Old 09-24-2008, 10:25 PM   #1 (permalink)
EcoMod Wannabe
Sean T.'s Avatar
Taurusaurus Rex - '97 Taurus GL (Sedan)
90 day: 22.51 mpg (US)
Screw heads?
Would screw heads decrease aerodynamics? Or should they be covered with a tiny piece of tape? Mostly I mean head-on but also on the sides of a car.
Old 09-24-2008, 10:47 PM   #2 (permalink)
Thinking out loud... I would expect that you have pretty laminar flow over the sides of the vehicle, right down at the surface. I would expect the minor depressions for the screw heads and the slots to have very little effect due to this. They might have somewhat more of an effect if the screw hole is deeply recessed, though.
I'm not sure about the front, but the air speed at the front is typically lower than the sides, so any real penalty from a lack of smoothness there would likely be reduced. And the "non smoothness" is pretty darned small anyway.
If you're really really trying to get every last bit out of the car that you can, go for it. It shouldn't be any real appreciable weight (compared to the rest of the car), and if you're careful you can avoid having part of the tape sticking out into the windstream. But my guess is that it probably won't have a noticeable effect.
-soD
Old 09-24-2008, 11:03 PM   #3 (permalink)
Moderator
Daox's Paseo - '97 Paseo
90 day: 67.16 mpg (US)
Daox's Prius - '04 Prius
90 day: 52.66 mpg (US)
Minor imperfections such as screw heads really don't hurt anything at the speeds we are traveling at.
EcoRenovator.org - Efficient living and green home improvement
Prius Build Thread
Paseo Build Thread
Old 09-24-2008, 11:21 PM   #4 (permalink)
EcoMod Wannabe
Sean T.'s Avatar
ok. thanks everybody I guess I'll stop worrying about it lol.
Honda IACV explained TomO Off-Topic Tech 5 08-22-2009 03:06 PM
low volume shower heads al128 Saving@Home 14 07-19-2009 10:52 PM
Archimedes screw throttle ronarprfct EcoModding Central 29 08-27-2008 04:10 PM
E.O.C. cracking heads? scissorhands EcoModding Central 8 07-12-2008 11:16 PM
carburetor main jet screw and a/f screw spyghost General Efficiency Discussion 5 06-25-2008 01:36 PM
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.3.2
