Old 01-18-2010, 04:32 PM   #1 (permalink)
Grasshopper
alohaspirit's Avatar
Makai - '01 Echo 4D Auto
90 day: 34.45 mpg (US)
Mauka - '00 Echo 4D Auto
90 day: 34.57 mpg (US)
Silver Surfer - '02 Jetta TDI
90 day: 35.93 mpg (US)
Arrow ScanGauge II speaker mount for 2001 Toyota Echo
Ive been thinking about a SG mount for a long time now. So I fabbed one up. If you worked straight through from start to finish it will probably take you an hour or so.
I could have just drilled 3 holes in the speaker cover but I dont have a spare cover.
Its also reversible this way. I do plan to cover the surrounding hole with coroplast or something. This probably cost me $5 to make.
What I used:
Thin cardstock (for template)
Thin sheet metal
Metal snips
Metal file (to smooth edges)
Drill
Screwdriver
2 Screws
3M Velcro
I had it behind the steering wheel but its not a great place since the surface is curved.
(It'll come off eventually in time)
So I popped the speaker cover off.
My echo didnt come with tweeters so its an empty space with 2 places for screws.
I made a template out of cardstock, traced it to thin sheet metal,
then cut a plate using metal snips. I then smoothed the edges and
and screwed it down to the existing holes.
3M heavy duty "velcro" works really well and I was able to run the cord down.
(If you look through the windshield, it literally drops straight down to the OBD port)
I like how close it is to the windshield. I keep my eyes on the road
and even have a small amount of room to put up the sunshade.
Past Present Future?
Old 01-18-2010, 05:19 PM   #2 (permalink)
...beats walking...
Old Tele man's Avatar
Vibe - '09 Vibe Base (2ZR-FE)
90 day: 32.19 mpg (US)
Goldie Locks - '011 Cruze LTZ
90 day: 29.42 mpg (US)
...sneaky cool!
2011 Chevrolet Cruze LTZ 1.4LT 6A
2009 Pontiac Vibe 1.8L/SFI 4A
2004 Pontiac Vibe 1.8L/MFI 4A
2003 Ford Focus ZX5 2.0L/Zetec 4A
1971 Dodge Charger 318 3A
1970½ Plymouth AAR 'Cuda 340/6BBL 4M
1968 Dodge Charger 383 3A
1967 Plymouth Barracuda Formula S 383 4M
1965 Plymouth Barracuda Formula S 273 4M
Old 01-26-2010, 03:42 AM   #3 (permalink)
Grasshopper
im still thinking of ways to make the surround
any suggestions?
Old 01-26-2010, 07:49 AM   #4 (permalink)
Daox's Paseo - '97 Paseo
Last 3: 53.99 mpg (US)
Daox's Prius - '04 Prius
90 day: 54.91 mpg (US)
CM400E - '81 CM400E
Fiberglass is the only thing I can think of.
Old 01-26-2010, 07:51 PM   #5 (permalink)
...beats walking...
...how about that "home-improvement" foam in a can?
...make a mold (wax paper?), spray in the foam; let it harden, sand down, and cover with suitably colored cloth, tolex, or faux-naugahyde.
...for a tight fit, wrap the SGII (without cable) in wax paper and position in as you want within the mold.
Old 02-02-2010, 07:00 PM   #6 (permalink)
recession proof rebel
k.civic.f4i's Avatar
stay away from the foam in a can!!!! it's evil. fiberglass is the way to go. fairly easy, just time consuming.
how to.....
http://ecomodder.com/forum/showthrea...cks-11998.html
http://ecomodder.com/forum/showthrea...how-12301.html
true wealth comes from good health and wise ways
Old 02-02-2010, 07:21 PM   #7 (permalink)
any suggestions?
small sheet of...
aluminum diamond plate
Carbon fiber sheet (not fabric, 6"x6" chunk should do)
fiberglass (fairly work intensive, for such a small piece)
abs plastic sheet
choroplast (if your really have to )
thin wood
thin wood upholstered
to name a few
Old 02-06-2010, 05:29 AM   #8 (permalink)
why dont you just cut a hole through the thing that was originally there enough for the bracket to fit? would look really oem. or pick one up from a junkyard and cut that up.
how to.....
Scangauge II vs cruise control rjacob Instrumentation 10 06-02-2011 02:36 PM
Aerodynamic Belly Pan on Toyota Echo jimepting Aerodynamics 23 12-05-2010 06:18 PM
ScanGauge II with X-Gauge: ecomodder price $149.95 smartzuuk Instrumentation 0 09-01-2009 02:07 AM
What is wrong with my scangauge II? 2000mustang fan Instrumentation 5 07-22-2008 10:45 PM
What is X Gauge (on the ScanGauge II)? NeilBlanchard Instrumentation 5 07-22-2008 08:07 PM
