Old 05-27-2008, 08:49 PM   #1 (permalink)
stinky - '97 geo metro lsi
90 day: 44.71 mpg (US)
roller rockers
i was wondering if roller rockers would make a difference in my milage. i should lower friction like other motors.
Old 05-27-2008, 09:03 PM   #2 (permalink)
TheDon's Avatar
Pepper - '87 Mercedes Benz 300D
90 day: 30.42 mpg (US)
what whats?
Old 05-27-2008, 09:18 PM   #3 (permalink)
90 day: 52.71 mpg (US)
90 day: 70.75 mpg (US)
90 day: 52.48 mpg (US)
http://insightcentral.net/encyclopedia/envtece.html
In this system, the cam followers of the intake primary rocker arms are fitted with rollers that minimize friction on the cam's contact surfaces. (Each roller turns on a needle roller bearing.)
Honda uses them in the Insight engine (probably others.)
Old 05-27-2008, 09:23 PM   #4 (permalink)
So I should have added: I bet it would make a very small difference.
Old 05-27-2008, 09:31 PM   #5 (permalink)
Liberti
LostCause's Avatar
Thunderbird - '96 Ford Thunderbird
90 day: 27.75 mpg (US)
I also believe Honda uses them in the D15z1.
If you are going to install roller rockers, I would go all the way in reducing engine friction. Coat the skirts of your pistons with MoS2, size oil galleries, blueprint and balance the engine, etc. There are many gains to be had in the average engine.
- LostCause
Old 05-27-2008, 11:01 PM   #6 (permalink)
Recycling Nazi
Bror Jace's Avatar
Blue Bullet - '06 Honda Civic Sedan LX
90 day: 35.68 mpg (US)
Arrow
Yes, roller rockers are a very good idea ... but all by themselves, you probably won't notice any savings.
If you have a Geo Metro, and have a spare engine you are rebuilding, I would consider these as one of a few mods designed to maximize efficiency.
But as an after-market add-on to save $$$ and fuel? Nope, I wouldn't bother.
--- Bror Jace
Old 05-28-2008, 12:15 AM   #7 (permalink)
Of course, the real benefit of having roller rockers is being able to use a cam with steeper angles. See if you can find an aftermarket cam that offers a higher torque, lower peak rpm profile. If you're going to do one, it'd be a shame not to do the other. (but yes, will lower internal engine friction as well).
Old 05-28-2008, 08:40 PM   #8 (permalink)
Lurking EcoModder
Q1kS2k - '02 Honda S2000
F150 E - '13 FORD F150 XLT
WHITE CIVIC - '07 HONDA CIVIC LX
Try getting your internals coated with a dry film lubricant. I have read documentation of 68hp gains in a V8. Friction kills efficiency.
http://www.afterburnercoatings.com/i...d=30&Itemid=44
BTW I'm Chris, nice to meet everyone.
Old 05-29-2008, 08:06 PM   #9 (permalink)
Hi Chris,
Welcome to the place and enjoy your stay.
Cheers , Pete.
