hyperinflating tires CapriRacer Introductions 48 09-26-2009 10:25 PM
Tire pressure (of winter tires) tasdrouille General Efficiency Discussion 20 08-12-2009 02:38 AM
Article: Green push hits tire makers MetroMPG General Efficiency Discussion 0 12-16-2007 08:14 PM
