Old 02-23-2009, 02:05 PM   #11 (permalink)
I wonder how the selector for reverse differs from those for 1st and 2nd? It may be possible that you were somehow trying to select two gears at once. That's an excellent way to lock up a transmission solid, for as long as both gears are selected. In fact, it's an old trick to be able to remove nuts and bolts from the guts of a transmission without the gears and such spinning on you...
-soD
Old 02-24-2009, 05:25 PM   #12 (permalink)
Idiot Suv?? Sav?? Sev?? S
metroschultz's Avatar
SuperElasticBubblePlastic - '93 Metro plainjane
90 day: 53.91 mpg (US)
SilverHairBeauty - '01 Avalon XL
90 day: 24.06 mpg (US)
Send a message via AIM to metroschultz
Possible, though not Probable
The S10 trans is a toploader (The gearshift goes into the trans from the top and there is no external linkage to bind up)
The selector for reverse is also the selector for 5th.
when you pull into reverse you are moving a lever all by itself in the side of the trans. moving a gear (not a synchro) on a counter shaft.
To go to 1st from there you are moving across two open dogs and pushing a rod backward (yeah it seems different) for the 1st gear synchro and fork.
It is possible to get between the dogs and push 1st and 3rd at the same time but usually that creates too much resistance on your shifter so you will pull back and try again. If you did get 1st and 3rd at the same time the car would
TOTALLY
be locked and immovable. If this happens again you may have a problem that needs attention.
But I am going with the frozen brakes theory.
If you hit 2 gears at once. 1 time, it will happen again and again and again and again and again.......
You can turn painful situations around through laughter. If you can find humor in anything - even poverty - you can survive it. Bill Cosby
Old 02-27-2009, 10:27 AM   #13 (permalink)
Wicked Wanda - '99 Beetle GLS
90 day: 29.59 mpg (US)
Green Monster - '99 Explorer Sport
90 day: 16.73 mpg (US)
Dad's Taxi - '99 Odyssey EX
90 day: 24.23 mpg (US)
I've had this problem several times over the years with parking brakes on rear drum brake cars. Unless I was parked on I hill I wouldn't use the parking brake in the winter.
EV S10 project budget forcast? MazdaMatt Fossil Fuel Free 13 01-24-2009 01:24 AM
S10 radiator fan changes? bennelson EcoModding Central 29 12-29-2008 07:54 PM
Worth changing gears to imporve Fuel Economy? 2000mustang fan EcoModding Central 33 07-22-2008 08:31 PM
