Old 06-19-2009, 09:21 AM   #11 (permalink)
Daox's Paseo - '97 Paseo
Last 3: 53.99 mpg (US)
Daox's Prius - '04 Prius
90 day: 57.08 mpg (US)
CM400E - '81 CM400E
Does diesel flame speed slow down as it leans out similar to a gasoline engine?
Old 06-19-2009, 09:29 AM   #12 (permalink)
dcb
needs more cowbell
dcb's Avatar
pimp mobile - '81 gs 250 t
90 day: 96.29 mpg (US)
schnitzel - '01 Golf TDI
90 day: 53.56 mpg (US)
does diesel have a flame propagation front? Doesn't it all pretty much go spontaneously when ignited by pressure?
Old 06-19-2009, 09:47 AM   #13 (permalink)
CM400E - '81 CM400E
Good point dcb. Diesel experts?
Old 06-19-2009, 11:22 AM   #14 (permalink)
PaleMelanesian's Disciple
hummingbird's Avatar
City - '04 City iDSI EXi
90 day: 47.47 mpg (US)
But why are we discussing HHO without first challenging the "35-50% more efficient than gasoline engine" claim? Can we ask for specific reasons why this is possible with Scorpion? What are the energies involved in dissociation and recombination and how does it help up the efficiency THAT much? Or it is just a claim without substantiation, that has got a discussion jump-started here?
Old 06-19-2009, 11:28 AM   #15 (permalink)
Moderator
tasdrouille's Avatar
The Guzzler - '08 Elantra GL
90 day: 33.12 mpg (US)
Got Soul? - '011 Soul 2U
Diesel direct injection combustion is pretty complicated, and I don't understand it fully. The fuel starts to burn up as it exits the injector nozzle after a short ignition delay. So there's tiny burning fuel droplets swirling in the piston's bowl. When you add propane, which is injected upstream in the intake, you get an additional homogeneous mixture adding a whole new dimension to the combustion.
www.HyperKilometreur.com - Quand chaque goutte compte...
Old 06-19-2009, 02:12 PM   #16 (permalink)
Moderate your Moderation.
Herbie - '86 Golf Diesel
90 day: 51.89 mpg (US)
Diesels have injection throughout the powerstroke, the way I understand it, which is why they have so much more available torque. The "combustion" as it were, never occurs at one solid point in the piston's travel, only the ignition part of it.
In a properly tuned diesel, the AF ratio at almost any given moment (not counting moments before or after the one you're looking at) is lean. The overall combustion process, when measured on the exhaust stroke, shows "not-so-lean", but probably still not stoich.
IOW - Since the fuel is injected throughout the power stroke, from TDC to BDC (not really, but bare with me), and there is (let's say) 1L of air in the cylinder, considering stoich to be 15:1 (for easier figuring), there are now 1000mL of air, and to create a stoich mixture, you'd need 66.67mL of fuel.
So, now you take that 66.67mL of fuel, and inject it over the 90* of power stroke, and you end up with a mixture that starts out extremely lean, and as it burns up the air, it becomes less lean.
Assuming that fuel is injected from TDC to BDC (90*, but it's really not), that would be 66.7/90 = .75mL of fuel injected per degree of crankshaft rotation.
This results in the first degree of crankshaft rotation having a 750:1 AF ratio, and each subsequent degree being closer to stoich mixture, until the "total burn" AF ratio has become 15:1, as measured by the exhaust gasses.
Someone, please correct me if I'm wrong about this!
I'd like to think that people might open their eyes at some point... instead, I find it more and more likely that I'll just close mine.
-- Author kept secret.
Je ne veux pas d'une meilleure vie. Je veux être heureux avec celle que j'ai maintenant.
(I do not want a better life. I want to be happy with the one I have now.)
Old 06-19-2009, 02:20 PM   #17 (permalink)
Pokémoderator
cfg83's Avatar
1999 Saturn SW2 - '99 SW2 Wagon
90 day: 42.23 mpg (US)
hummingbird -
I think it's best to wait and see if the Scorpion makes it to market. We need to see someone driving it around and see what they say. It seems like their gizmo is way different than the homemade stuff. I think they are claiming that they are displacing 30%-40% of the gasoline fuel. This is a "supercar" implementation, i.e. Tesla for HHO. It wouldn't be cost-effective for the rest of us.
(just my opinion)
CarloSW2
American Solar Energy Society
Old 06-19-2009, 03:08 PM   #18 (permalink)
Lots of people are calling this a scam... google Ronn Motor Company, and one of the pre-filled suggestions is "scam".
Old 06-19-2009, 03:41 PM   #19 (permalink)
Moderator
Christ, that is right. It's not a bang, it's a burn throughout injection. Although generally the injection duration is only a couple crank angles. The more fuel you want to inject the longer the injection duration will be, as injection pressure and nozzle orifice size are fixed. That's why people end up putting larger nozzles to make more power, since they want all their fuel injected as close to TDC as possible, because late injection is inefficient and finish burning down in the exhaust (that's how the new CR TDI does it to burn off the DPF, late injection events, as the CR system has the capability to manage multiple injections events per cycle). I don't really see how varying AF ratio is relevant to the discussion though.
Old 06-19-2009, 04:06 PM   #20 (permalink)
Pokémoderator
cfg83's Avatar
Christ -
That's a totally valid POV. If the HHO doesn't pan out, I predict it will morph into a "traditional" supercar or never make it to market.
CarloSW2
HHO gas anyone? cerdmier EcoModding Central 4 03-28-2008 02:49 PM
