Old 05-17-2010, 03:10 PM   #11 (permalink)
Originally Posted by bgd73 View Post
warm the carb somehow, leave fuel alone til last second before engine..heat riser ideas galore.
Of course, if you warm the carb, then you warm the fuel and lose some to evaporation. I think he means that you should warm the intake air (plenty of other threads on that regarding how-to and how warm to get it.)
Old 05-17-2010, 03:17 PM   #12 (permalink)
Left Lane Ecodriver
RobertSmalls's Avatar
Zombie Insight - '00 Insight MT
90 day: 62.82 mpg (US)
That's a good point. Fuel and air are mixed at a ratio of 15:1 by MASS, so heating your air charge will be ~15 times as effective as heating your fuel, and far less risky.
Old 05-17-2010, 11:16 PM   #13 (permalink)
the radiator is in use when thermostat is open. That means engine is full warm on the cold fuel..before warming the fuel. This is silly....I hope you see why.
toyota 22r...the tank is soft mounted. I can see why you would want to make a quest to make it lively (warm)... I am on this gas subject recently with an old subaru welded into crazy strong.. the hard mounted tank needs to be urethan strapped to calm down hard resonance (way to active...proof in the venting) warm the carb somehow, leave fuel alone til last second before engine..heat riser ideas galore.
ALL your gibberish is "silly... i hope YOU see why."
Old 05-18-2010, 12:24 AM   #14 (permalink)
ooo ooo ooo ah ah ah
Blue - '93 Tempo
ShWing! - '82 gold wing Interstate
F150 - '94 F150 XLT
Sport Coupe - '92 Tempo GL
Moon Unit - '98 Sable LX Wagon
WTH??? Hasn't this been discussed/played with/debunked about 1000 times over already?
I want to get to the bottom of this ethanol killing my mpg Nerys General Efficiency Discussion 172 07-20-2010 01:06 AM
Priorities: RPMs vs VAC luvit Instrumentation 47 02-05-2010 08:36 AM
Restricted fuel system affect mpguino readings? wagonman76 OpenGauge / MPGuino FE computer 1 09-09-2008 01:34 PM
Yikes! I've become a fuel saving nerd! metromizer Introductions 9 06-06-2008 10:19 AM
Basic EcoDriving Techniques and Instrumentation SVOboy Instrumentation 2 11-17-2007 11:38 AM
