Old 08-02-2010, 01:12 PM   #1 (permalink)
scangauge instrumentation
Installed a ScanGauge II in on '03 Tacoma 4x4.
As a test of accuracy for the horsepower x-gauge, I did an (old-mans version) of a fast takoff. From a stop, I did a smooth roll-on of the throttle to about 80 or 90% of available throttle, shifting at ~3500 RPM. Scanguage reported a reading of 135 horses which sounds pretty good cause the 2.7 I4 is rated at 150 horses.
Around town, on mostly flat land with small hills, it appears that my peak HP use is around 60 HP. Most of use is around 30 to 40 horses. I haven't scoped out highway travel yet.
If I were to replace the 2.7 I4 with a micro-diesel or electric motor, should I be looking at torque over horsepower ratings? Seems I recall an expression - something like - we don't drive horsepower, we drive the torque. Any other readings I should be looking at on the Scangauge?
Old 08-02-2010, 02:18 PM   #2 (permalink)
Absent without leave.
Arragonis's Avatar
George - '011 Aygo Go!
Team m8
90 day: 54.54 mpg (US)
Mildred - '011 Prius T-Spirit
90 day: 45.97 mpg (US)
There are probably better replies but HP is a mathematical thing, a measure of work done whereas torque is a measure of 'twist'. The formula is something like
(torque (lb/ft) * rpm) / 5252
I'm not sure about the hp readings from the SG2 as I've had mine 48 hours now
If you want to swap then you need also to match the rev range of the engine to your gearing and weight - maybe an axle swap or something. My TDI has 30 mph/1000 in top but the car is very light (for a modern car that is, its still too heavy IMHO).
I'm not sure how electric motors work in terms of rpm, torque and efficiency except they make max torque from stop. But I'm keen to learn more so I will watch other replies.
No longer here. Bye, and good luck to all.
Scangauge II vs cruise control rjacob Instrumentation 10 06-02-2011 02:36 PM
Scangauge 2: monitoring hp on an Ion manderson99 Instrumentation 5 06-08-2010 11:05 AM
Dealer says ScanGauge ruined my PCM and I can't use ScanGauge anymore Markmysite EcoModding Central 55 05-06-2010 06:31 AM
Scangauge Suggestions JonnyG Instrumentation 23 02-13-2010 04:17 PM
Scangauge 1 - Some help please! jdubbs_scort Instrumentation 6 06-17-2008 03:26 PM
