Old 01-15-2015, 05:49 PM   #1 (permalink)
betasniper's Avatar
Red - '01 Honda Insight CVT
Gen-1 Insights
House of Tudor
90 day: 59.17 mpg (US)
Civic Hybrid - '12 Honda Civic Hybrid
Bahamut - '18 Chevrolet Volt LT
Team Volt
Plug-in Hybrids
Saturn Problems!?!
Hello, the saturn has recently been getting worse and worse fuel economy as you can see from my fuel logs. I also noticed that it has less acceleration than it used to at the same MAP level (as monitored by a vacuum gauge). I did a compression test and the pressures have seemed to be higher than what they used to be but I didn't think that would cause worse economy. I did however notice some black stuff on the piston faces when looking in the spark holes. Maybe that is the cause? I read that you could clean the pistons with GM Piston Ring Cleaner. I also noticed the car doesn't coast as well as it used to. Anyway I would appreciate any advice you guys give.
Thanks!
*Less power for MAP reading
*Higher compression test (black piston coating)
*Car doesn't coast as it used to
: Brothers
: Dad's
Old 01-15-2015, 10:14 PM   #2 (permalink)
herp derp Apprentice
Saturn-sold - '99 saturn sc1
Team Saturn
90 day: 28.28 mpg (US)
Yukon - '03 GMC Yukon Denali
90 day: 13.74 mpg (US)
I'd concentrate on finding the cause of the reduced coasting. The extra drag on the car would make it feel like it's making less power than expected. The extra load might cause the engine to run richer than usual, creating the extra carbon / soot that you've seen... But I wouldn't read into that too much, wouldn't surprise me if it might be normal, this is just a reason you decided to look where you did.
Might start by jacking up the wheels, and checking for one that takes excessive effort to rotate
Old 01-16-2015, 04:26 AM   #3 (permalink)
Check the engine timing as well. Wouldn't affect coasting; but, would affect mileage.
Old 01-17-2015, 03:20 PM   #4 (permalink)
betasniper's Avatar
Gen-1 Insights
House of Tudor
Team Volt
Plug-in Hybrids
Timing has never been changed since we originally purchased the car. We are the original owners and I don't believe the engine has ever been apart.
The back wheels spin very freely. Spin times more than 5 sec.
The front wheels dont spin for half a second. Not hard to spin but they dont spin long. Spin better in neutral than park. (both wheels up)
: Brothers
: Dad's
Old 01-17-2015, 09:58 PM   #5 (permalink)
Do a tune up--change the plugs, the wires, the cap and rotor (if any), change the fluids and filters. Check the tire pressures and fill to max.
Cover the basics first.
-soD
Old 01-17-2015, 11:57 PM   #6 (permalink)
Team Saturn
How big of a temperature change do you get with the seasons there? Looks like you're down to where you were, at around the same time last year
Old 01-19-2015, 04:00 PM   #7 (permalink)
The S - '99 Saturn SC2
Team Saturn
Head over to saturnfans.com and post in the S series forum, tons of helpful Saturn people over there. Also, has the ECTS ever been changed?
The Following User Says Thank You to ninetynineSC2 For This Useful Post:
War_Wagon (01-21-2015)
Old 01-19-2015, 04:48 PM   #8 (permalink)
Spaced out...
spacemanspif's Avatar
The New Focus - '07 Ford Focus ZX5
90 day: 32.44 mpg (US)
Sounds like dragging brakes. Check the calipers and maybe pull the slide pins and re lube them to make sure the calipers are floating freely. Saturnfans recommends syl-Glyde from NAPA as it won't cause the slide pin boots to swell and reduce pin float. Those cars like to have pins bend a little too and make the calipers go cock-eyed so check pad wear as well.
-Mike
2007 Ford Focus ZX5 - 91k - SGII, pending upper and lower grill bocks - auto trans
1987 Monte Carlo SS - 5.3/4L80E swap - 13.67 @ 106
2007 Ford Focus Estate - 230k - 33mpg - Retired 4/2018
1995 Saturn SL2 - 256K miles - 44mpg - Retired 9/2014
Cost to Operate Spreadsheet for "The New Focus"
Old 01-21-2015, 09:00 AM   #9 (permalink)
basjoos's Avatar
Aerocivic - '92 Honda Civic CX
Last 3: 70.54 mpg (US)
AerocivicLB - '92 Honda Civic CX
90 day: 55.14 mpg (US)
Camryglide - '20 Toyota Camry hybrid LE
90 day: 62.77 mpg (US)
A quick test for dragging brakes is to take your hand and feel the temperature of each wheel after you have been driving at speed for a while. Dragging brakes produce heat, so if one wheel is hotter than the others, you have either a dragging brake or a bad wheel bearing problem.
aerocivic.com
Old 01-21-2015, 06:42 PM   #10 (permalink)
5 Gears of Fury
War_Wagon's Avatar
Spunky - '90 Honda Civic CX
90 day: 35.56 mpg (US)
That'd be my guess too. My '98 started getting worse and worse mileage, and getting really hard to start. Had the original ECTS in it, which had cracked. Changed it myself in an hour or so and for $12 it solved all my problems.
"Don't look for one place to lose 100 pounds, look for 1600 places to lose an ounce." - Tony DeFeo
