Old 07-06-2008, 10:50 AM   #1 (permalink)
dcb
needs more cowbell
dcb's Avatar
pimp mobile - '81 gs 250 t
90 day: 96.29 mpg (US)
schnitzel - '01 Golf TDI
90 day: 53.56 mpg (US)
Saw another grill block :)
I was at the zoo friday and noticed what looked like a gold pontiac, but it had the caracteristic "use whatever you have lying around" grill block job on it It had a little Bondo to close the hood gap and some black stuff on the lower grill. It weren't pretty unless you knew what it was about. I found it quite encouraging myself The stealth grill blocks are nice, but the obvious ones sure are a lot easier to spot.
Old 07-06-2008, 11:48 AM   #2 (permalink)
Dartmouth 2010
SVOboy's Avatar
Vegan Powa! - '91 CRX DX
90 day: 66.52 mpg (US)
I don't think I've ever seen on in the wild, so that's pretty neat indeed.
Old 07-06-2008, 01:22 PM   #3 (permalink)
Hybrid Student Driver
RH77's Avatar
Teggy - '98 Integra LS
90 day: 33.38 mpg (US)
IMA - '010 Insight EX
90 day: 42.69 mpg (US)
Tessie - '06 TSX Base
90 day: 27.1 mpg (US)
I've only seen cardboard type stuff in the Winter, but nothing in the warmer months. Excellent spot!
RH77
Supporting those devastated by the Joplin Tornado
EF5 / 22-May-2011
_
_
Old 07-06-2008, 06:50 PM   #4 (permalink)
BamZipPow's Avatar
BZP T-100 (2010) - '98 T-100 ext cab - 3.4L/auto SR5
90 day: 20.99 mpg (US)
BZP T-100 (2011) - '98 T-100 ext cab - 3.4L/auto SR5
90 day: 20.93 mpg (US)
BZP T-100 (2009) - '98 T-100 ext cab - 3.4L/auto SR5
Last 3: 19.01 mpg (US)
BZP T-100 (current) (2012) - '98 T-100 ext cab - 3.4L/auto SR5
90 day: 20.88 mpg (US)
Send a message via ICQ to BamZipPow Send a message via AIM to BamZipPow Send a message via MSN to BamZipPow Send a message via Yahoo to BamZipPow
What...no piccies?
Old 07-07-2008, 10:53 AM   #5 (permalink)
Mechanical Engineer
The Truck - '02 Ram 1500 SLT Sport
90 day: 17.57 mpg (US)
The Van 2 - '06 Odyssey EX
90 day: 18.48 mpg (US)
I've seen something here in the parking lot at work...late 90s/early 00's Sebring coupe with what looks like an aftermarket bumper cover that has rippled plastic in place of the standard open grille. Not a "grille block" per se but not-so-cleanly blocks the grille none the less. Since it's neither aero-clean due to the horizontal ridges approximating the original grille shape nor a DIY job I don't think the original intent was improved mileage.
Old 07-07-2008, 12:05 PM   #6 (permalink)
dcb
needs more cowbell
dcb's Avatar
Oh I forgot, the pontiac had the wipers parked vertically
Old 07-07-2008, 02:08 PM   #7 (permalink)
I read that grille blocks are ineffective. EPA blocked an 18 wheeler's grille oppening and there wasn't any effect in wind resistance. I have the PDF file somewhere hope I find it.
GreenTruckingConcepts.com
Old 07-07-2008, 02:38 PM   #8 (permalink)
Ex-lurker
i_am_socket's Avatar
Skeeter - '05 Corolla LE
90 day: 35.55 mpg (US)
I hate to feed the trolls, but you are aware that the aerodynamic differences between an 18 wheeler and a passenger car is ENORMOUS right?
Old 07-15-2008, 08:38 PM   #9 (permalink)
....sorry. I didn't know 'aerodynamics' CARED. I thought that they affected EVERYTHING ***PROPORTIONATLY****
I think the EPA tests are *smarter* than YOURS.
Old 07-15-2008, 09:37 PM   #10 (permalink)
Mr. Blue Tape
azraelswrd's Avatar
AzxA - '06 xA
90 day: 42.72 mpg (US)
I wouldn't put a lot of weight into EPA tests, considering the thorough "testing" they do for mileage ratings.... assuming they actually do any testing and don't just take someone else's data and stick it into the computer and hope whatever value they do get is close to where it should be (plus those numbers they use are guesstimates to simulated aerodynamic effects).
...or the unrealistic conditions done for those tests re-established in the 80s, only updated after 2007? Wow, slow and sloppy. It's not surprising so many people here are able to overshoot the EPA expected values or worse by many others who don't know better, to undershoot it by a large margin.
Grille blocking can't hurt but it alone won't net you a lot of mpgs. It's all about the cumulative gain. 0.2 here, 0.4 there, 0.1 somewhere else... aeromods can add up.
My 5 pillars of fuel efficiency:
  • driving style
  • aerodynamics
  • tires
  • weight reduction
  • engine maintenance
The Following User Says Thank You to azraelswrd For This Useful Post:
Christ (11-05-2009)
OEM Grill Block for 92-95 Civic Owners TomO EcoModding Central 2 10-04-2011 01:31 AM
Lower Grill Block 2005 Honda Civic Arminius EcoModding Central 12 10-04-2011 01:31 AM
DIY - Front Grill Block - 1991 Honda CRX SVOboy DIY / How-to 33 06-24-2011 06:16 PM
Grill Block Poll. Ryland Aerodynamics 18 11-09-2009 01:00 AM
My try at a partial grill block bhazard Aerodynamics 15 04-30-2008 11:09 PM
