Old 01-06-2010, 05:26 PM   #1 (permalink)
scangauge fuel tank size accuracy
Right. I have a scangauage 2 on my car which has a 9.6 gallon tank.
As the scangauge doesnt have high accuracy on fuel tank size measuremeant I have told it that its 10gallons as per the manual which says round up.
My Question is, does it affect the accuracy as , after a 10 or 20 fillups I have adjusted it to the point where my Miles to empty is now accurate.
Whereas before it used to say emtpy 30 miles before it was actually empty. it now correlates when its actually emtpy.
confused
Old 01-06-2010, 05:52 PM   #2 (permalink)
epic stock master
luvit's Avatar
86 Accord LX (carb) - '86 Accord LX
90 day: 35.57 mpg (US)
i can't answer your question, but no matter what model of car i own, this makes me scratch my head:
when i'm on empty, i almost always pump 2 more gallons than the tank's rated size. -- i don't top off.
makes me mad or something.
single person car thread
Old 01-06-2010, 05:54 PM   #3 (permalink)
2 gallons! thats a lot!
When its really really emtpy I sometimes put in 2-3 liters more than the tank size which I attribute to the fuel pipe between the tank and the nozzle and between the engine and the tank.
Old 01-06-2010, 06:19 PM   #4 (permalink)
epic stock master
luvit's Avatar
i do this a lot.
Old 01-06-2010, 06:20 PM   #5 (permalink)
heh same.
Old 01-06-2010, 06:26 PM   #6 (permalink)
Ecomodder en route
KITT222's Avatar
Vib - '04 Vibe base
Automakers alter the gas gauge in your car so even when its on E the car has a gallon or so left. I was driving my dads fiances Corolla the other day, and it was on E. I mentioned it, and she said the car has a few gallons left. In fact when I got off the side roads, and onto the highway the needle went up.
In your case I'd say to round it down to 9 gallons. That means range wont be accurate, but it wont be an overshot. I dont own a Scangauge, so I dont know if theres a .5 gallons, or not, but if there is, than go with 9.5 gallons.
Old 01-06-2010, 06:27 PM   #7 (permalink)
So essentially the mile to empty and rage is more accurate now with the tank size on 10 gallons?
Old 01-06-2010, 06:40 PM   #8 (permalink)
Pokémoderator
cfg83's Avatar
1999 Saturn SW2 - '99 SW2 Wagon
Team Saturn
90 day: 43.05 mpg (US)
alexander.foti -
Since you are in the UK, I am assuming Imperial Gallons. Here's a trick that I haven't tried :
1 - 9.6 Imperial Gallons = 11.529 US Gallons = 43.642 liters (used this converter)
Code:
 9.6   => 10 /  9.6   = 1.0416 => +4.2% tank size error
43.642 => 44 / 43.642 = 1.008  => +0.8% tank size error
2 - Switch to liter units. Enter tank size of 44. Switch back to gallons. You may see 9 or 10 gallons, I don't know. Switch back to liter to verify that the liter value of 44 stayed in the scangauge. If it does, then you should have a more accurate tank size.
I haven't tried this, but it's an easy test.
CarloSW2
American Solar Energy Society
The Following 2 Users Say Thank You to cfg83 For This Useful Post:
mcrews (01-07-2010), MetroMPG (01-07-2010)
Old 01-06-2010, 07:24 PM   #9 (permalink)
ECO-Evolution
Lazarus's Avatar
Iron Horse - '97 Intrepid
C-3 - '08 XF50X
90 day: 135.32 mpg (US)
confused
Not sure I understand the question but when you fill up the amount you put in the tank should match the amount of fuel used on the SG. Mine was accurate to within .1 gallon almost every fillup once I got it adjusted.
"Judge a person by their questions rather than their answers."
Old 01-06-2010, 08:16 PM   #10 (permalink)
...beats walking...
Old Tele man's Avatar
Vibe - '09 Vibe Base (2ZR-FE)
90 day: 32.19 mpg (US)
Goldie Locks - '011 Cruze LTZ
90 day: 29.42 mpg (US)
As the scangauge doesnt have high accuracy on fuel tank size measuremeant I have told it that its 10 gallons as per the manual which says round up.
...uh, which SGII instructions are you reading and following (Ver 4.5, 5.0 or 5.1)?
...early versions mentioned comparing "percent" value, while the newest (ver 5.1) "Quick Setup" mentions comparing "gallons" fuel used.
...I'm sure the "gallons" method described in the "Quick Setup" pamphlet is the most accurate method.
2011 Chevrolet Cruze LTZ 1.4LT 6A
2009 Pontiac Vibe 1.8L/SFI 4A
2004 Pontiac Vibe 1.8L/MFI 4A
2003 Ford Focus ZX5 2.0L/Zetec 4A
1971 Dodge Charger 318 3A
1970˝ Plymouth AAR 'Cuda 340/6BBL 4M
1968 Dodge Charger 383 3A
1967 Plymouth Barracuda Formula S 383 4M
1965 Plymouth Barracuda Formula S 273 4M
How to calculate MPG / fuel economy formula MetroMPG DIY / How-to 21 06-29-2010 09:37 AM
Engine braking without using fuel idea Dane-ger EcoModding Central 38 02-04-2010 10:35 AM
Effect of fuel octane number on FE hummingbird EcoModding Central 32 10-28-2009 12:50 AM
87 octane vs 89 octane kill-9 General Efficiency Discussion 42 08-15-2009 05:12 PM
Basic EcoDriving Techniques and Instrumentation SVOboy Instrumentation 2 11-17-2007 11:38 AM
