Assume a cop pulls you over for the front side screens -- which exception in the vehicle code would you use to get out of ticket?
(10) Sun screening devices meeting the requirements of Section 26708.2 installed on the side windows on either side of the vehicle's front seat, if the driver or a passenger in the front seat has in his or her possession a letter or other document signed by a licensed physician and surgeon certifying that the person must be shaded from the sun due to a medical condition, or has in his or her possession a letter or other document signed by a licensed optometrist certifying that the person must be shaded from the sun due to a visual condition. The devices authorized by this paragraph shall not be used during darkness.
(d) Notwithstanding subdivision (a), clear, colorless, and transparent material may be installed, affixed, or applied to the front side windows, located to the immediate left and right of the front seat if the following conditions are met:
(1) The material has a minimum visible light transmittance of 88 percent.
(2) The window glazing with the material applied meets all requirements of Federal Motor Vehicle Safety Standard No. 205 (49 C.F.R. 571.205), including the specified minimum light transmittance of 70 percent and the abrasion resistance of AS-14 glazing, as specified in that federal standard.
(3) The material is designed and manufactured to enhance the ability of the existing window glass to block the sun's harmful ultraviolet A rays.
(4) The driver has in his or her possession, or within the vehicle, a certificate signed by the installing company certifying that the windows with the material installed meet the requirements of this subdivision and identifies the installing company and the material's manufacturer by full name and street address, or, if the material was installed by the vehicle owner, a certificate signed by the material's manufacturer certifying that the windows with the material installed according to manufacturer's instructions meets the requirements of this subdivision and identifies the material's manufacturer by full name and street address.
(5) If the material described in this subdivision tears or bubbles, or is otherwise worn to prohibit clear vision, it shall be removed or replaced.
I think why RVs can get away with it is because those are built in or included with the vehicle, thus satisfying the exception D subsection 2. At least that's how I'm interpreting that loophole.
Oh, and I did run a rear side open window+screen test and I saw no difference in GPH at speeds of 45 and 50mph at 16tps compared with an open rear side window with no screen attached. It was also quieter and offers a shading bonus as well.
