Old 03-05-2009, 03:43 PM   #141 (permalink)
Grasshopper
alohaspirit's Avatar
Makai - '01 Echo 4D Auto
90 day: 34.45 mpg (US)
Mauka - '00 Echo 4D Auto
90 day: 34.5 mpg (US)
i like the new grill block
it has a definite curve to it
almost looks like
Past Present Future?
Old 04-30-2009, 06:38 PM   #142 (permalink)
Mica Blue - '05 xA RS 2.0
90 day: 45.16 mpg (US)
Josepha - '08 xD
90 day: 30.76 mpg (US)
Hi,
I've put some small "tabs" on the back, that hopefully act like a Kamm back:
The results so far are that these help somewhat, but are not Earth shattering. I hope to extend them down below the lights (and maybe use acrylic over the lights) and across the bottom, too.
Old 04-30-2009, 11:05 PM   #143 (permalink)
Boxhead
whokilledthejams's Avatar
Boxy Brown - '04 xB
90 day: 35.48 mpg (US)
Send a message via AIM to whokilledthejams
Nice! I thought about doing something similar with the xB, but I'm low on Coroplast at the moment.
Old 05-01-2009, 03:48 AM   #144 (permalink)
Josepha - '08 xD
Thanks! I need to get some more, too. I'd like to do some more smoothing on the underside -- though for part of it, I need to get aluminum.
BTW, I have a small addition and change to the rear under pan, to make it shallower and prevent air from getting in above it. I'll take some pictures next time I have it up on the ramps. (I bought a pair, along with two wood beaded seat covers at my local auto parts store!)
In starting to read the Hucho book, I'm wondering if removing the plastic rocker panel thingies on my car would be a small help? I would imagine that the air is coming out from under the car, and a smoother radius might be a bit better?
Old 05-02-2009, 10:55 PM   #145 (permalink)
Josepha - '08 xD
Hi,
Question: has anybody heard of or tried making an insert for a side window that has a NACA intake on it? If you roll down the window and then hold the insert in place adn then roll the window back up to hold it in place, theis would get ventilation air into the car -- hopefully with less drag (and noise) than just opening the window?
Old 05-08-2009, 12:12 PM   #146 (permalink)
Josepha - '08 xD
Hi,
I'm going to head out soon and do some Cd coast down tests! I'll be recording video on my Fuji point and shoot, so the data gathering will be fairly painless -- I've got it attached to a mini tripod, which I will then tape to my steering wheel, so that it videos the ScanGauge II. I've set it to kilometers...
Questions: I've downloaded the spreadsheet from the Instructables page
How do I get reasonably accurate air density? (I'll check the elevation of my test site in Google Earth!)
How do I get the best guesstimate for tire rolling resistance?
Old 05-08-2009, 12:24 PM   #147 (permalink)
Josepha - '08 xD
Hi again,
Hello,
I've determined that the approximate frontal area of the Scion xA is ~18.01 square feet. [See adjusted number below] I inserted this photo into DataCAD 12, scaled it based on the measuring tape just below the bumper, and I then carefully traced the outline of the car with a polyline, and the hatched it with a 1'-0" square grid.
Now, there is some distortion due to the camera being at a point (this is not a true "elevation" view). To minimize this, I used the zoom lens on it's longest focal length, and tried to position the height of the lens to ~1/2 the height of the car. The height scales to ~4'-2 1/2" whereas the specification is 60.2" (~5'-0 1/4"), and the width scales to 5'-1 7/8" vs 66.7" in the spec. so the actual area is like a little greater. In fact, the width is ~19% low and the height is ~7.75% too low, so that averages to 13.375%, so:
18.01 + 13.375% = 20.42 sq ft
[Edit: I will take another photo with a longer lens to try to reduce the error, and post the results later.]
I'm going to use a program called DXO Optics Pro to get perspective and distortion correction for the lens on my Nikon DX-40X, so I should be able to get a pretty accurate frontal area!
Old 05-09-2009, 12:35 AM   #148 (permalink)
Josepha - '08 xD
Hi,
I did the coast down tests today, but the spreadsheet is just shootin' in the dark without a valid rolling resistance. If I use 0.011 (at the lower end of a "normal" tire on a smooth road), then I get a Cd of 0.267, which would be pretty sweet -- but I'm guessing at the RR...
I still need to measure the area from a corrected photo -- I used the number from the CdA list: ~22 sq ft for now.
Old 05-09-2009, 03:28 PM   #149 (permalink)
Naca
Hi,
Neil,Charles Farmer,one of the local nut-cases who runs a streamliner at Bonneville, sells a plex or Lexan clear NACA duct which rivets to clear sheet,as you'll see on NASCAR.They may be available through a race catalog.If you can't find 'em,let me know and I'll hook you up.Tuft-test your side glass and look for vorticity.You'll want to stay way from those areas,as they'll be low pressure.If you incorporate horizontal louvers,you can keep the UV off your skin,wear short sleeves and reduce solar gain into the cabin.It's a great project idea and something I've wanted to do for years.
Old 05-09-2009, 04:57 PM   #150 (permalink)
Josepha - '08 xD
Hi Phil,
The additional thing that this could accomplish is to get the side windows (close to) flush. I'll try some tuft tests when I can -- I'm guessing the rear windows would be better than the front, if the air flow has reattached after the (probable) separation just behind the A pillars?
The fronts might be helped by some flush "rain guards", I'll bet -- this will draw air out of the car, and mybe with less noise than when you just crack the windows?
grille block
LinkBacks (?)
LinkBack to this Thread: http://ecomodder.com/forum/showthread.php/scion-xa-aero-mods-2969.html
Posted By For Type Date
Volkswagen brings 260-mpg XL1 Concept a step closer to reality - Autoblog Green This thread Refback 07-05-2011 03:29 AM
How bad do you want to get better mileage??? - Page 5 This thread Refback 06-10-2011 05:05 PM
Video Mirrors - "eyes forward" system - Page 2 - ApteraForum.com - Unofficial Aptera Car Forum This thread Refback 06-03-2011 05:52 PM
How much do Rear Spoilers hurt MPG? - Ford Mustang Forums : Corral.net Mustang Forum This thread Refback 04-28-2011 02:02 PM
SPCR • View topic - Super Efficient Cars [very large pictures] This thread Refback 04-13-2011 05:50 PM
Volkswagen brings 260-mpg XL1 Concept a step closer to reality — Autoblog Green This thread Refback 01-26-2011 10:49 AM
Zombie Squad • View topic - Feul Efficiency in a BOV This thread Refback 01-23-2011 11:16 PM
Page 2: Quick weight reduction and slipperiness-- worth it? - Motor Trend The General Forum Forum This thread Refback 12-13-2010 06:47 PM
Neil Blanchard Designs: More ways for auto makers to build more efficient vehicles - Updated 29 June 2010! This thread Refback 11-26-2010 09:09 PM
Nissan Leaf snags 99 mpg rating on official EPA sticker — Autoblog Green This thread Refback 11-24-2010 04:20 PM
Will we ever replace the standard rear- and side-view mirror? - Autoblog Green This thread Refback 11-07-2010 09:13 AM
Neil Blanchard Designs: Aerodynamic modifications to save gasoline This thread Refback 10-10-2010 11:43 PM
Neil Blanchard Designs: "eyes forward" Video Mirrors on my xA This thread Refback 09-23-2010 04:09 AM
xA MPG Hypermiling Quest - Scionlife.com This thread Refback 08-20-2010 02:45 AM
SocialNetworkInc.com: Cloud Vision This thread Refback 08-14-2010 08:54 AM
How much do Rear Spoilers hurt MPG? - Corral.net : Ford Mustang Forums This thread Refback 08-02-2010 05:32 PM
Will we ever replace the standard rear- and side-view mirror? — Autoblog Green This thread Refback 07-19-2010 05:58 AM
EcoModder.com: Vehicle Efficiency Improvements | Facebook This thread Refback 05-20-2010 02:56 PM
3 posts tagged ?ecodriving? - NeilBlanchard?s Blog on Vox This thread Refback 04-27-2010 06:20 PM
More ways for auto makers to build more efficient vehicles - Updated 13 Apr 2010! - Vox This thread Refback 04-15-2010 07:32 PM
Ford creates suggestion box for consumers, what do you want? — Autoblog Green This thread Refback 04-14-2010 01:19 PM
3 posts tagged ?video mirrors? - NeilBlanchard?s Blog on Vox This thread Refback 04-12-2010 03:03 AM
6 posts from 2008 - NeilBlanchard?s Blog on Vox This thread Refback 04-08-2010 03:49 PM
EcoDriving & Other Vehicle Efficiency Improvements (Page 2) - Future Car Reports This thread Refback 03-28-2010 06:25 PM
silentpcreview.com | View topic - Super Efficient Cars [very large pictures] This thread Refback 03-26-2010 10:24 AM
Improving Vehicle Efficiencies -- A List! - Electric A!D This thread Refback 01-27-2010 05:23 PM
"eyes forward" Video Mirrors on my xA - Vox This thread Refback 01-25-2010 08:56 AM
How much do Rear Spoilers hurt MPG? - Corral Forums This thread Refback 01-07-2010 11:34 PM
5 posts tagged ?aerodynamic drag? - NeilBlanchard?s Blog on Vox This thread Refback 12-26-2009 12:13 PM
EcoModder.com: Vehicle Efficiency Improvements | Facebook This thread Refback 12-24-2009 02:13 AM
12 posts from 2009 - NeilBlanchard?s Blog on Vox This thread Refback 11-30-2009 03:23 PM
Production Aptera 2e leaked again on forum — Autoblog Green This thread Refback 10-30-2009 01:09 AM
What if... the Aptera 2e had a EESU? - Page 6 - ApteraForum.com - Aptera Car Forum This thread Refback 10-09-2009 11:17 AM
Greenlings: Will we ever replace the standard rear- and side-view mirror? — Autoblog Green This thread Refback 10-01-2009 11:58 PM
Ask AutoblogGreen: Do electric vehicles need front air intakes? — Autoblog Green This thread Refback 08-29-2009 10:37 AM
Posts (page 2) - NeilBlanchard’s Blog on Vox This thread Refback 08-23-2009 12:16 PM
List of aero mods you can do to your vehicle MetroMPG Aerodynamics 72 01-05-2012 01:36 PM
Scion XA in PA goodblues Introductions 25 08-27-2010 09:49 AM
Aero mods on 06 civic c0da Aerodynamics 28 05-20-2009 04:17 PM
Planning Aero Mods Doofus McFancypants Aerodynamics 30 06-15-2008 07:03 PM
Saturn aero mods? Heynow999 Aerodynamics 5 05-05-2008 07:44 PM
