Old 12-19-2009, 03:46 PM   #291 (permalink)
smoke
Interesting. I didn't come to the same conclusion, but it's hard to tell from the stills I have. FYI, there are pics of the smoke testing of the car in this thread: Wind tunnel images of GM EV1 (Impact) and Sunraycer solar car
My thought is that with attached flow,the smoke would lay directly against the surface of the backlight and close to the trunklid right to the end.
Your wind tunnel image ( thanks! ) and my still clearly show the smoke trace far above the body,indicating a captured/locked vortex,with flow separating up at the backlight header.
It's been mentioned in the press,that GM has very stringent and rigid standards for outward visibility which may lead to aero compromises.
Old 03-25-2010, 10:15 AM   #292 (permalink)
Mica Blue - '05 xA RS 2.0
90 day: 45.16 mpg (US)
Josepha - '08 xD
90 day: 30.76 mpg (US)
Minor update -- one of my smooth hubcaps came off and ripped the Coroplast rear wheel skirt off with it... bummer. I actually was able to retrieve both -- the wheel cover is warped pretty badly, and it probably is ruined (unless I can mechanically fasten it). The wheel skirt survived almost unscathed!
It felt like I was driving a naked car.
Old 03-25-2010, 05:07 PM   #293 (permalink)
xA
Neil,sorry to hear about the xA's spontaneous disassembly.Some of my Moonies are scattered along New Mexico's interstates.I justify the loss by considering life with the screw-on type.
I never got to recover any so I don't know anything about restoration.Maybe a leather shot-bag and rawhide mallet.
Hope you get her restored.The mods make her a real 'looker.'
NeilBlanchard (03-25-2010)
Old 03-25-2010, 09:24 PM   #294 (permalink)
Josepha - '08 xD
Thanks, Phil -- I've been contemplating making some screw-on covers, or if I can fix the one then I'd have to mechanically affix it... The rear wheels would do better with flat covers; while the domed ones seem to fill the space better. The wheel skirts had to be arched out to clear the rears, and they rubbed a bit.
I've been meaning to remake the skirts and grill block with something more permanent than Coroplast and tape -- but the fact that they work so well as is, also has it's appeal.
Old 04-07-2010, 04:40 PM   #295 (permalink)
Josepha - '08 xD
I got a copy of "Aerodynamics of Road Vehicles" -- the Hucho book! 4th edition...
Old 04-07-2010, 05:01 PM   #296 (permalink)
Daox's Paseo - '97 Paseo
Last 3: 53.99 mpg (US)
Daox's Prius - '04 Prius
90 day: 57.08 mpg (US)
CM400E - '81 CM400E
Wooohoo, congrats. Its a great book.
Old 05-16-2010, 04:40 PM   #297 (permalink)
Josepha - '08 xD
Wheel Strake!
My first take on rear wheel strakes:
The side needs to be smoother, and extend a little farther back, the bottom needs to not slope up quite so much and level from the back...
Old 05-17-2010, 09:35 AM   #298 (permalink)
Josepha - '08 xD
I need to buy some more Coroplast! The wheel strake makes it very obvious that I need to connect it with a larger wheel skirt. And I need to do a full belly pan...
I bought one sheet a couple of years ago, and I think I need another.
Old 05-17-2010, 04:59 PM   #299 (permalink)
Like the wheel fairings. Is the tape a temp or permanent thing?
Old 05-17-2010, 05:17 PM   #300 (permalink)
Josepha - '08 xD
The wheel skirts (with the white-ish "transparent" duct tape) are "semi-permanent; in that I'd like to make them from aluminum and have screws with tabs to attach them.
The wheel strake behind the driver's side rear wheel that I have just added (with the black Gorilla Tape) is temporary. It will serve as a template to make better version (for both sides), once I get more Coroplast.
My latest thought involves extending a Kamm panel up from the tip of the wheel strake to complete the ones I've had on the upper sides for a while now. I'd have to have clear acrylic on the part that passes over the taillights, and I would *not* be able to attach them to the upper parts; because they are on the hatch door...
grille block
LinkBacks (?)
LinkBack to this Thread: http://ecomodder.com/forum/showthread.php/scion-xa-aero-mods-2969.html
Posted By For Type Date
Volkswagen brings 260-mpg XL1 Concept a step closer to reality - Autoblog Green This thread Refback 07-05-2011 03:29 AM
How bad do you want to get better mileage??? - Page 5 This thread Refback 06-10-2011 05:05 PM
Video Mirrors - "eyes forward" system - Page 2 - ApteraForum.com - Unofficial Aptera Car Forum This thread Refback 06-03-2011 05:52 PM
How much do Rear Spoilers hurt MPG? - Ford Mustang Forums : Corral.net Mustang Forum This thread Refback 04-28-2011 02:02 PM
SPCR • View topic - Super Efficient Cars [very large pictures] This thread Refback 04-13-2011 05:50 PM
Volkswagen brings 260-mpg XL1 Concept a step closer to reality — Autoblog Green This thread Refback 01-26-2011 10:49 AM
Zombie Squad • View topic - Feul Efficiency in a BOV This thread Refback 01-23-2011 11:16 PM
Page 2: Quick weight reduction and slipperiness-- worth it? - Motor Trend The General Forum Forum This thread Refback 12-13-2010 06:47 PM
Neil Blanchard Designs: More ways for auto makers to build more efficient vehicles - Updated 29 June 2010! This thread Refback 11-26-2010 09:09 PM
Nissan Leaf snags 99 mpg rating on official EPA sticker — Autoblog Green This thread Refback 11-24-2010 04:20 PM
Will we ever replace the standard rear- and side-view mirror? - Autoblog Green This thread Refback 11-07-2010 09:13 AM
Neil Blanchard Designs: Aerodynamic modifications to save gasoline This thread Refback 10-10-2010 11:43 PM
Neil Blanchard Designs: "eyes forward" Video Mirrors on my xA This thread Refback 09-23-2010 04:09 AM
xA MPG Hypermiling Quest - Scionlife.com This thread Refback 08-20-2010 02:45 AM
SocialNetworkInc.com: Cloud Vision This thread Refback 08-14-2010 08:54 AM
How much do Rear Spoilers hurt MPG? - Corral.net : Ford Mustang Forums This thread Refback 08-02-2010 05:32 PM
Will we ever replace the standard rear- and side-view mirror? — Autoblog Green This thread Refback 07-19-2010 05:58 AM
EcoModder.com: Vehicle Efficiency Improvements | Facebook This thread Refback 05-20-2010 02:56 PM
3 posts tagged ?ecodriving? - NeilBlanchard?s Blog on Vox This thread Refback 04-27-2010 06:20 PM
More ways for auto makers to build more efficient vehicles - Updated 13 Apr 2010! - Vox This thread Refback 04-15-2010 07:32 PM
Ford creates suggestion box for consumers, what do you want? — Autoblog Green This thread Refback 04-14-2010 01:19 PM
3 posts tagged ?video mirrors? - NeilBlanchard?s Blog on Vox This thread Refback 04-12-2010 03:03 AM
6 posts from 2008 - NeilBlanchard?s Blog on Vox This thread Refback 04-08-2010 03:49 PM
EcoDriving & Other Vehicle Efficiency Improvements (Page 2) - Future Car Reports This thread Refback 03-28-2010 06:25 PM
silentpcreview.com | View topic - Super Efficient Cars [very large pictures] This thread Refback 03-26-2010 10:24 AM
Improving Vehicle Efficiencies -- A List! - Electric A!D This thread Refback 01-27-2010 05:23 PM
"eyes forward" Video Mirrors on my xA - Vox This thread Refback 01-25-2010 08:56 AM
How much do Rear Spoilers hurt MPG? - Corral Forums This thread Refback 01-07-2010 11:34 PM
5 posts tagged ?aerodynamic drag? - NeilBlanchard?s Blog on Vox This thread Refback 12-26-2009 12:13 PM
EcoModder.com: Vehicle Efficiency Improvements | Facebook This thread Refback 12-24-2009 02:13 AM
12 posts from 2009 - NeilBlanchard?s Blog on Vox This thread Refback 11-30-2009 03:23 PM
Production Aptera 2e leaked again on forum — Autoblog Green This thread Refback 10-30-2009 01:09 AM
What if... the Aptera 2e had a EESU? - Page 6 - ApteraForum.com - Aptera Car Forum This thread Refback 10-09-2009 11:17 AM
Greenlings: Will we ever replace the standard rear- and side-view mirror? — Autoblog Green This thread Refback 10-01-2009 11:58 PM
Ask AutoblogGreen: Do electric vehicles need front air intakes? — Autoblog Green This thread Refback 08-29-2009 10:37 AM
Posts (page 2) - NeilBlanchard’s Blog on Vox This thread Refback 08-23-2009 12:16 PM
List of aero mods you can do to your vehicle MetroMPG Aerodynamics 72 01-05-2012 01:36 PM
Scion XA in PA goodblues Introductions 25 08-27-2010 09:49 AM
Aero mods on 06 civic c0da Aerodynamics 28 05-20-2009 04:17 PM
Planning Aero Mods Doofus McFancypants Aerodynamics 30 06-15-2008 07:03 PM
Saturn aero mods? Heynow999 Aerodynamics 5 05-05-2008 07:44 PM
