Old 07-15-2009, 09:40 AM   #201 (permalink)
Daox's Paseo - '97 Paseo
Last 3: 53.99 mpg (US)
Daox's Prius - '04 Prius
90 day: 57.08 mpg (US)
CM400E - '81 CM400E
That doesn't sound like a very friendly commute! But, it certainly sounds like you got it figured out.
Old 07-17-2009, 01:51 PM   #202 (permalink)
Mica Blue - '05 xA RS 2.0
90 day: 45.16 mpg (US)
Josepha - '08 xD
90 day: 30.76 mpg (US)
Hiya,
So far, driving without my rear underpan has gotten better FE! At almost halfway through the next tank, the SGII is sitting at almost 50mpg, which is the best FE that I have ever seen. This is up about 2-3mpg over the most recent tanks with the underpan.
I guess the lesson is, you do really need to worry about parachuting -- and by putting an underpan in the front of the car first, and work your way back; working to exclude air flow from getting on the "wrong" side of the mod...
Old 07-17-2009, 02:42 PM   #203 (permalink)
Bio Deezler - '03 Jetta GLS TDI
90 day: 50.78 mpg (US)
Thats funny, I think I am having the same exact problem.
I recently switched fuels to pure bio, which should drop the energy content and subsequently FE by around 6-10 %. Previous fuel switches haven't seen this much variation though. Well this time around I lost 4 mpg; not cool. The other day I leaned under the rear of the car to see that some of my double sided tape had let go on the rear belly pan and it could end up parachuting pretty badly at 70 mph. Just went out to the parking lot here at work and removed it, hopefully I'll get the same effect as you! I think a sturdy rear diffuser is in order now.
Awesome mileage there Neil.
Old 07-24-2009, 10:03 AM   #204 (permalink)
Scion - '05 Xa
90 day: 35.97 mpg (US)
Sisyphus' Bolder - '81 CJ5 base
Truck - '99 Silverado 1500 4x4
Harley - '00 Sportster XLH883
alternator mods?
Hey Neil, great work with the Xa. I'm envious.
I was wondering if you've made any mechanical and/or electrical modifications. I'm planning to replace my (rather worn out) battery with deep-cycle ones, possibly a pair of Optima yellow or blue top (only difference is the blue has threaded studs in addition to the standard automotive ones). I'd relocate them to the spare tire well to allow 2 to fit, as well as to improve front/rear weight balance. My spare has been replaced by a tire-plug kit, a small air compressor, and my trusty AAA card for really bad blowouts.
I've picked up a couple of solid-state relays and plan to cut power to the alternator's winding unless the throttle is at idle or I flip a dashboard-mounted "just in case" switch. Then I'd top off the batteries with a smart charger at home.
Theoretically this would allow the alternator to free-wheel unless I'm coasting, decelerating, or stopped, in which case it would use this otherwise wasted energy to charge the batteries. Do you know of any cases where someone has done something similar?
Old 07-24-2009, 06:52 PM   #205 (permalink)
Old Retired R&D Dude
Transporter - '09 Escape XLS
So, you are going to use idle mode sensor to start charging..
Wouldn't that load on the Alt cause it to load up the ICE,
increasing the TPS to maintain idle RPMs??
And use more fuel than a normal idle?
Humm, back when I was thinking about add-on hybrid adapters,
I figured on hooking up something like a good-MPG vacuum switch
so when I was getting over 60 MPG going down a hill etc,
I would charge my pack. Bring that 60 MPG down some,
like maybe to 40 MPG.?.
The good-MPG switch would be ANDed with a low SOC signal
from the pack monitor. Once both were on, the charging would begin.
Based on the idea that it's best to charge when you have outrageously
good MPG, (or in Fuel-cut-off, using zero fuel) but don't
charge so heavily that you drop your MPG down
too much. I wanted it to work like a Hybrid regen system.
Charge up when coasting up to a redlight or going down a steep hill.
I guess you could test the idea by warming up the ICE and see what
turning on your lights (and high beams) does to your engine loading.
Might want to turn on the rear defroster too.
If your idle RPMs and/or TPS goes up, you'll know Alt loading effects your FE.
IIRC, I've given jumps to people and noticed my car start to change RPMs,
the second I hooked up to the dead battery..
Cheers,
Rich
Old 07-25-2009, 11:20 AM   #206 (permalink)
Scion - '05 Xa
on-demand charging
I was thinking about that too. Maybe I'll wire the "clutch disengaged when starting" idiot switch in series with the TPS signal to the relay. That way it would only charge when the throttle's at idle AND the clutch is engaged, aka fuel cutoff mode (or when idling in neutral, but one thing at a time). But I think that the reduced drag on the engine when the alt is freewheeling would more than offset the extra drain at idle . I suppose the first step is just to disconnect the alt winding wire and see how many dummy lights come on, and what happens to the RPMs.
Regardless, I'll stop here before I get in trouble for hijacking the thread...
Old 08-13-2009, 05:10 PM   #207 (permalink)
Josepha - '08 xD
Update:
I had to reinstall my stock mirrors in order to get an inspection sticker...
But, the video mirrors are back on. They work better in every situation except bright sunshine: low light and in the rain, the video mirrors are far superior to the optical ones, and the field of view of the video mirrors is much better. I am leaving the small optical mirror on for the bright sunny days -- I get the best of both this way.
The other issue I had with the inspection was the age of my license plate: it is ~32 years old (it is the ONLY plate I have ever had on a car!), and has some cracking and is not as readable as it could be. I've seen far worse, though. If I take the state up on the offer to replace it with new plates with the same number -- I'll have to have a plate on the front of the car...which I don't like for aerodynamic reasons.
Old 08-13-2009, 05:20 PM   #208 (permalink)
Dartmouth 2010
SVOboy's Avatar
Vegan Powa! - '91 CRX DX
90 day: 66.52 mpg (US)
You could always take the opportunity to get some super sweet vanity plates...I'm planning on it soon!
Old 08-18-2009, 11:08 AM   #209 (permalink)
Josepha - '08 xD
Hi,
Well, yesterday I found a fairly major flaw with my video mirrors: the LCD screens go black when they get too hot! This happened to the left hand one, which is exposed to more direct sunlight. This is probably part of the reason why they get darker in bright sunshine -- again the one on the left is often darker and harder to see than the screen on the right.
I may try to rig up a quiet 120mm fan behind them to try yo keep them cooler. Or, if it gets really hot (today is supposed to be hotter than yesterday) then I may be forced to turn on the A/C and that will test my theory...
Bummer. The screens do generate some heat on their own. After it sat in the shade for a while, the screen started working again.
Old 08-18-2009, 11:48 AM   #210 (permalink)
Slow and easy
elhigh's Avatar
Josie - '87 Pickup
90 day: 30 mpg (US)
Hi,
I had that happen with my multimeter while diagnosing a bum rooftop AC unit a couple of weeks ago. No problem, just dangle it under the output of this kitchen ventilator - that flow is air conditioned!
The fan ought to do the job, but geez - you have room?
You're not in front of me...
I'm 25,000 miles in front of you.
grille block
LinkBacks (?)
LinkBack to this Thread: http://ecomodder.com/forum/showthread.php/scion-xa-aero-mods-2969.html
Posted By For Type Date
Volkswagen brings 260-mpg XL1 Concept a step closer to reality - Autoblog Green This thread Refback 07-05-2011 03:29 AM
How bad do you want to get better mileage??? - Page 5 This thread Refback 06-10-2011 05:05 PM
Video Mirrors - "eyes forward" system - Page 2 - ApteraForum.com - Unofficial Aptera Car Forum This thread Refback 06-03-2011 05:52 PM
How much do Rear Spoilers hurt MPG? - Ford Mustang Forums : Corral.net Mustang Forum This thread Refback 04-28-2011 02:02 PM
SPCR • View topic - Super Efficient Cars [very large pictures] This thread Refback 04-13-2011 05:50 PM
Volkswagen brings 260-mpg XL1 Concept a step closer to reality — Autoblog Green This thread Refback 01-26-2011 10:49 AM
Zombie Squad • View topic - Feul Efficiency in a BOV This thread Refback 01-23-2011 11:16 PM
Page 2: Quick weight reduction and slipperiness-- worth it? - Motor Trend The General Forum Forum This thread Refback 12-13-2010 06:47 PM
Neil Blanchard Designs: More ways for auto makers to build more efficient vehicles - Updated 29 June 2010! This thread Refback 11-26-2010 09:09 PM
Nissan Leaf snags 99 mpg rating on official EPA sticker — Autoblog Green This thread Refback 11-24-2010 04:20 PM
Will we ever replace the standard rear- and side-view mirror? - Autoblog Green This thread Refback 11-07-2010 09:13 AM
Neil Blanchard Designs: Aerodynamic modifications to save gasoline This thread Refback 10-10-2010 11:43 PM
Neil Blanchard Designs: "eyes forward" Video Mirrors on my xA This thread Refback 09-23-2010 04:09 AM
xA MPG Hypermiling Quest - Scionlife.com This thread Refback 08-20-2010 02:45 AM
SocialNetworkInc.com: Cloud Vision This thread Refback 08-14-2010 08:54 AM
How much do Rear Spoilers hurt MPG? - Corral.net : Ford Mustang Forums This thread Refback 08-02-2010 05:32 PM
Will we ever replace the standard rear- and side-view mirror? — Autoblog Green This thread Refback 07-19-2010 05:58 AM
EcoModder.com: Vehicle Efficiency Improvements | Facebook This thread Refback 05-20-2010 02:56 PM
3 posts tagged ?ecodriving? - NeilBlanchard?s Blog on Vox This thread Refback 04-27-2010 06:20 PM
More ways for auto makers to build more efficient vehicles - Updated 13 Apr 2010! - Vox This thread Refback 04-15-2010 07:32 PM
Ford creates suggestion box for consumers, what do you want? — Autoblog Green This thread Refback 04-14-2010 01:19 PM
3 posts tagged ?video mirrors? - NeilBlanchard?s Blog on Vox This thread Refback 04-12-2010 03:03 AM
6 posts from 2008 - NeilBlanchard?s Blog on Vox This thread Refback 04-08-2010 03:49 PM
EcoDriving & Other Vehicle Efficiency Improvements (Page 2) - Future Car Reports This thread Refback 03-28-2010 06:25 PM
silentpcreview.com | View topic - Super Efficient Cars [very large pictures] This thread Refback 03-26-2010 10:24 AM
Improving Vehicle Efficiencies -- A List! - Electric A!D This thread Refback 01-27-2010 05:23 PM
"eyes forward" Video Mirrors on my xA - Vox This thread Refback 01-25-2010 08:56 AM
How much do Rear Spoilers hurt MPG? - Corral Forums This thread Refback 01-07-2010 11:34 PM
5 posts tagged ?aerodynamic drag? - NeilBlanchard?s Blog on Vox This thread Refback 12-26-2009 12:13 PM
EcoModder.com: Vehicle Efficiency Improvements | Facebook This thread Refback 12-24-2009 02:13 AM
12 posts from 2009 - NeilBlanchard?s Blog on Vox This thread Refback 11-30-2009 03:23 PM
Production Aptera 2e leaked again on forum — Autoblog Green This thread Refback 10-30-2009 01:09 AM
What if... the Aptera 2e had a EESU? - Page 6 - ApteraForum.com - Aptera Car Forum This thread Refback 10-09-2009 11:17 AM
Greenlings: Will we ever replace the standard rear- and side-view mirror? — Autoblog Green This thread Refback 10-01-2009 11:58 PM
Ask AutoblogGreen: Do electric vehicles need front air intakes? — Autoblog Green This thread Refback 08-29-2009 10:37 AM
Posts (page 2) - NeilBlanchard’s Blog on Vox This thread Refback 08-23-2009 12:16 PM
List of aero mods you can do to your vehicle MetroMPG Aerodynamics 72 01-05-2012 01:36 PM
Scion XA in PA goodblues Introductions 25 08-27-2010 09:49 AM
Aero mods on 06 civic c0da Aerodynamics 28 05-20-2009 04:17 PM
Planning Aero Mods Doofus McFancypants Aerodynamics 30 06-15-2008 07:03 PM
Saturn aero mods? Heynow999 Aerodynamics 5 05-05-2008 07:44 PM
