Saturn sc1 - the work car
Picked up a 1.9l sc1 last February to make the bleeding stop. I was driving my 2014 dodge ram 115km back and forth to work . 11.65 l / 100k driving mostly like a maniac...ouch.
I have averaged since I've owned the car 6.4 l/100k. And that's by doing absolutely nothing to help myself. Commited to not doing stupid things and I've brought that down to 5.7 over the last two fill ups. Cause I need another hobby lol the mods start tomorrow :) hoping to get under 5l / 100k. Wish me luck.. |
Bleeding?
Welcome and good luck! :) |
Bleeding money lol.. 5 -600 month in fuel costs. Need a truck for my hobbies but driving it daily was killing me..
Looked up the Saturn SC1 as I am not familiar with it here in the UK. Describes it as a compact car. Here it would be classed as a large family saloon!
Productive day yesterday, trans fluid swapped to synthetic, front air dam added, weatherstripping on the hood to headlight gap. Torque app downloaded and Canada post should be dropping off my obd2 dongle this afternoon.
Once I have torque up and running I can do a wai and grill block. Need to see if I can find a serpentine belt for a/c delete. Was an option so I should be able to :). Looking forward to seeing a small change in the mileage numbers! |
1 Attachment(s)
http://ecomodder.com/forum/attachmen...1&d=1506676814
Air dam. Also picked up some relays and switches and a momentary start switch to wire in a kill switch and start panel. |
2 Attachment(s)
http://ecomodder.com/forum/attachmen...1&d=1506677081
Before air dam. The stock one was long gone before I got this car lol.. vehicle had been in a front end / rear end accident hence the pick and pull bumpers.. http://ecomodder.com/forum/attachmen...1&d=1506677246 Replacing a bunch of loose body clips to get rid of some rattles. Did the air dam with the bumper cover removed to save my back lol. |
Issue I had with wai was if I could get good heat on the highway it was too hot in town and would get preignition, never figured out a system to switch from hot to cold I didn't bypass the ac compressor, when the ac is off, I don't think it creates any more drag than an idler pulley. |
The older Saturn's were available without ac and power steering they use a shorter belt and a ribbed idler pulley and only have to spin the alternator and water pump I'm currently running that setup on my 99 sc2
