Old 11-26-2010, 05:04 PM   #1 (permalink)
Scanguage says 25mpg, but manual measurement says = 35mpg
If I measure from top of tank to top of tank, plug in the cost and the distance I travel I get 35mpg for my van.
However, if I plug in my scangauge i get 25mpg max... I never see it rise to 35...
I have the wheel diameter set correctly and the same engine size (2,5 turbo...)
Old 11-26-2010, 05:36 PM   #2 (permalink)
MPG>HP
Little Blue - '09 Focus SE
Team Ford
90 day: 34.41 mpg (US)
You need to calibrate your Scan Guage. Next time you fill up you can enter the amount of gallons/liters used into the SGII to calibrate it.
Best Tank:36.915MPG|422.6Miles
Longest Tank:35.2MPG|435.8Miles
Best Trip:45.9MPG|5.9Miles
The Following User Says Thank You to Angmaar For This Useful Post:
jago25_98 (11-26-2010)
Old 11-26-2010, 10:18 PM   #3 (permalink)
Wiki Mod
Weather Spotter's Avatar
AeroTrix - '06 Matrix base
90 day: 42.69 mpg (US)
yep this is what you need to do. Do it for two tanks and it should be very close.
It will never be right on but will stay within a % or 2.
Old 11-28-2010, 12:02 PM   #4 (permalink)
I disagree: the Scangauge just isn't very good at measuring fuel consumption. I have one in my Insight, which also has the factory mpg gauge. The factory one is as close to accurate as I can measure, the Scangauge reading often differs by 20 mpg or more. That's when it's calibrated, and it loses calibration very easily.
Old 11-28-2010, 12:32 PM   #5 (permalink)
MPG>HP
Team Ford
The Insight has weird A/F ratios (up to 1:25 or something) and the SGII was designed for 1:14.7. So it won't be accurate in less you don't drive in lean burn mode.
Old 11-28-2010, 01:39 PM   #6 (permalink)
Ohh snap
brucey's Avatar
Lesbaru - '00 Outback
90 day: 21.98 mpg (US)
Convertalier - '00 Cavalier Z24 Convertible
90 day: 26.08 mpg (US)
Send a message via AIM to brucey
Mine is consistently accurate within 1% once calibrated.
Daily Driver
Winter Beast
Old 11-28-2010, 02:50 PM   #7 (permalink)
...beats walking...
Old Tele man's Avatar
Vibe - '09 Vibe Base (2ZR-FE)
90 day: 32.19 mpg (US)
Goldie Locks - '011 Cruze LTZ
90 day: 29.42 mpg (US)
...my SGII, on my SIDI '09 Vibe, seems to run within ±2% fairly consistantly, and that's with the Toyota Spark-Ignition Direct Injection (SIDI), not normal MFI.
Old 11-28-2010, 03:48 PM   #8 (permalink)
Pokémoderator
cfg83's Avatar
1999 Saturn SW2 - '99 SW2 Wagon
Team Saturn
90 day: 43.05 mpg (US)
jago25_98 -
I would venture to guess that the SG is not as good at turbo engines.
Here's a silly question but I have to ask it. Is the fuel set to US gallons or Imperial gallons?
CarloSW2
American Solar Energy Society
Old 11-28-2010, 08:22 PM   #9 (permalink)
Wiki Mod
US gallons
Old 11-28-2010, 08:33 PM   #10 (permalink)
Yeah, that's the problem (at least as I understand it): the SGII isn't actually measuring fuel consumption directly, it's inferring it from other measurements and some assumptions, like the A/F ratio. If your engine doesn't follow the assumptions it uses, the values will be wrong.
There are other cars besides the Insight that have some variety of lean burn tech: Lean burn - Wikipedia, the free encyclopedia
Trouble w/ Scanguage... 97Cavalier Instrumentation 7 09-15-2008 12:35 PM
