Old 01-29-2009, 01:50 AM   #21 (permalink)
Smile
Nice idea, this could be a new feature
Old 02-02-2010, 06:46 AM   #22 (permalink)
The backpack for cars
CARUX is the ultimate solution
Its better than the roof box because the CARUX is mounted behind the car and not like a roof box on the top, it does not create any additional drag and therefore no additional fuel costs.
Old 02-02-2010, 09:55 AM   #23 (permalink)
Quest for a 400 mile tank
mjboks's Avatar
Adventure Truck - '07 Tacoma Double cab V6 TRD 4wd offroad
90 day: 19.26 mpg (US)
Commuter Bicycle - '94 mountain bike
winkosmosis,no doubt,the boat will cause some interference over the roof.I do believe such a "roof rack" would however offer the minimum loss do to ,as you've mentioned,the narrow profile with very small frontal area,and drag coefficient on the order of Cd0.06.----------- The majority of the hull should see no separated flow for the entire length.------ Should the kayak be mounted on an inverted aerodynamic pylon as bombs and drop-tanks and bellytanks are done,there would be virtually no drag to speak of.No separation anyhow.---------- Some of my neighbors report that they lose "nothing" when they transport canoe and kayak on their roof.Some have actually claimed "gains."--------- I'm polite enough not to challenge their claims,and one day will test for myself,as I have both a canoe and kayak,but they usually ride inside the bed of the truck.
I'm hauling canoes, kayaks and bikes quite often on the top of my tacoma. I don't have any data to prove it but I would say if I'm only hauling a single canoe on top (upside down), I don't see much of a drop in FE. I wouldn't see any gain either though. I haul my kayaks in the vertical orientation (so I can fit 2-3 kayaks on top) and usually see a big drop in FE. My canoe however is probably the most aerodynamic (and light weight) part of the vehicle when on top.
How to reduce drag of surfboard roof racks? Palionu Aerodynamics 11 04-28-2012 02:15 PM
CdA list Daox Aerodynamics 106 03-30-2012 06:02 PM
Minivan Kardboard Kammback boosts MPG +3.7% (6.6%, counting roof rack delete) MetroMPG Aerodynamics 31 05-20-2010 12:23 PM
Sources of Aerodynamic Drag in Automobiles and Possible Solutions SVOboy Aerodynamics 12 02-17-2010 02:09 PM
Roof rack test: quantifying the aero penalty MetroMPG Aerodynamics 15 02-15-2010 03:21 PM
