Old 05-03-2008, 11:45 AM   #11 (permalink)
Moderator
tasdrouille's Avatar
The Guzzler - '08 Elantra GL
90 day: 33.12 mpg (US)
Got Soul? - '011 Soul 2U
Running your engine at higher temperatures makes it more efficient. Ideally you would want it to have it running just below the fan trigger temp all the time, but that's just not possible.
My elantra runs at 196 and the fan kicks in at 220.
Since dash gauges are so innacurate, I would not suggest running your truck fanless without a way to accurately monitor coolant temps.
www.HyperKilometreur.com - Quand chaque goutte compte...
Old 05-03-2008, 12:06 PM   #12 (permalink)
Legend in my own mind
trikkonceptz's Avatar
Evil Pumpkin - '08 xD RS 1.0 #1633
90 day: 35.45 mpg (US)
Silent Silver Killer - '010 Insight EX
90 day: 51.5 mpg (US)
Why is this true? It seems to go against all logic. Now I can understand you guys that live up north wanting to get engines heated up quickly, but here in florida its so hot the engine is almost at temperature while parked .. LOL
Seriously though, I was think about running without a thermostat in order to bring engine temps down to a 160-180 range or lower. Someone please edumacate me ...
Thx NoCO2; "The biggest FE mod you can make is to adjust the nut behind the wheel"
I am a precisional instrument of speed and aeromatics
If your knees bent in the opposite direction......what would a chair look like???
Old 05-03-2008, 01:09 PM   #13 (permalink)
Moderator
Maybe you are confusing performance and efficiency.
Under certain limits:
- A colder engine performs better while a hotter one is more efficient.
- A richer engine performs better while a leaner one is more efficient.
Swapping in a higher temp thermostat Daox EcoModding Central 23 03-31-2008 07:51 AM
What to do when the ScanGauge shows your SUV gets horrible MPG? Ditch the ScanGauge! MetroMPG Hypermiling / EcoDriver's Ed 10 02-14-2008 05:26 PM
Engine efficiency improvement through higher temp thermostat? Lazarus General Efficiency Discussion 13 02-05-2008 11:39 AM
