Old 02-05-2010, 11:03 PM   #1 (permalink)
89HF's Avatar
MightyMouse - '89 CRX HF
90 day: 53.61 mpg (US)
rolling resistance and friction coefficient?
Somebody posted a method for estimating the rolling resistance of a tire in another thread but it didn't seem very user friendly. Does anyone know if there is a connection between a tire's rolling resistance and its friction coefficient?
Old 02-06-2010, 07:27 AM   #2 (permalink)
Tire Geek
CapriRacer's Avatar
Yes, and I've talked about it in detail here:
Barry's Tire Tech
Short version: There is technology triangle between Rolling Resistance, Traction, and Treadwear. In order to improve one, you have to sacrifice one of the other (or both).
Old 02-06-2010, 03:13 PM   #3 (permalink)
89HF's Avatar
thanks, at first glance, it looks like I can learn a few things from that link. However, since the friction coefficient of a tire is fairly easy to determine (by doing a drag test for example) is there any way to take that number and translate it into rolling resistance?
Old 02-06-2010, 04:32 PM   #4 (permalink)
ecomonkey
silver clown - '02 echo 2 door base
90 day: 45.91 mpg (US)
if you are looking at lrr tires, the rr is avialible on many tires,on the manufactures websites and other places.
Old 02-06-2010, 06:32 PM   #5 (permalink)
...beats walking...
Old Tele man's Avatar
Vibe - '09 Vibe Base (2ZR-FE)
90 day: 32.19 mpg (US)
Goldie Locks - '011 Cruze LTZ
90 day: 29.42 mpg (US)
...from the number crunching I did, that "flat" spot (contact patch) area on the bottom of the tire roughly equates to a 3% reduction in the mathematical radius of the tire.
...I got ~97% values for the 16" diameter Goodyear, Firestone/Bridgestone and Michelin tires that I analyzed.
...how'd I do it? Just backsolved from their posted tire-revolutions-per-mile against their published static (unloaded) tire diameters.
2011 Chevrolet Cruze LTZ 1.4LT 6A
2009 Pontiac Vibe 1.8L/SFI 4A
2004 Pontiac Vibe 1.8L/MFI 4A
2003 Ford Focus ZX5 2.0L/Zetec 4A
1971 Dodge Charger 318 3A
1970½ Plymouth AAR 'Cuda 340/6BBL 4M
1968 Dodge Charger 383 3A
1967 Plymouth Barracuda Formula S 383 4M
1965 Plymouth Barracuda Formula S 273 4M
Old 02-07-2010, 06:34 AM   #6 (permalink)
Tire Geek
CapriRacer's Avatar
No You have 3 variables and only one of them would be known.
List of aero mods you can do to your vehicle MetroMPG Aerodynamics 75 03-01-2012 07:28 PM
Calculating Rolling Resistance SVOboy EcoModding Central 2 02-15-2012 08:43 PM
Top 5 most fuel efficient tires (Lowest Rolling resistance: LRR) blackjackel General Efficiency Discussion 140 11-21-2011 09:13 AM
Discussion on tire efficiency Ernie Rogers General Efficiency Discussion 68 02-21-2010 08:45 PM
