View Poll Results: What gauge do you use most
Fuel System Loop Status
0 |
0% |
Manifold Absolute Pressure/Boost
1 |
3.57% |
Instant Fuel Economy
21 |
75.00% |
Throttle Position Sensor
10 |
35.71% |
Temperatures
14 |
50.00% |
Average Fuel Economy
20 |
71.43% |
Intake Air Pressure
0 |
0% |
Engine Loading
11 |
39.29% |
Fuel Pressure
1 |
3.57% |
Ignition Timing
2 |
7.14% |
09-23-2011, 06:39 PM
Scangauge settings
Okay, so I got my scangauge today and I am curious what are the four stats people prefer to monitor and why. Right now I am running with current MPG, average MPG, Engine Load, and Throttle positioning sensor.
09-26-2011, 02:08 PM
...beats walking...
...here's what I'm using on my '09 Vibe:
[MPH][MPG]
[RPM][AVG]
• 2011 Chevrolet Cruze LTZ 1.4LT 6A
• 2009 Pontiac Vibe 1.8L/SFI 4A
• 2004 Pontiac Vibe 1.8L/MFI 4A
• 2003 Ford Focus ZX5 2.0L/Zetec 4A
• 1971 Dodge Charger 318 3A
• 1970½ Plymouth AAR 'Cuda 340/6BBL 4M
• 1968 Dodge Charger 383 3A
• 1967 Plymouth Barracuda Formula S 383 4M
• 1965 Plymouth Barracuda Formula S 273 4M
09-26-2011, 02:26 PM
For maximizing mpg:
instant mpg, average mpg, lod
For diagnostics:
fwt for grille block monitoring
vlt for battery charge during extensive eoc
- - - - -Best 11-mile commute: 105 mpg
- - - - -Best tank: 88.5 mpg / 1133 miles
09-26-2011, 03:09 PM
LOD
AVG (used as trip average - instant and tank average are on the OBC)
WT (coolant temp)
AI (intake air temp - shows DPF regeneration)
09-26-2011, 03:18 PM
Efficiency Aficionado
For some reason I hate the average MPG. I rely on the instant MPG and check my average MPG only at the end of the trip.
FWT (grille blocks)
MPG
LOD
IGN
09-26-2011, 04:07 PM
AVG is my most useful tool. Every stop, light, hill, pulse&glide cycle, etc I focus on finishing with the average higher than before. Just keep ratcheting it higher and higher.
The Following User Says Thank You to PaleMelanesian For This Useful Post:
09-26-2011, 04:32 PM
In the Prius I use:
SOC - for the PHEV use
WT - for warm up stages and engine off
GPS - (gas pedal position) for engine off and EV usage
RPM -for acceleration
I wish I had more. I'd love to have the amp gauge up all the time to see what the PHEV is doing and for braking. I'd also like to have AVG on display all the time to use like Andrew does. As it is, I have a few points along my commute that I check it and know generally if I'm doing good or bad.
09-26-2011, 04:46 PM
rpm....
not on your chart.
Since I'm on the hway alot, I use the digital rpm (there is a factory tach)
I realize we all are different in uor sensory input.....but If I never saw Instant MPG, I would be just fine.
Gotta have the AVG MPG or I die!!!!!
like PALMALE said.... keep trying to bump it up.....like a long video game....and I'm going to WIN!!!!.
09-26-2011, 04:55 PM
#9 (permalink)
I never noticed, but is the AVG MPG gauge the "current" average or is it for the "tank" average ?
09-26-2011, 05:00 PM
#10 (permalink)
yeah, thats the only rub.
It is 'current' since the car was turned on. sometimes on a short stop it will continue the exisiting avg. I just don't know what that time limit is....
When I am doing my 11-14hr trips, I will leave the car running and go thru the drive thru for a bite so It doesnt reset in the middle of my trip.
I do know that at the 'next level' of gauges, that you can do trip or day totals. I haven't really gotten there .............
