Old 01-23-2008, 08:35 PM   #1 (permalink)
Nomadic Chicken
WaxyChicken's Avatar
Saving a dead jump starter
I have a jump starter that i've allowed to get too low. Now it won't hold a charge for more than a day.
Is there anyway i can salvage it or get some other good use from it?
(example pic)
If you haven't herd of them before (but you probably have) here's how they work:
-Plug them in at night.
-The next day put it in your car.
-If your car battery dies during the next couple of weeks then you can use this Jump Starter to start your car up instead of bumming a jump from someone else's car.
Old 01-23-2008, 08:38 PM   #2 (permalink)
Awesomeness personified
AndrewJ's Avatar
Harold - '94 Civic CX
90 day: 54.51 mpg (US)
Margot - '08 Big Dummy
Send a message via AIM to AndrewJ
replace the battery that's inside of it. It's probably a SLA (sealed lead acid) 12v battery. You can find a suitable replacement from Radioshack. Every one I go into seems to have a few large-ish SLA's sitting forlorn on a shelf near the back, problem is that they're expensive, usually to the tune of at least $40
"I got 350 heads on a 305 engine. I get 10 miles to the gallon. I ain't got no good intentions." - The Drive By Truckers.
Old 01-23-2008, 08:44 PM   #3 (permalink)
Nomadic Chicken
Originally Posted by AndrewJ View Post
replace the battery that's inside of it [...] problem is that they're expensive, usually to the tune of at least $40
i only paid $60 for the jump starter. For that i could just about go out and get a new one.
What about the parts?
It had a DC out plug, could display Red, Yellow, Green for jump charge available in the unit, and it would "Beeeeeeeeeeeeep!" if connected backwords.
Could i salvage those parts for anything if i decide not to rebuild it?
(i never saw inside one. I might try taking it appart this weekend)
Old 01-23-2008, 08:52 PM   #4 (permalink)
AndrewJ's Avatar
I'm sure you can find a MUCH cheaper SLA out there somewhere, $40 is just the exorbitant price that Radioshack charges for theirs.
As for the rest of the bits, sounds like you have the makings for a 12v battery charger if you should need one.
Old 01-23-2008, 09:34 PM   #5 (permalink)
MechE
The Wagen - '00 Jetta GLS
90 day: 32.72 mpg (US)
Open it up and see if the sides of the battery are bulging.... If they are... I'd try desulfating (build your own circuit though - otherwise, spend $60). It may, or may not, work... It has worked for me in a kind of "lets get this done" ethos - but YMMV.
Challenge me, or correct me, but don't ask me to die quietly.
Old 01-23-2008, 09:42 PM   #6 (permalink)
Nomadic Chicken
K. thanks guys. I'll open it up this weekend and see what i find. It should be pretty drained out by now.
Old 01-24-2008, 07:14 PM   #7 (permalink)
LibbyMetro's Avatar
lil' red - '93 Metro Base
90 day: 51.1 mpg (US)
Da' Honda - '98 Civic EX
90 day: 40.3 mpg (US)
Gas Guzzler - '95 K1500 cheyenne
http://www.alwaysbrilliant.com/aa/as...y%20Jumper.htm
bout 45 bucks
