Old 07-29-2008, 10:15 AM   #21 (permalink)
Sandstone Princess - '99 Sububan LT
90 day: 21.04 mpg (US)
Joe - '02 sentra XE
90 day: 43.9 mpg (US)
Regal - '03 Regal LS
90 day: 33.85 mpg (US)
Does anybody know of 5th gear changes or parts that would be availalbe for a 2002 nissan sentra XE, 5spd 1.8 base model. Yes, I just picked it up to allow the semi-retirement of the suburban
I asked in some other forums and nobody had a clue.
Old 07-29-2008, 10:50 AM   #22 (permalink)
lovemysan's Avatar
gutless wonder - '02 sl sohc
90 day: 40.17 mpg (US)
econoburban - '05 surburban 2wd LT
90 day: 19.43 mpg (US)
Cfg83, looking at the BFSC map it appears to me that the sweet spot is around 70 mph/2500 rpm. Which is nearly identical to a sohc, peak torque for me is 2400rpms, 114lb ft. I've read in the past that that the dohc makes within 3lb of the sohc until after 3500 rpm.
2002 Saturn SL
sohc + 5spd = 50mpg
mod pics see link below
http://s75.photobucket.com/albums/i3...emysan/saturn/
Real men have wheel skirts.
Old 07-29-2008, 02:29 PM   #23 (permalink)
Pokémoderator
cfg83's Avatar
1999 Saturn SW2 - '99 SW2 Wagon
90 day: 43.46 mpg (US)
lovemysan -
Ok. Traffic willing, I'll give that a try on the to/from leg to work today and see what happens. Considering that I never touch 3000 RPMs on my commute, it's nice to think I might have a "stealth-SOHC" in my SW2.
CarloSW2
American Solar Energy Society
Old 07-29-2008, 02:36 PM   #24 (permalink)
lovemysan's Avatar
CFG I was merely stating that from a BSFC eff standpoint 70mph is best. However I find that 38mph is best for maximum eff. LOL. You should be able to hit 43-44mpg at 70 though. Of course there are a lot of different variables here that I don't understand how to compute.
2002 Saturn SL
sohc + 5spd = 50mpg
Old 07-29-2008, 04:55 PM   #25 (permalink)
Pokémoderator
cfg83's Avatar
Dust -
Originally Posted by Dust View Post
Did the Cruise control ever get sorted out?
No, I stopped working on it. I will post a separate thread on this so you can see where I left off. I may never fix it because I have a vague plan to reuse the cruise control buttons for something else. For instance, I think it would be neat to turn it a control for a fuel injector cutoff.
CarloSW2
Old 07-29-2008, 07:05 PM   #26 (permalink)
Pokémoderator
cfg83's Avatar
lovemysan -
Ok. I did it for fun anyway. I couldn't get up to 70 MPH average because of traffic. Instead, it's just a +12 MPH Average comparison. Here are the results :
ROUTE : 10 West -> 710 South -> 105 West -> 405 South -> Exit Freeway => Roughly 27+ miles
SCANGUAGE "CURRENT" Readings :
Code:
                   SLOW     FAST
MPG            :   61.2     45.8
Gallons        :    0.4      0.6
Water Temp Max :  200.0    204.0
Miles          :   27.5     27.7
RPM Max        : 2135.0   2572.0
Hours          :    0.6      0.4
MPH Max        :   58.0     74.0
MPH AVG        :   45.0     57.0
WEATHER(.com) :
Code:
Degrees F      : 77.00      76.00
Humidity (%)   : 27.00      59.00
Dew Point (F)  : 36.50      60.00
in. Pressure   : 30.09      30.01
The problem (in my mind) is the difference in the humidity. Otherwise, these two express a decent comparison.
CarloSW2
Old 08-12-2008, 08:53 PM   #27 (permalink)
FumeSniffer
cookie96civic's Avatar
FumeSniffer - '96 Civic DX
90 day: 46.19 mpg (US)
Big Gulp - '06 8600-375 Twin Turbo
90 day: 7.15 mpg (US)
RPM too low???
I'm not dead sure, but i think my civic dx is around 3000 @ 60-65, with only 100hp. My question is my new Nissan Quest runs 2200 @ 80mph and around 1600 @ 60. Is this lugging the engine? Or will it downshift before enough lugging occurs. (5spd auto). I guess it has a little more torque (255) than the civic too, maybe that helps.
Old 08-12-2008, 09:34 PM   #28 (permalink)
Boxhead
whokilledthejams's Avatar
Boxy Brown - '04 xB
90 day: 35.78 mpg (US)
Send a message via AIM to whokilledthejams
You're not lugging. Generally, engines that make a lot of their torque at low rpms can be geared to run like that at highway speeds, because they remain driveable to the average person. Essentially, the gearing is chosen so that passing in-gear isn't a trial of patience.
Admittedly, while everyone here would like a top gear tall enough to run a flying mile on the salt flats, most people want to be able to accelerate at a pace quicker than 'glacial.' Hence, at 80mph, my xB is running at something like 4200rpm. Bigger engines tend to make a lot more torque at lower rpms, so they can be geared much taller without impacting performance. The upside is better fuel economy than if shorter gears were chosen.
Old 08-13-2008, 11:54 AM   #29 (permalink)
Blackfly - '98 Metro
90 day: 78.84 mpg (US)
ForkenSwift - '92 Metro EV
90 day: 106.27 mpg (US)
And apparently the manufacturers assume people are clueless about the concept of downshifting for acceleration or climbing! Thus we are stuck with excessive RPM at highway speeds. Let's start a petition.
PS - nice salt flats reference.
Old 08-21-2008, 10:37 AM   #30 (permalink)
OfficeLinebacker's Avatar
Awesome thread. Been toying with the idea of oversize tires...does this gear change have a similar effect on the speedo readings?
Still playing with my ScanGaugeII!
Story of a custom 5th gear for a '98 Ford Escort ZX2: +6% MPG MetroMPG EcoModding Central 7 09-01-2009 03:44 PM
EOC (keep in neutral or 5th gear?) Pillzilla Hypermiling / EcoDriver's Ed 18 08-25-2009 09:58 PM
Home made hybrid (using access to 5th gear on FWD transaxle) AXMonster Hybrids 17 10-19-2008 06:35 AM
Met an unhappy Aveo owner today MetroMPG General Efficiency Discussion 18 08-21-2008 06:56 PM
5th Gear New Smart Car Review (video) igo EcoModding Central 0 04-13-2008 10:06 PM
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.3.2
