Old 09-29-2010, 07:59 PM   #1 (permalink)
Pacifica - '06 Pacifica Touring
90 day: 22.74 mpg (US)
Running rich after cold starts.
I have a 2006 Pacifica with 63k miles. The exhaust smells like gas after a cold start.
Anyone have any suggestions for what I should check? O2 Sensor? Leaking injector?
Maybe its normal? It makes me cringe knowing I am running rich and wasting gas.
Old 09-29-2010, 10:07 PM   #2 (permalink)
...beats walking...
Old Tele man's Avatar
Vibe - '09 Vibe Base (2ZR-FE)
90 day: 32.19 mpg (US)
Goldie Locks - '011 Cruze LTZ
90 day: 29.42 mpg (US)
..."how long" does the gasoline 'smell' persist after those cold starts? A couple of minutes or what?
Old 09-29-2010, 10:11 PM   #3 (permalink)
1 minute, maybe 2? I will have to start it and then time it...
Is that normal?
Old 09-29-2010, 11:45 PM   #4 (permalink)
...beats walking...
...todays engines 'start' in "open-loop' (no computer control) which CAN be too rich, but should become "normal" as soon as the engine warms up enough for the computer to go into "closed-loop" control, usually within 1-3 minutes or sooner if being driven (loaded).
...is there a "puff" of black smoke during start-up, too? That, typically, should not occur.
Old 09-30-2010, 01:44 PM   #5 (permalink)
Daox's Paseo - '97 Paseo
Last 3: 53.99 mpg (US)
Daox's Prius - '04 Prius
90 day: 54.91 mpg (US)
CM400E - '81 CM400E
Don't sit there and idle your car. Start and drive!
Old 09-30-2010, 11:23 PM   #6 (permalink)
Intermediate EcoDriver
Mustang Dave's Avatar
White Pony - '07 Mustang V6 Premium Coupe
Team Ford
90 day: 29.98 mpg (US)
Big Red - '89 F-250 4WD Custom
90 day: 15.54 mpg (US)
Yeah, what Daox said. I can't believe how many co-workers will sit in their cars eating their lunch with the engine idling to power the air conditioning. And they complain about their bad fuel economy!
Fuel economy is nice, but sometimes I just gotta put the spurs to my pony!
Originally Posted by thatguitarguy View Post
Just 'cuz you can't do it, don't mean it can't be done...
Old 10-01-2010, 05:15 AM   #7 (permalink)
Wiki Writer
bugler - '91 626
90 day: 35.89 mpg (US)
If you are running rich (by design) at cold start you can "fix" this by putting an appropriate resistance on the MAF (mass air flow) sensor signal which will make your car leaner when the car isn't in open loop.
Old 10-01-2010, 09:52 AM   #8 (permalink)
I usually sit for 10-15 seconds and then go. I give it just enough time for the rpms to drop.
I am not sure I want to lean out the motor. I still owe money for this vehicle.
Old 10-01-2010, 11:11 AM   #9 (permalink)
Ryland's Avatar
honda cb125 - '74 CB 125 S1
90 day: 79.71 mpg (US)
green wedge - '81 Commuti-Car
Blue VX - '93 Civic VX
putting a load on the engine is going to warm it up faster, so it will go in to closed loop sooner, idling your engine will put more wear on it, you should be ready to drive before you even start your vehicle, seat belt should be buckled, mirror adjusted.
I coast down my drive way and pop the clutch at the bottom so my car is moving before it ever starts, 208,000 miles and the engine is in perfect condition.
How to: reduce the rich condition of a cold start. C3H8 EcoModding Central 69 09-10-2010 03:53 PM
VX swap running bad. Carwhisperer EcoModding Central 0 09-03-2010 03:44 PM
Electronic Engine Control Algorithm. Is this Correct? worstmechanic EcoModding Central 7 01-08-2010 06:18 PM
Need help running rich! Curly1 General Efficiency Discussion 12 07-19-2009 08:39 AM
Comparing Warm Air Intakes (WAI) & Cold Air Intakes (CAI) toomuch EcoModding Central 22 04-07-2009 09:30 PM
