Old 03-19-2010, 09:25 PM   #1 (permalink)
Scangauge: Bad pump messed up gauges
At a recent fillup, the car needed 24% more fuel than expected by the Scangauge. This was odd, as it's generally within 5%. Now all my mileage readings are significantly lower.
So, how can I 'throw away' info from this tank?
Old 03-19-2010, 11:08 PM   #2 (permalink)
...beats walking...
Old Tele man's Avatar
Vibe - '09 Vibe Base (2ZR-FE)
90 day: 32.85 mpg (US)
Goldie Locks - '011 Cruze LTZ
90 day: 28.75 mpg (US)
...can you readjust the FILLUP value (up or down as necessary) until the "±%" number is *back* to what it was before? Of course, this assumes you wrote-down or recall what that number was before.
2011 Chevrolet Cruze LTZ 1.4LT 6A
2009 Pontiac Vibe 1.8L/SIDI 4A
2004 Pontiac Vibe 1.8L/MFI 4A
2003 Ford Focus ZX5 2.0L/Zetec 4A
1971 Dodge Charger 318 3A
1970˝ Plymouth AAR 'Cuda 340/6BBL 4M
1968 Dodge Charger 383 3A
1967 Plymouth Barracuda Formula S 383 4M
1965 Plymouth Barracuda Formula S 273 4M
Old 03-19-2010, 11:18 PM   #3 (permalink)
Pokémoderator
cfg83's Avatar
1999 Saturn SW2 - '99 SW2 Wagon
90 day: 42.26 mpg (US)
Old Tele man -
I agree. I also think you can leave the SG unconnected for a while and it will reset to defaults.
CarloSW2
American Solar Energy Society
Old 03-20-2010, 11:03 AM   #4 (permalink)
ECO-Evolution
Lazarus's Avatar
Iron Horse - '97 Intrepid
C-3 - '08 XF50X
90 day: 135.32 mpg (US)
One thing you might want to check when this happens is if somehow the SG went back to the default values. I"ve had my SG I reset several times that gave me incorrect values.
If you driven it with wrong numbers I think all you can do is just reset it like you filled it up and just ride out the tank until it's time to fill up again. You probably need to confirm the setup values again.
"Judge a person by their questions rather than their answers."
What are your 4 favorite ScanGauge Gauges? armycopter Instrumentation 37 08-14-2010 01:57 AM
Hydraulic Hybrid Vs. Electric Hybrid jason.thompson EcoModding Central 20 09-15-2009 08:39 PM
Heat Pump Temp Lockout Settings to Gas Backup RH77 Saving@Home 0 10-25-2008 01:09 PM
ScanGauge is bad for MPGs Tango Charlie The Lounge 2 08-10-2008 01:29 PM
What gauges do you use on your scangauge? regor EcoModding Central 12 06-10-2008 11:06 AM
