Old 03-27-2013, 09:28 AM   #1 (permalink)
paulhale's Avatar
94 Honda Civic VX lean burn question
What causes the ECU to put the engine into lean burn? Temperature, oxygen, the airspeed velocity of a swallow carrying a coconut?
I'm trying to track down some lean burn issues, and while I perform some troubleshooting steps, I would like to have a little more info on lean burn from people who have alot more experience with it than I do. Thanks.
Old 03-27-2013, 02:44 PM   #2 (permalink)
I believe it's some combination of:
Coolant temp, intake air temp, RPM, manifold pressure (proxy for engine load), throttle position, and possibly a few other factors.
Have you been able to chase down a good manual for your car? The factory manual or equivalent should lay out the conditions. There are places you can download factory-type manuals for various Honda products; not sure if the VX one is in that list.
-soD
Old 03-27-2013, 03:22 PM   #3 (permalink)
paulhale's Avatar
I do have a paper service manual for my car, and a huge PDF one.
Old 03-27-2013, 03:25 PM   #4 (permalink)
paulhale's Avatar
What can I do to test this? What can cause it to be incorrect?
Old 03-28-2013, 07:56 PM   #5 (permalink)
Rusty crusty trusty - '94 Honda Civic Cx
90 day: 36.13 mpg (US)
Vx - '92 Honda Civic Vx
90 day: 49.97 mpg (US)
Google search. You can use a voltmeter and monitor the 02 output. It's load throttle position 02 temp and map load.
