Old 10-22-2009, 11:25 PM   #251 (permalink)
3-Wheeler's Avatar
AlienMobile - '00 Insight
90 day: 98.7 mpg (US)
Neil,
Your second sketch above is closer to what it would take to keep the air attached.
Hi,
The top and the bottom of my sketch are arcs, so the angle of change is constant.
I should mention that a constant rate of change does not necessarily guarantee to keep the air attached, if the angle from horizontal is still too steep.
Take a look at the many NACA airfoil shapes from the 64, 65, and 66 series airfoils. Those tails are quite long to their full length!! Note that the length/width ratio for these airfoils is one average at least 4:1, if not longer. That means if your car width is four feet, the total length of the car body should be at least, four times this, or 16 feet long at a minimum.
When making boat-tailed car bodies, our only practical way of handling the situation is to truncate the airfoil at some practical length, and provide what else... but a Kamm back tail piece to allow the air to detach cleanly.
Once we understand the fundamentals of airfoil design, then it becomes quite easy to determine what our limited length boat-tails should look like.
Hope this helps, Jim.
Old 10-23-2009, 07:04 PM   #252 (permalink)
3-Wheeler's Avatar
Neil,
Here are a couple of pictures that one can contemplate. Notice how long the tails are on these streamlined vehicles?
Craig Vetter streamliner
Burt Monroe Bonneville Salt Flats Streamliner
Now imagine your design similar to these, except you truncate the tail in a place you are comfortable with.
Our vehicles are slower speed types than Burt's shown above, therefore our tails can close a little more sharply, similar to Craig's above.
... and 4 degrees or less on the bottom
Neil, how did you arrive at the 4° limit on the bottom?
Jim.
Old 10-23-2009, 08:21 PM   #253 (permalink)
Cd
Ultimate Fail
Cd's Avatar
Even if you create a tail that is not ' ideal ' in length, you are still filling in a large portion of you wake...right ?
I would guess that a cropped tail would be less beneficial than your stubby boattail design because you would still have a larger wake with the cropped tail.
( Why would it not be ? )
With the stubby boattail, you would lose attachment and the air would begin to become turbulent, but doesn't that happen behind a truncated tail anyways ? ( And with a larger wake too. )
I'm thinking of the Mythbuster golf balled car post that was posted here on the forum. This sounds like a perfect project to test dimples - after all golf balls are a perfect sphere versus teardrop. Who knows - it just might keep your flow attached longer.
( It would be an interesting test )
I feel embarrased to post sometimes with any suggestions.
I'll let the experts have the floor now.
Old 10-23-2009, 08:30 PM   #254 (permalink)
Silver Turtle - '02 Focus Zx3
90 day: 38.83 mpg (US)
You could always use zigzag tape at the point of seperation or Votrex generators (basically the same thing). That would solve your problem of too much angle and too much wake left behind all in one
Old 10-25-2009, 12:08 AM   #255 (permalink)
3-Wheeler's Avatar
Hi Cd,
You are absolutely correct. The entire object of creating a boat-tail is to reduce the amount of turbulence at the back of the object moving through the air.
One way to do that is to add a 'tail' and taper it to allow the air to stay attached as far back as possible. The farther the air stays attached, the smaller the overall wake size with be, and this in turn lowers the overall drag.
And the angle of taper is important as well. Obviously we want to use a steep angle so that skin friction is low, but at the same time, if the angle is too steep, then the air will detach before the end of the tail, and create a larger hole in the air stream.
So there is a balance between choosing a steep angle of taper (loss of attachment), and using a slight angle and making the tail too long (increased skin friction).
Jim.
Old 10-25-2009, 07:27 AM   #256 (permalink)
Mica Blue - '05 xA RS 2.0
90 day: 45.16 mpg (US)
Josepha - '08 xD
90 day: 30.76 mpg (US)
Hello,
Isn't the 3rd possibility to start the long (proper) length boattail -- and then truncate it sharply at a more practical length?
Old 10-25-2009, 10:47 AM   #257 (permalink)
basjoos's Avatar
Aerocivic - '92 Civic CX
Last 3: 70.54 mpg (US)
AerocivicLB - '92 Civic CX
90 day: 72.29 mpg (US)
One fallacy with using a wing airfloil section (NACA series) as a pattern for a boattail is that these are shaped to generate lift, not as a shape for the shortest teardrop that has attached flow. For my boatttail I used the tailcone of a Questair Venture as a starting shape and reduced the bottom angle as much as I thought I could get away with without it dragging on a steep approach angled driveway. The Venture is a 350mph kitplane nicknamed "The Flying Egg" for its short fuselage. It keeps attached flow at 350mph, so it would have no problem doing so at 80mph.
Most aircraft tailcones are longer than they need to be strictly for the purposes of attached flow, since aircraft designers have other considerations such as yaw stability (weathervaning) and providing a long enough lever arm for the rudder and elevators to work against. The Venture has a huge rudder for its size to compensate for its short tailcone, but its designers must have figured the increase in drag from the larger tail is more than compensated by the reduced skin friction from the shorter tailcone. And they must have figured correctly since the Venture is one of the fastest kitplanes out there and is often seen racing at Reno.
aerocivic.com
Old 10-25-2009, 02:07 PM   #258 (permalink)
Cd
Ultimate Fail
Cd's Avatar
Here are some more images of that plane :
And the Space Shuttle boattail. The angle on the underside of the tail is especially steep ! Do you think they still had attached flow ?
Old 10-25-2009, 02:20 PM   #259 (permalink)
Cd
Ultimate Fail
Cd's Avatar
I overlaid the image of the Space Shuttle over your first design ( the short tail ) and the Shuttles' tail is much shorter than yours - but then I realized that I was not looking at it in three dimensions.
Also, the angle on the bottom of the boattail is not as steep as I thought. I flipped it it's not that far off the 'ideal' 15 degrees.
( slap )
Old 10-25-2009, 02:42 PM   #260 (permalink)
Cd
Ultimate Fail
Cd's Avatar
When looking at the Space Shuttle boattail, I see that it is a bunch of airfoils shaped teardrops stuck together. This is especially apparent at the top portion of the boattail where the engine housing is the widest.
Looking at your car, you have something similar, only flipped vertically. The wheels bulge out farther than the rest of the body. I wonder if you could create a bunch of stuck together airfoill shapes like the Shuttle has.
Oh well. ( Brain fart. )
grille block
LinkBacks (?)
LinkBack to this Thread: http://ecomodder.com/forum/showthread.php/scion-xa-aero-mods-2969.html
Posted By For Type Date
Volkswagen brings 260-mpg XL1 Concept a step closer to reality - Autoblog Green This thread Refback 07-05-2011 03:29 AM
How bad do you want to get better mileage??? - Page 5 This thread Refback 06-10-2011 05:05 PM
Video Mirrors - "eyes forward" system - Page 2 - ApteraForum.com - Unofficial Aptera Car Forum This thread Refback 06-03-2011 05:52 PM
How much do Rear Spoilers hurt MPG? - Ford Mustang Forums : Corral.net Mustang Forum This thread Refback 04-28-2011 02:02 PM
SPCR • View topic - Super Efficient Cars [very large pictures] This thread Refback 04-13-2011 05:50 PM
Volkswagen brings 260-mpg XL1 Concept a step closer to reality — Autoblog Green This thread Refback 01-26-2011 10:49 AM
Zombie Squad • View topic - Feul Efficiency in a BOV This thread Refback 01-23-2011 11:16 PM
Page 2: Quick weight reduction and slipperiness-- worth it? - Motor Trend The General Forum Forum This thread Refback 12-13-2010 06:47 PM
Neil Blanchard Designs: More ways for auto makers to build more efficient vehicles - Updated 29 June 2010! This thread Refback 11-26-2010 09:09 PM
Nissan Leaf snags 99 mpg rating on official EPA sticker — Autoblog Green This thread Refback 11-24-2010 04:20 PM
Will we ever replace the standard rear- and side-view mirror? - Autoblog Green This thread Refback 11-07-2010 09:13 AM
Neil Blanchard Designs: Aerodynamic modifications to save gasoline This thread Refback 10-10-2010 11:43 PM
Neil Blanchard Designs: "eyes forward" Video Mirrors on my xA This thread Refback 09-23-2010 04:09 AM
xA MPG Hypermiling Quest - Scionlife.com This thread Refback 08-20-2010 02:45 AM
SocialNetworkInc.com: Cloud Vision This thread Refback 08-14-2010 08:54 AM
How much do Rear Spoilers hurt MPG? - Corral.net : Ford Mustang Forums This thread Refback 08-02-2010 05:32 PM
Will we ever replace the standard rear- and side-view mirror? — Autoblog Green This thread Refback 07-19-2010 05:58 AM
EcoModder.com: Vehicle Efficiency Improvements | Facebook This thread Refback 05-20-2010 02:56 PM
3 posts tagged ?ecodriving? - NeilBlanchard?s Blog on Vox This thread Refback 04-27-2010 06:20 PM
More ways for auto makers to build more efficient vehicles - Updated 13 Apr 2010! - Vox This thread Refback 04-15-2010 07:32 PM
Ford creates suggestion box for consumers, what do you want? — Autoblog Green This thread Refback 04-14-2010 01:19 PM
3 posts tagged ?video mirrors? - NeilBlanchard?s Blog on Vox This thread Refback 04-12-2010 03:03 AM
6 posts from 2008 - NeilBlanchard?s Blog on Vox This thread Refback 04-08-2010 03:49 PM
EcoDriving & Other Vehicle Efficiency Improvements (Page 2) - Future Car Reports This thread Refback 03-28-2010 06:25 PM
silentpcreview.com | View topic - Super Efficient Cars [very large pictures] This thread Refback 03-26-2010 10:24 AM
Improving Vehicle Efficiencies -- A List! - Electric A!D This thread Refback 01-27-2010 05:23 PM
"eyes forward" Video Mirrors on my xA - Vox This thread Refback 01-25-2010 08:56 AM
How much do Rear Spoilers hurt MPG? - Corral Forums This thread Refback 01-07-2010 11:34 PM
5 posts tagged ?aerodynamic drag? - NeilBlanchard?s Blog on Vox This thread Refback 12-26-2009 12:13 PM
EcoModder.com: Vehicle Efficiency Improvements | Facebook This thread Refback 12-24-2009 02:13 AM
12 posts from 2009 - NeilBlanchard?s Blog on Vox This thread Refback 11-30-2009 03:23 PM
Production Aptera 2e leaked again on forum — Autoblog Green This thread Refback 10-30-2009 01:09 AM
What if... the Aptera 2e had a EESU? - Page 6 - ApteraForum.com - Aptera Car Forum This thread Refback 10-09-2009 11:17 AM
Greenlings: Will we ever replace the standard rear- and side-view mirror? — Autoblog Green This thread Refback 10-01-2009 11:58 PM
Ask AutoblogGreen: Do electric vehicles need front air intakes? — Autoblog Green This thread Refback 08-29-2009 10:37 AM
Posts (page 2) - NeilBlanchard’s Blog on Vox This thread Refback 08-23-2009 12:16 PM
List of aero mods you can do to your vehicle MetroMPG Aerodynamics 72 01-05-2012 01:36 PM
Scion XA in PA goodblues Introductions 25 08-27-2010 09:49 AM
Aero mods on 06 civic c0da Aerodynamics 28 05-20-2009 04:17 PM
Planning Aero Mods Doofus McFancypants Aerodynamics 30 06-15-2008 07:03 PM
Saturn aero mods? Heynow999 Aerodynamics 5 05-05-2008 07:44 PM
