Old 07-15-2008, 10:48 PM   #11 (permalink)
Daily Driver - '01 Explorer Sport
90 day: 18.12 mpg (US)
Send a message via Yahoo to Tony Raine
Originally Posted by Mandilon View Post
I read that grille blocks are ineffective. EPA blocked an 18 wheeler's grille oppening and there wasn't any effect in wind resistance. I have the PDF file somewhere hope I find it.
i read somewhere that elvis was still alive, doesn't make it true
but to be more serious....
on an 18 wheeler, i can see how a grill block would be a bad thing. an 18 wheeler grill is very wide, tall, and vertical. with an "open" grill, air will pass through it and while most of it just bounces around and creates turbulence, some of it has a fighting chance to make it out the bottom of the rig.
with a grill block, air just hits a massive wall at a 90 degrees to the road.
compare trying to run down the road holding a 4'x8' sheet of plywood straight up to doing the same with a 4'x8' window screen.
on a car/pickup/suv, the grill block diverts the air over/under the car at a more aerodynamically pleasing angle. think teardrop shape.
My Intro
Old 07-15-2008, 10:56 PM   #12 (permalink)
Old Retired R&D Dude
Transporter - '09 Escape XLS
Originally Posted by Tony Raine View Post
7
If you are running above 40 mph, the surface of a mesh screen starts to act just like it was a solid.
That's why those old mesh satellite dishes blow around in a heavy wind storm.
Cheers,
Rich
Old 07-15-2008, 10:57 PM   #13 (permalink)
gascort's Avatar
Gascort - '93 Escort Wagon
90 day: 40.49 mpg (US)
But... to be less serious, could someone please try this and post video?
I bet the window screen has at least 50% of the resistance of a plywood sheet at high speeds though. Seems like a lot of turbulence would be generated.
The grill blocks on our cars also push air up, over, and around a vehicle that has good aerodynamics. The semi - it doesn't matter where the air goes around - it's not good.
Gasoline, Wind, Solar, Gravity Hybrid-to-be! http://www.scientificmethodfueleconomy.blogspot.com/
Old 07-15-2008, 10:59 PM   #14 (permalink)
gascort's Avatar
...I think the EPA tests are *smarter* than YOURS.
Please tell me you are kidding, and that you don't also believe Jamie and Adam on Mythbusters never have error in their experimentation...
Old 07-15-2008, 10:59 PM   #15 (permalink)
Mr. Blue Tape
azraelswrd's Avatar
AzxA - '06 xA
90 day: 42.72 mpg (US)
Wow, I didn't know that. Cool! (I was wondering why people were using mesh for belly pans) Does it involve Bernoulli's principle or am I making it that obvious I'm not a physicist?
My 5 pillars of fuel efficiency:
  • driving style
  • aerodynamics
  • tires
  • weight reduction
  • engine maintenance
Old 07-15-2008, 11:04 PM   #16 (permalink)
Legend in my own mind
trikkonceptz's Avatar
Evil Pumpkin - '08 xD RS 1.0 #1633
90 day: 40.52 mpg (US)
Lady in Red - '07 Camry Hybrid
90 day: 40.74 mpg (US)
OMG, I did this for nothing? Seriously, 2 mpg from grill and fog blocks are nothing to sneeze at ..
Plus, ghetto bug splatter wind tunnel testing shows bug only like the bottom 4 inches of the nose. everything else now stays clean .. whoo hoo ...
Thx NoCO2; "The biggest FE mod you can make is to adjust the nut behind the wheel"
I am a precisional instrument of speed and aeromatics
If your knees bent in the opposite direction......what would a chair look like???
Old 07-15-2008, 11:11 PM   #17 (permalink)
What kind of speeds are we talking about? Because, 50% is a big number..
Can't find much info about this on the web..
I think this "reduce by 40%" chart is most likely for a K-band dish
which has pretty large holes in it's mesh.
Whereas if we are talking about a window screen.. I would have to guess
it would say reduce by 20% at the most..
Cheers,
Rich
Old 07-16-2008, 03:27 AM   #18 (permalink)
EP3
EP3's Avatar
02WhiteEp3 - '02 Civic Si
90 day: 28.35 mpg (US)
Send a message via AIM to EP3
....sorry. I didn't know 'aerodynamics' CARED. I thought that they affected EVERYTHING ***PROPORTIONATLY****
LOL Wow this is a way to start off posting. Reguardless if you are right or not (which I strongly disagree with you). Real life trial and error is where you will see real results. Yea you go ahead and trust everything the governt throughs at you. And I have not been an Ecomodder here long, but I am offended when you insult someone on here.
If this was meant in any other way then I read this, please explain again.
"There is no such thing as a dumb question.. Just dumb people".
Old 07-16-2008, 03:31 AM   #19 (permalink)
EP3
EP3's Avatar
ROTFLMAO
I am impressed that you found such a chart. Wow! that this chart even existed. Funny stuff never the less.
Old 07-16-2008, 03:44 AM   #20 (permalink)
EP3
EP3's Avatar
LOL I am so going to do this. I can see me now...Out of breath, my wife yelling "What the!! What are you doing" The neibors staring as if I am on some kind of drug induced rage. The Police showing up shortly after with the COPS camera crew. Me yelling at the Police saying "no its ok I am a firefighter doing a areodynamics test"... Me getting tazed as I run towards the Police because they take the screen as some kind of weapon... The last words before I wet myself from being tazed "Ecomodder Till I DIE!!"
Sorry I must be tired 2:42am EST coming off a 24hr shift.
Grill Block Poll. Ryland Aerodynamics 18 11-09-2009 01:00 AM
DIY - Front Grill Block SVOboy DIY / How-to 13 11-24-2008 09:33 PM
Lower Grill Block 2005 Honda Civic Arminius EcoModding Central 11 06-25-2008 04:02 AM
My try at a partial grill block bhazard Aerodynamics 15 04-30-2008 11:09 PM
OEM Grill Block for 92-95 Civic Owners TomO EcoModding Central 1 12-17-2007 11:58 PM
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.3.2
