Rootes(Commer) TS3 and similar engines
Not wanting to continue hijacking MorphDaCivic's Achates thread, I have started this one to discuss single-crankshaft, rocker-arm, opposed-piston engines. The best known of this type was the TS3 built by Rootes(Commer).
I will attempt to move relevant posts, or content thereof, from that thread as cleanly as possible. In the meantime, a quick internet search using the tags revealed two Achates patents on the subject, US9359896 and US20110186017, both dated 2010. Quoting the abstract from US9359896, "An opposed-piston engine with a single crankshaft has a rocker-type linkage coupling the crankshaft to the pistons that utilizes a rotatable pivot rocker arm with full-contact plain bearings. A rocker-type linkage utilizes a rotatable pivot bearing with an eccentric aspect to vary translation of piston linkage along the axial direction of a cylinder, which shifts the top dead center (TDC) and bottom dead center (BDC) locations of a piston so as to change the volume of charge air compressed during the power stroke." There are other related Achates patents. They also cited in their prior art a patent by George Henry Enderby, GB183501 (A), dated 1922-08-01. This is the oldest patent on the subject that I have located thus far, though I seem to remember a drawing going back as far as about 1900. |
My only experience with opposed piston engines is with the Rolls Royce K60 engine in a FV 432 APC. It does have two crankshafts and six cylinders, so its not quite the same as your rocker arm engine.
It chooched when I pressed the go pedal, and it sounded pretty normal to me. ;) Don't know what else to say. |
Here are relevant posts (with some editing) from " New Boxer Engine Pickup get 37 MPG":
It's quite surprising to figure out that even Achates has some patents related to this design. Well, even though the dual-crankshaft design may work well and eventually be easier to increase the stroke, I must confess I'd still feel more comfortable dealing with a single-crankshaft engine...
Achates' current focus may be based on its affiliation with Fairbanks-Morse and Cummins.
Fairbanks-Morse is familiar with, and known for, the dual-crankshaft design and would be interested in a downsized model for truck use. It was a (supposedly inferior) Cummins engine that replaced the TS3. Institutional prejudices can linger for decades. I am not sure Cummins would like to be responsible for the rebirth of the TS3, 50 years after destroying it. I would guess that Achates has done research and testing on a number of historically viable opposed-piston designs, to see how much they could be improved by applying current technology. Securing patents for these improvements, tested or not, can (assuming the ideas are sound) have the effect of controlling entry into the opposed-piston market. They may have even bought, or made a bid for, the OPOC patents last year. |
It was actually Chrysler that purchased Rootes, beginning in 1967. They had just spent a sizeable amount of money developing a diesel engine with Cummins (who bought Perkins from Chrysler in 1964), so the first thing they did was shut down production of the TS3, destroyed most of the prototypes of the TS4, destroyed the drawings and disbanded the engine design team. They sold what was left of Rootes to Renault and Peugeot by 1978. Chrysler got its comeuppance during the Daimler-Benz merger.
For some excellent articles on opposed piston engines, I recommend reviewing this section at the Achates website (while it lasts):
Viewpoints - Achates They also recommend this publication: Opposed Piston Engines – Evolution, Use and Future Applications, by Martin Flint and Jean-Pierre Pirault. |
Opposed-piston engines are likely to make a comeback, now that Cummins is taking it seriously. I'm sure a civilian derivative of the ACE would easily find its way among the truck market.
https://www.dieselarmy.com/news/cumm...tons-per-hole/ |
Thanks for the information. I had been keeping an eye on Achates' progress, but not a close eye. It is about time one of these good ideas finally makes its way into production.
I still suspect there may be an advantage to the single-crankshaft design within a particular range of engine sizes. I was going to mention earlier that perhaps at least some of the picturesque, orange wooden fishing boats at Mar del Plata in Argentina may still be powered by Rootes-Lister TS3 marine engines. I don't know if it would be worth the trip to go see them, but if you do, check if any are still around, and accessible, before you go. |
