Old 12-26-2010, 05:59 PM   #1 (permalink)
Scangauge 2 TFT display
Hello everyone.
I got my Scangauge 2 days ago.
Could not get it to display the Automatic transmission fluid temperature,though.
If anyone could post the code for that it would be appreciated.
Toyota Echo 2004 A/T
Thanks
Old 12-26-2010, 06:14 PM   #2 (permalink)
MPG>HP
Little Blue - '09 Focus SE
Team Ford
90 day: 34.41 mpg (US)
This post might help you.
Welcome to the forum.
Best Tank:36.915MPG|422.6Miles
Longest Tank:35.2MPG|435.8Miles
Best Trip:45.9MPG|5.9Miles
The Following User Says Thank You to Angmaar For This Useful Post:
sonnyivo (12-27-2010)
Old 12-26-2010, 07:56 PM   #3 (permalink)
mcrews's Avatar
The Q - '02 Q45 Sport
90 day: 23.08 mpg (US)
I ended up installing a regular gauge and patched into the trans line with the sensor.
Which is ok.....but.....
I still get plenty of information of the SGII
ECO MODS PERFORMED:
First, Grille Block
http://ecomodder.com/forum/showthrea...e-10912-2.html
Second, Full underbelly pan
http://ecomodder.com/forum/showthrea...q45-11402.html
third, rear skirts and 30.4mpg on trip! http://ecomodder.com/forum/showthrea...tml#post247938
The Following User Says Thank You to mcrews For This Useful Post:
Old 12-27-2010, 03:45 PM   #4 (permalink)
I tried the 2 codes provided .....sorry do not work....
Old 12-30-2010, 09:11 PM   #5 (permalink)
I found the needed code
Hello guys finally i found the code i needed.For anybody who might need it in the future...it is:
TXD: 686AF101B4
RXF: 044105B00 00
RXD: 2808
MTH: 00090005FFD8
Thank you again Angmaar.I found it through the link you sent me.First time i used the spaces between the letters and it didn't work.Tried without them and everything is fine now.
