Old 12-30-2017, 09:46 AM   #171 (permalink)
Master Ecomadman
arcosine's Avatar
sc1 - '98 saturn sc1
Team Saturn
90 day: 43.17 mpg (US)
C - '97 Vision R40
minivan - '93 oldsmobile Silouette
Tracker - '96 geo tracker 4wd 2d soft top
90 day: 30 mpg (US)
SC1 Lives! I replaced the rusted engine cradle outside in single digit temperatures. I have only 4 exhaust studs left to install, and some straps for the radiator. The worst was the bolt retainer nuts spinning inside the frame, I had to grind the bolt heads off. The new cradle has copious amounts of undercoating. A 4 foot chunk of belly pan is now missing, I had to cut out for access. I am considering a replacement for sc1, maybe a last model Celica gt with a Corolla 5 speed transmission. I looked at cars in the junkyard when extracting the new cradle, Celicas brakes are monstrous compared to sc1's puny disks. SC1 brakes have always been a weak point. I like the Celica's hatch back, I could almsot fit my bike inside. Cruising at 65, sc1 1.9L is at 2220 (4.025 final and .605 fifth ratio) rpm, where the 1.8L VVT Celica with Corolla trans(3.722 final with .725 fifth ratio), would be at 2435 rpm. They weigh about the same, and have the same tire size, 195/60R15. I've found that Toyotas are pita to work on.
I want to finish it up before before the weather turns sub-zero this afternoon.
New bike in progress:
- Tony
The Following 2 Users Say Thank You to arcosine For This Useful Post:
aerohead (12-30-2017), BamZipPow (12-30-2017)
Old 12-30-2017, 09:56 AM   #172 (permalink)
Do more with less
OD - '05 Ford Econoline
90 day: 18.64 mpg (US)
90 day: 49.71 mpg (US)
90 day: 28.08 mpg (US)
Tony,
You are supposed to get outside projects done before now! I am still driving the same cars for the past 10 years.
Prediction here on NYE is -15°F
"A man is not finished when he is defeated. He is finished when he quits."
Richard M. Nixon
"The reward of suffering is experience."
Harry S. Truman
“There's no way to rule innocent men. The only power any government has is the power to crack down on criminals. Well, when there aren't enough criminals, one makes them. One declares so many things to be a crime that it becomes impossible for men to live without breaking laws.”
Ayn Rand
Old 12-30-2017, 11:02 AM   #173 (permalink)
Master Ecomadman
arcosine's Avatar
Team Saturn
C - '97 Vision R40
90 day: 30 mpg (US)
Happy New Year, Dave!
- Tony
Old 12-30-2017, 11:32 AM   #174 (permalink)
Do more with less
Wow a SWB bike. So used to seeing your open wheel out front.
Happy new year to you too Tony
Dave
Richard M. Nixon
Harry S. Truman
Ayn Rand
Old 12-30-2017, 01:04 PM   #175 (permalink)
Master Ecomadman
arcosine's Avatar
Team Saturn
C - '97 Vision R40
90 day: 30 mpg (US)
I'll have to make it out your way one of these days.
I am trying SWB, smaller, lighter, more maneuverable. Nose over LWB front wheel moves CP forward, in theory, hasn't been tested yet in cross winds.
- Tony
Old 01-12-2018, 03:32 PM   #176 (permalink)
Aero Wannabe
COcyclist's Avatar
TDi - '04 VW Golf
90 day: 60.98 mpg (US)
Originally Posted by arcosine View Post
Is there a thread for the new bike? I'm interested in your build.
60 mpg hwy highest, 55+mpg lifetime
TDi=fast frugal fun
make NOx not Carbon
"I worked on the wiring to see if I could get the alternator to charge. The stud was loose and I accidentally let the white smoke out of the box... Alternators, among other things, run on white smoke. Once you let the white smoke out they no longer work!" planejob
Old 01-12-2018, 10:46 PM   #177 (permalink)
Master Ecomadman
arcosine's Avatar
Team Saturn
C - '97 Vision R40
90 day: 30 mpg (US)
Yes, yes there is a thread:
The Recumbent Bicycle and Human Powered Vehicle Information Center
Tony
- Tony
The Following 3 Users Say Thank You to arcosine For This Useful Post:
aerohead (01-13-2018), BamZipPow (01-13-2018), COcyclist (01-15-2018)
saturn
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
