Old 12-01-2008, 08:37 PM   #131 (permalink)
Mica Blue - '05 xA RS 2.0
90 day: 45.16 mpg (US)
Josepha - '08 xD
90 day: 30.76 mpg (US)
Hi,
After my first commute with the smooth wheel covers on, I gotta' say that my seat o' the pants impression is they are helping a lot! Coasting was better, and the feel of the throttle was better, too. I was able to go faster with similar throttle, and my FE only went up. I got ~240 miles on the first half tank which is in line with higher FE than I have been getting lately.
Of course, some of the change could be the 4 Michelin X-Ice full snows inflated to 40psi (their sidewall max is 51psi, which is surprising). I've had these tires for 2 winters already, and they used to make more noise and not roll as well as they do now. And they never were as good as my all-seasons.
We'll see how the numbers work out, but it looks like I'll be selling the alloy rims and mounting my Yokohama's on the steel rims in the spring...
Old 12-01-2008, 11:28 PM   #132 (permalink)
Funny's Avatar
Rolling Lemon - '02 Corolla S
90 day: 40.94 mpg (US)
Is there a reason you are not running max inflation? Have you experienced negative results (AKA Accidents and near misses)? Sliding, fishtailing, poor stopping distance and the like? If not, pump those puppies up and go for the record tank man!
American by right
Ecomodder by choice
Hypermiler by necessity
Old 12-01-2008, 11:35 PM   #133 (permalink)
EcoModding Lurkaholic
Tercelerat0r's Avatar
White Wallace - '91 Tercel DX
90 day: 28.44 mpg (US)
Trugly - '92 P'Up
90 day: 23.66 mpg (US)
Huh, thats interesting seeing as we're on winter gas, and snow tires typically would hurt your fuel mileage, but who are we to complain.
I gotta go jack my tire pressure up, i'm currently running them at 35psi(MF recommended) gonna put to max sidewall pressure
Max mpg FTW!
Old 12-02-2008, 12:22 AM   #134 (permalink)
Josepha - '08 xD
Hi,
Yes, if I go too high, the wet traction goes to hell, and I start to feel sliding on turns. I'll see how they go on snow as they are -- and there are dimishing returns after certain point. Lastly, the sharper pavement breaks get telegraphed into the chassis -- it starts to seem painful.
I was just surprised that the snowtires had 51psi sidewall max. And at 40psi, they are rolling like crazy; in combination with the smooth wheel covers.
Old 12-05-2008, 07:01 PM   #135 (permalink)
crazy
Hi,
After my first commete with the smooth wheel covers on, I gotta' say that my seat o' the pants impression is they are helping a lot! Coasting was better, and the feel of the throttle was better, too. I was able to go faster with similar throttle, and my FE only went up. I got ~240 miles on the first half tank which is in line with higher FE than I have been getting lately.
I was filling the T-100 in Alamogordo,New Mexico when a family pulled in with a car like yours.The driver/father was very curious about my truck and I don't believe I've ever heard the word "crazy" used so many times in such a short period.I told him about ecomodder.He said they were getting around 36-mpg.It would have been poetic if you'd pulled up about then,and they could have seen what you've done and the difference its made.Crazy!!!!!--------------- The Scion looks great! And great numbers to go with it.---------- I'm already noticing falling mpg due to oncoming winter temps,so don't be frustrated if things get squirrely between now and next spring.-------- Really like what your doing,look forward to your future posts,Phil.
Old 12-26-2008, 12:42 PM   #136 (permalink)
Josepha - '08 xD
Hi,
I have been keeping a fuel log since I got my xA, and I have entered them into the EPA website. Here's the graph of all my tanks -- 178 of 'em so far!
The dips in the graph are during the winter -- I bought it in the late spring of 2005. At first I drove far fewer miles, so the beginning of the graph is compressed a bit in the horizontal/time. I started ecodriving and I did the significant aero mods that account for the latter part of the graph popping up well above the previous highs.
Old 02-27-2009, 01:15 PM   #137 (permalink)
Josepha - '08 xD
Hi,
I thought I'd post a current picture, but I realize it is very similar to the last one. The biggest difference, you cannot see: I've removed the rear under pan, and it did not seem to hurt me at all.
My worst mileage this winter was just above 41mpg, and my best tankful was 46.3mpg! I'm looking forward to getting above 50mpg, after the weather warms up!
Old 02-28-2009, 04:11 PM   #138 (permalink)
Josepha - '08 xD
new upper grill block!
Well, a day after I posted an updated picture -- I added a new more streamlined upper grill block for my xA:
It projects forward to the "nose" of the bumper, and smooths things out, and increases the angles to (hopefully) better deflect the air flow around the car.
I need to make it more symmetrical, and trim it, so it doesn't "want" to lift the lower outside corners...but the air will be pressing this into the car, so it will suffice for the moment. And later as the weather warms, I'll adjust the lower opening for the right amount of cooling.
toxshox (08-23-2010)
Old 02-28-2009, 06:08 PM   #139 (permalink)
Grasshopper
alohaspirit's Avatar
Makai - '01 Echo 4D Auto
90 day: 34.45 mpg (US)
Mauka - '00 Echo 4D Auto
90 day: 34.5 mpg (US)
this is another thread ive been following for a while
great job on the aero Neil
Past Present Future?
Old 03-05-2009, 02:27 PM   #140 (permalink)
Josepha - '08 xD
Hi,
An early update on the new upper grill block: the cooling provided by the remaining opening below the front bumper seems to be keeping things cooler than when I also had the small opening above the bumper! The only thing I can figure is the upper opening was providing a vent for the pressurized air in front of the radiator -- like what happened on the original Taurus.
I'll wait until the weather gets warmer to confirm this, and if it is correct, I can make the lower opening smaller...
grille block
LinkBacks (?)
LinkBack to this Thread: http://ecomodder.com/forum/showthread.php/scion-xa-aero-mods-2969.html
Posted By For Type Date
Volkswagen brings 260-mpg XL1 Concept a step closer to reality - Autoblog Green This thread Refback 07-05-2011 03:29 AM
How bad do you want to get better mileage??? - Page 5 This thread Refback 06-10-2011 05:05 PM
Video Mirrors - "eyes forward" system - Page 2 - ApteraForum.com - Unofficial Aptera Car Forum This thread Refback 06-03-2011 05:52 PM
How much do Rear Spoilers hurt MPG? - Ford Mustang Forums : Corral.net Mustang Forum This thread Refback 04-28-2011 02:02 PM
SPCR • View topic - Super Efficient Cars [very large pictures] This thread Refback 04-13-2011 05:50 PM
Volkswagen brings 260-mpg XL1 Concept a step closer to reality — Autoblog Green This thread Refback 01-26-2011 10:49 AM
Zombie Squad • View topic - Feul Efficiency in a BOV This thread Refback 01-23-2011 11:16 PM
Page 2: Quick weight reduction and slipperiness-- worth it? - Motor Trend The General Forum Forum This thread Refback 12-13-2010 06:47 PM
Neil Blanchard Designs: More ways for auto makers to build more efficient vehicles - Updated 29 June 2010! This thread Refback 11-26-2010 09:09 PM
Nissan Leaf snags 99 mpg rating on official EPA sticker — Autoblog Green This thread Refback 11-24-2010 04:20 PM
Will we ever replace the standard rear- and side-view mirror? - Autoblog Green This thread Refback 11-07-2010 09:13 AM
Neil Blanchard Designs: Aerodynamic modifications to save gasoline This thread Refback 10-10-2010 11:43 PM
Neil Blanchard Designs: "eyes forward" Video Mirrors on my xA This thread Refback 09-23-2010 04:09 AM
xA MPG Hypermiling Quest - Scionlife.com This thread Refback 08-20-2010 02:45 AM
SocialNetworkInc.com: Cloud Vision This thread Refback 08-14-2010 08:54 AM
How much do Rear Spoilers hurt MPG? - Corral.net : Ford Mustang Forums This thread Refback 08-02-2010 05:32 PM
Will we ever replace the standard rear- and side-view mirror? — Autoblog Green This thread Refback 07-19-2010 05:58 AM
EcoModder.com: Vehicle Efficiency Improvements | Facebook This thread Refback 05-20-2010 02:56 PM
3 posts tagged ?ecodriving? - NeilBlanchard?s Blog on Vox This thread Refback 04-27-2010 06:20 PM
More ways for auto makers to build more efficient vehicles - Updated 13 Apr 2010! - Vox This thread Refback 04-15-2010 07:32 PM
Ford creates suggestion box for consumers, what do you want? — Autoblog Green This thread Refback 04-14-2010 01:19 PM
3 posts tagged ?video mirrors? - NeilBlanchard?s Blog on Vox This thread Refback 04-12-2010 03:03 AM
6 posts from 2008 - NeilBlanchard?s Blog on Vox This thread Refback 04-08-2010 03:49 PM
EcoDriving & Other Vehicle Efficiency Improvements (Page 2) - Future Car Reports This thread Refback 03-28-2010 06:25 PM
silentpcreview.com | View topic - Super Efficient Cars [very large pictures] This thread Refback 03-26-2010 10:24 AM
Improving Vehicle Efficiencies -- A List! - Electric A!D This thread Refback 01-27-2010 05:23 PM
"eyes forward" Video Mirrors on my xA - Vox This thread Refback 01-25-2010 08:56 AM
How much do Rear Spoilers hurt MPG? - Corral Forums This thread Refback 01-07-2010 11:34 PM
5 posts tagged ?aerodynamic drag? - NeilBlanchard?s Blog on Vox This thread Refback 12-26-2009 12:13 PM
EcoModder.com: Vehicle Efficiency Improvements | Facebook This thread Refback 12-24-2009 02:13 AM
12 posts from 2009 - NeilBlanchard?s Blog on Vox This thread Refback 11-30-2009 03:23 PM
Production Aptera 2e leaked again on forum — Autoblog Green This thread Refback 10-30-2009 01:09 AM
What if... the Aptera 2e had a EESU? - Page 6 - ApteraForum.com - Aptera Car Forum This thread Refback 10-09-2009 11:17 AM
Greenlings: Will we ever replace the standard rear- and side-view mirror? — Autoblog Green This thread Refback 10-01-2009 11:58 PM
Ask AutoblogGreen: Do electric vehicles need front air intakes? — Autoblog Green This thread Refback 08-29-2009 10:37 AM
Posts (page 2) - NeilBlanchard’s Blog on Vox This thread Refback 08-23-2009 12:16 PM
List of aero mods you can do to your vehicle MetroMPG Aerodynamics 72 01-05-2012 01:36 PM
Scion XA in PA goodblues Introductions 25 08-27-2010 09:49 AM
Aero mods on 06 civic c0da Aerodynamics 28 05-20-2009 04:17 PM
Planning Aero Mods Doofus McFancypants Aerodynamics 30 06-15-2008 07:03 PM
Saturn aero mods? Heynow999 Aerodynamics 5 05-05-2008 07:44 PM
