Old 09-14-2016, 01:32 PM   #1 (permalink)
Tealo - '91 Honda Civic DX
90 day: 34.88 mpg (US)
Tire size confusion
So I've realized that the tires on my car are not stock size which would mean my speedometer and odometer readings are slightly off.
My car's stock tires would be 175/70R13 and the ones on my car are 195/60R14.
When I plug those numbers into this site it says when the speedo says 100 I'm actually going 102.5.
However, when I use the calculator on this site it says when the speedo says 100 I'm actually going 97.56.
Not sure why I'm getting different numbers here. Any help would be appreciated, thanks!
Old 09-14-2016, 02:28 PM   #2 (permalink)
Red Light Avoider
pletby's Avatar
My Civic - '00 Honda Civic DX
90 day: 46 mpg (US)
If you have a GPS or even a cell phone with GPS you can set your cruise at 100km/hr and read how fast you are really going then apply the correction to your speedometer.
As a strange sidebar my speedometer is optimistic by around 4km/hr, but when I read the speed off my Ultragauge accessing my car's computer it matches the GPS exactly. Weird eh?
I'm not an expert on reading tire sizes, someone else will chime in I'm sure.
Old 09-14-2016, 02:52 PM   #3 (permalink)
Karmann Eclectric
jray3's Avatar
Odysseus - '00 Honda Odyssey
MR BEAN - '12 Mitsubishi i-MiEV SE
Karmann Eclectric - '71 VW Karmann Ghia Electric Conversion
BOB - '87 Ford 250 Lariat ext cab
Honda speedo= wierdo
I've seen bad speedometer readings on two hondas now (with stock size tires). My Odyssey reads 4-5 mph high at highway speed, but the odometer and OBD readouts are spot on, whether counting mile markers or using GPS.
2012 Mitsubishi i-MiEV, 112 MPGe
2000 Honda Odyssey
1987 F250 Diesel, 6.9L IDI, goes on anything greasy
1983 Grumman Kurbwatt, 170 kW "Gone Postal" twin
1983 Mazda RX-7 electric, 48 kW car show cruiser
1971 VW Karmann Ghia electric, 300 kW tire-smoker
1965 VW Karmann Ghia cabriolet, 1600cc
Have driven over 100,000 all-electric miles!
Old 09-14-2016, 03:10 PM   #4 (permalink)
vskid3's Avatar
Civic DX (sold) - '97 Honda Civic DX
90 day: 34.15 mpg (US)
GTO (sold) - '04 Pontiac GTO
90 day: 22.62 mpg (US)
Green Brick (sold) - '06 Ford Escape Hybrid
90 day: 31.93 mpg (US)
I think your issue is that the two sites compare things backwards from each other. Your second site is actually saying that when your speed is 100, your speedo will say 97.56. The tire you're running is a little bigger, so you'll go farther for each revolution compared to the stock size. That means your speedo will read lower than actual (or at least lower than it would read compared to the stock tires). GPS is the way to go, especially to check the odometer (more important for MPG calculation).
A lot of cars will read a little high on the speedometer, but the odometer and speed from the OBD-II port are right on. Supposedly it's so you can't blame the manufacturer if you get caught speeding.
Camry Thread
E-Bike Thread
Old 09-14-2016, 03:24 PM   #5 (permalink)
darcane's Avatar
Both answers are identical, just inverted in how they are displayed... change the order you plug them in and you will get the same numbers.
Ignore the numbers for a moment. Your current tires are taller than stock. Because of that, you are going faster than you would be going with the stock tires.
Past Cars:
2001 Civic HX Mods
CTS-V
2003 Silverado Mods
Old 09-14-2016, 03:30 PM   #6 (permalink)
iveyjh's Avatar
none - '98 Honda Civic HX
none - '00 Chevy (Geo) Metro base
none - '00 Saturn SL1 base
The second one is correct, all things considered.
Old 09-14-2016, 04:38 PM   #7 (permalink)
Thanks everyone. So does that mean I can just multiply the odometer by 2.5% for correct readings?
I'll try downloading an app to check my gauges with as well.
Old 09-14-2016, 09:47 PM   #8 (permalink)
Aero Deshi
ChazInMT's Avatar
MagMetalCivic - '04 Honda Civic Sedan EX
Last 3: 34.25 mpg (US)
I have noticed that tires of the same size by differing makes have slightly different diameters when I shop on Tire Rack.I ALWAYS use Tire Rack as a guide for the tires I'm going to buy for my cars since 1992 or so to get the best price. When they started putting performance and review ratings up it is just an amazing site to find the best value. I would never have bought General tires were it not for them.
Old 09-14-2016, 09:54 PM   #9 (permalink)
Ok so I ran a GPS speedometer app on my way home today. The second site appears to be right while the speedometer says 100 the app was saying around 97.5 km/h.
I reset the tripmeter and the car says 38.7 while the app reports 38.67, so almost bang on.
