Old 10-02-2009, 04:09 AM   #11 (permalink)
Chug - '96 Polo CL
90 day: 49.42 mpg (US)
Front toe helps with turn-in, rear toe helps keep the car stable at speed. easy rule of thumb I was told back in my race days
-ve rear toe (front inner edge closer together than rear) = more stability in straight line, can help reduce mid corner and lift-off o/steer
+ve rear toe = more rearpost weight transfer turn ability.
The alignment was done by the bloke at the local shop and I helped out 'cos he was using a mirror gauge similiar to what I used to used on race cars. The car still feels very secure at highway speeds (65-70) and is still fun 'maintaining momentum' on back roads
good things come to those who wait, sh*t turns up pretty much instantly
twitter.com/bertchalmers
The Following User Says Thank You to robchalmers For This Useful Post:
MetroMPG (10-06-2009)
Old 10-04-2009, 06:19 PM   #12 (permalink)
Chug - '96 Polo CL
1st tank sole on new alignment 43MPG !!!!!! another 4.9% increase!!! and I've ticked over my 50mpgUK target!!!
Old 10-04-2009, 11:39 PM   #13 (permalink)
mwebb's Avatar
1996 geo metro - '96 metro base
mwebb: did you set the toe yourself or have a shop do it?
i set the toe myself , using a hunter g111 at my shop
Old 10-06-2009, 11:26 AM   #14 (permalink)
Blackfly - '98 Metro
90 day: 67.07 mpg (US)
ForkenSwift - '92 Metro EV
90 day: 125.37 mpg (US)
U.F.O. - '00 Insight
90 day: 85.75 mpg (US)
Just did a quick calc to determine how accurate the measuring-tape-across-the-treads method of checking alignment specs for my car would be:
With my 155/80 r13 tires, the outer diameter is 22.76 inches / 578.2 mm, and a 1 degree toe angle equates to a 5 mm or 0.2 inch difference at the tread. That's coarser than I would have guessed, so probably worth a check.
The larger your tires' outer diameter, the more potential accuracy in the measuring tape quick check.
Old 10-06-2009, 03:18 PM   #15 (permalink)
...beats walking...
Old Tele man's Avatar
Vibe - '09 Vibe Base (2ZR-FE)
90 day: 32.19 mpg (US)
Goldie Locks - '011 Cruze LTZ
90 day: 29.42 mpg (US)
...I can remember alignment shops that had a pair of saw-tooth edged bars sticking up through a plate on the ground that you'd drive over, which moved a scale that they read to indicate whether and how much your front wheel toe-in/out was.
...don't recall anybody actually worrying about rear wheel toe until VW's and Corvairs came around.
2011 Chevrolet Cruze LTZ 1.4LT 6A
2009 Pontiac Vibe 1.8L/SFI 4A
2004 Pontiac Vibe 1.8L/MFI 4A
2003 Ford Focus ZX5 2.0L/Zetec 4A
1971 Dodge Charger 318 3A
1970½ Plymouth AAR 'Cuda 340/6BBL 4M
1968 Dodge Charger 383 3A
1967 Plymouth Barracuda Formula S 383 4M
1965 Plymouth Barracuda Formula S 273 4M
Rubber ground skirt hypermiler01 Aerodynamics 13 05-21-2011 07:21 AM
DIY Rubber Front Wheel Skirts newtonsfirstlaw DIY / How-to 32 05-19-2011 07:45 AM
Discussion on tire efficiency Ernie Rogers General Efficiency Discussion 68 02-21-2010 08:45 PM
Norm's EV3 burns rubber bennelson Fossil Fuel Free 3 04-11-2009 08:30 PM
Rear Parachute NewBModder EcoModding Central 8 09-17-2008 06:42 PM
