Old 05-16-2008, 11:43 AM   #11 (permalink)
tasdrouille's Avatar
The Guzzler - '08 Hyundai Elantra GL
90 day: 33.12 mpg (US)
Got Soul? - '11 Kia Soul 2U
I am inclined to believe it's not just the flatness of the mooncaps, but the fact that they are isolating both sides of the wheel. I think that if you simply plug the holes in regular steelies you might get something.
Something interesting to note is that most of the flow hit the wheel on the inside as the flow under the vehicle is pushed diagonally to the sides. Who knows, maybe the mooncaps are actually on the wrong side of the wheel.
www.HyperKilometreur.com - Quand chaque goutte compte...
Old 05-16-2008, 01:54 PM   #12 (permalink)
Legend in my own mind
trikkonceptz's Avatar
Evil Pumpkin - '08 Scion xD RS 1.0 #1633
90 day: 35.45 mpg (US)
Silent Silver Killer - '10 Honda Insight EX
90 day: 51.5 mpg (US)
Here they are they are 16" x 6-1/2
Thx NoCO2; "The biggest FE mod you can make is to adjust the nut behind the wheel"
I am a precisional instrument of speed and aeromatics
If your knees bent in the opposite direction......what would a chair look like???
Old 05-16-2008, 03:55 PM   #13 (permalink)
rim aerodynamics
The partially dished wheel cover as created by MOON Equipment is accepted as the premier low drag wheel cover.The efficacy of such full wheel discs have been recognized since Lindberg's historic Atlantic flight in the famed Spirit of St.Louis,Ryan Flyer.I'll be posting data on them in an up-coming installment,however I can state with a high degree of confidence that they fair better than anything else ever tested.Every Land speed record car,and every economy champ use them.A single perforation,used for the valve stem,and for brake cooling,as used in the Renault Vesta II is a rational application for the work-a-day world.
5th generation civic hatchback - improving aerodynamics AndrewJ Aerodynamics 396 06-13-2022 01:51 PM
Aerodynamics Seminar #3 - by Phil Knox MetroMPG Aerodynamics 8 03-10-2021 10:17 AM
Aerodynamics Seminar #1 - by Phil Knox MetroMPG Aerodynamics 7 08-08-2012 06:00 PM
Aerodynamics Seminar # 5 - by Phil Knox MetroMPG Aerodynamics 4 01-29-2008 01:41 PM
Aerodynamics Seminar # 4 - by Phil Knox MetroMPG Aerodynamics 0 01-28-2008 08:36 PM
