View Poll Results: What gauge do you use most
Fuel System Loop Status 0 0%
Manifold Absolute Pressure/Boost 1 3.57%
Instant Fuel Economy 21 75.00%
Throttle Position Sensor 10 35.71%
Temperatures 14 50.00%
Average Fuel Economy 20 71.43%
Intake Air Pressure 0 0%
Engine Loading 11 39.29%
Fuel Pressure 1 3.57%
Ignition Timing 2 7.14%
Multiple Choice Poll. Voters: 28. You may not vote on this poll
Old 09-30-2011, 05:28 PM   #31 (permalink)
Absent without leave.
Arragonis's Avatar
George - '011 Aygo Go!
Team m8
90 day: 54.54 mpg (US)
Mildred - '011 Prius T-Spirit
90 day: 45.97 mpg (US)
Originally Posted by CigaR007 View Post
For some reason LOD never goes over 84-85 on my car.
I'm still not convinced on what LOD is or how it helps.
No longer here. Bye, and good luck to all.
Old 09-30-2011, 05:45 PM   #32 (permalink)
PaleMelanesian's Avatar
PaleCivic - '96 Civic DX Sedan
90 day: 74.33 mpg (US)
Originally Posted by MPGranger View Post
So I just need to eyeball the engine loading then?
Also, if I hit 99 LOD with the accelerator half depressed, what happens when I continue to press the pedal?
It means you've removed the throttle as the biggest restriction in the system. The intake, air filter, valves and/or something else are holding it back.
It also means you need to back off the throttle. Most fuel-injected cars enrich the mix at full throttle, putting in extra fuel that doesn't burn. That extra fuel is wasted.
- - - - -Best 11-mile commute: 105 mpg
- - - - -Best tank: 88.5 mpg / 1133 miles
The Following User Says Thank You to PaleMelanesian For This Useful Post:
MPGranger (10-01-2011)
Old 09-30-2011, 05:48 PM   #33 (permalink)
LOD can be equated to (or calculated from) manifold vacuum. It points you to where on the bsfc chart you are, so you can run the engine at its most efficient point.
Old 10-01-2011, 02:01 PM   #34 (permalink)
euromodder's Avatar
Hägar - '05 V50 1.6L Diesel
Diesel
90 day: 52.27 mpg (US)
Snert - '06 S40 1.6L Diesel
90 day: 58.06 mpg (US)
It burns more fuel, but won't help much.
On my diesel car, acceleration isn't faster beyond 98-99 LOD.
Climbing, 99 LOD is the end.
Pushing further doesn't increase speed any more.
Lifetime fuel consumption :
