Old 02-07-2010, 01:12 AM   #31 (permalink)
Originally Posted by cfg83 View Post
It has been my impression that my 1999 ECU/PCM is slow to respond to commands.
A lot depends on the ECU and the protocol. OBD-II isn't really one protocol, it is more like 6, on top of three different electrical standards. The 'ISO' standards, which use the 'K' and 'L' lines are slow. There are a bunch of mandatory pauses between things that really bog things down.
J1850 and CAN are considerably faster, but there is still a lot of variation in response speed between different ECU's.
-jjf
How to calculate MPG / fuel economy formula MetroMPG DIY / How-to 21 06-29-2010 10:37 AM
Engine braking without using fuel idea Dane-ger EcoModding Central 38 02-04-2010 11:35 AM
Effect of fuel octane number on FE hummingbird EcoModding Central 32 10-28-2009 01:50 AM
87 octane vs 89 octane kill-9 General Efficiency Discussion 42 08-15-2009 06:12 PM
Basic EcoDriving Techniques and Instrumentation SVOboy Instrumentation 2 11-17-2007 12:38 PM
