Old 10-13-2008, 10:32 AM   #31 (permalink)
BBsGarage's Avatar
BBsRide - '06 Corolla CE
90 day: 31.64 mpg (US)
This is what mine looks like.
they helped slightly. coupled with your other mods it should be a nice addition.
Thanks.
Bill
SippingFuel
Check out BBsGarage
Picture ur Pet
Old 10-13-2008, 06:55 PM   #32 (permalink)
chuckm's Avatar
Exploder - '02 Explorer xlt
Rolla - '02 Corolla ce
90 day: 44.43 mpg (US)
BBsGarage,
Pretty slick looking. Is that flashing or mudflap or something else?
You got me thinking... if I use flashing, I can angle the exposed portion back toward the wheel.
"Jesus didn't bring 'Natty Lite' to the party. He brought the good stuff."
Old 07-21-2009, 10:49 PM   #33 (permalink)
chuckm's Avatar
Okay, after a long absence from modding, I've done a couple of items. First, I did change the upper grill block from duct tape to sheet metal. No big deal there, just smoother and a little better looking. Although I do think I may have to get a ecomodder decal to put in place of the Toyota badge. The other thing I did, just today, is attached a crude, two-piece, belly pan, attached with four zip-ties each.
It only goes back about a third of the way, just past the front wheel well. Thoughts?
Old 07-22-2009, 07:23 PM   #34 (permalink)
chuckm's Avatar
First day results were great. On my typical commute home, I'll get around 47mpg. This time, 49.4! The first 90 miles are showing 47.5mpg.
Old 07-25-2009, 02:14 PM   #35 (permalink)
rear spoiler
Originally Posted by chuckm View Post
OK, here's a profile picture of the corolla.
Like I mentioned, I am planning to cover the upper grill and most of the lower grill. Also, I'm going to add the belly pan, smooth hubs and rear wheel skirts (probably). I haven't decided on the front wheel skirts.
But I'm wondering, am I missing something?
Looking at your car from this view leads me to believe that a rear spoiler would help at highway speed.------------- If you can find a flat level spot to park the car,lay a straight edge across from your trunklid to the top of the car.------------------ If the angle,as measured from the horizon,is any steeper than say 13-degrees max.,then you probably have separated flow behind your roof which is not re-attaching ( like a Lancer).--------------- A simple bent sheetmetal spoiler,angled up no steeper than 30-degrees,and tall enough such that it just intersects,say a 12-13-degree line coming down off your roof,should get you flow re=attachment and lower drag.------------------------- Better to compare it to the streamlining template,as this would give you a more accurate appraisal.See Project" permanent Kammback for Metro" or "Aerodynamic Streamlining Template".
Old 07-27-2009, 07:34 AM   #36 (permalink)
chuckm's Avatar
Huh. Would never have guessed a spoiler would help. I'll look into it!
Old 07-28-2009, 07:08 PM   #37 (permalink)
chuckm's Avatar
Just had my best tank at 46.6. The belly pan rocks!
Testing the IAT mod tasdrouille General Efficiency Discussion 6 09-27-2009 04:09 PM
Looking for an "Aero Mod Materials" thread gascort Aerodynamics 7 05-06-2009 03:42 PM
Starting to Mod my Xfi bbjsw10 EcoModding Central 140 04-14-2009 07:27 AM
Change a thread title? wagonman76 Forum News & Feedback 3 06-27-2008 06:40 PM
