Old 08-02-2011, 11:04 PM   #1 (permalink)
graydonengineering's Avatar
Frontier 2wd 2.4L 5 speed - '98 Frontier XE
90 day: 27.72 mpg (US)
ScanGauge II faster response
I just learned a way to decrease the lag of data to the ScanGauge II! If the delay on the scan gauge II is too slow just increase the rate in the more>more>rate screen to "fast." I don't know why this is not the standard setting but I for one find the lag counterproductive.
-Miles
Best 15-mile commute city/highway mix: 37.7 mpg
Best tank so far: 31 mpg
The Following 3 Users Say Thank You to graydonengineering For This Useful Post:
1337 (10-16-2011), dkunitz (08-05-2011), mcrews (08-03-2011)
Old 08-03-2011, 12:27 AM   #2 (permalink)
dcb
needs more cowbell
dcb's Avatar
pimp mobile - '81 gs 250 t
90 day: 96.29 mpg (US)
schnitzel - '01 Golf TDI
90 day: 53.56 mpg (US)
I'm guessing it isn't the default because it works more reliably and/or in more cars in "slow" mode. Just a guess though.
Old 08-03-2011, 07:55 AM   #3 (permalink)
Daox's Paseo - '97 Paseo
Last 3: 53.99 mpg (US)
Daox's Prius - '04 Prius
90 day: 54.91 mpg (US)
CM400E - '81 CM400E
I'm also pretty sure, but you have to set it to fast every time you make a trip. I don't think it stays on fast...
Old 08-05-2011, 02:57 PM   #4 (permalink)
I can now verify, it does stay on fast. You don't need to change it every time. The data delay is quite a bit less. I like it!
-Miles
The Following User Says Thank You to graydonengineering For This Useful Post:
Daox (08-05-2011)
