Old 08-15-2012, 10:34 AM   #1 (permalink)
Altima SE - '07 Nissan Altima 3.5 SE
90 day: 22.72 mpg (US)
RSX-S - '02 Acura RSX Type S
90 day: 29.76 mpg (US)
Igloo - '07 Nissan Quest SL
90 day: 17.5 mpg (US)
Send a message via AIM to 99clipsgst
RSX front belly pan
To date my only eco mods on my RSX type S is max tire PSI and an Ultra Guage. The newest mod I have done is extended the stock belly pan.
Here is the before.
The After.
I have used 1 tank of gas and got 29.54 mpg but it has been raining pretty hard the last week so I will have to do a few more tanks to get a feel for the results.
Old 08-15-2012, 12:36 PM   #2 (permalink)
Lafawnda - '01 Honda CBR600 F4i
Big Yeller - '98 Dodge Ram 2500 base
Prius Plug-in - '12 Toyota Prius Plug-in
90 day: 57.64 mpg (US)
Mazda CX-5 - '17 Mazda CX-5 Touring
90 day: 26.68 mpg (US)
Your photos aren't showing up.
Seems you are getting the same mpg as my TSX... I had considered the RSX when I was in the market for a car. I believe there are more mods available for the car. There are no turbo kits for the TSX, for example. The gearing is a little taller too I think.
I'm thinking about doing a belly pan on the TSX, but really it just needs taller gears to be efficient. 3000RPM at 70MPH is way too high.
Old 08-15-2012, 01:38 PM   #3 (permalink)
Hopefully the pics work now.
Before.
After.
As for the gearing here is yours vs mine.
Gear 02 RSX 04-08 TSX
1 3.266 3.266
2 2.13 1.88
3 1.517 1.355
4 1.147 1.028
5 0.921 0.825
6 0.738 0.659
final 4.389 4.764
Old 08-15-2012, 01:45 PM   #4 (permalink)
Prophecy99's Avatar
Maxima - '02 Nissan Maxima GLE
looks good OP.
That is high, I am about 2400-2500 RPM around 71 MPH on my V6 nissan.
i have advanced timing but im not sure if that effects that.
Old 08-16-2012, 07:18 AM   #5 (permalink)
What RPM are you at when traveling 70mph? I've considered swapping in an RSX final drive, but I believe that will only drop my RPM by 8%. I'd still be doing 2700 RPM at 70, which still might be worth the hassle. I'm on the fence.
Old 08-16-2012, 08:30 AM   #6 (permalink)
Prophecy99's Avatar
99clipsgst are you going to do an rear diffuser/paneling ?
I am in the process of finishing my rear diffuser.
Old 08-16-2012, 06:18 PM   #7 (permalink)
I'm not sure if I will do a rear cover. They seem to be harder to make so they don't turn into a big parachute.
